Old 01-30-2015, 02:53 PM   #1
goshem
goshem's Avatar
Drives: 16' WRX
Oil in Oil Filter mount.
Is this normal?
goshem is offline   Reply With Quote
Old 01-30-2015, 02:56 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes.
Old 01-30-2015, 02:57 PM   #3
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Mine has had a decent amount in there for the past 2000 miles, haven't seen any falling out. Will probably require some high G turns lol
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 01-30-2015, 03:09 PM   #4
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I noticed that on mine last oil change. Oil levels have not changed since.
GotBRZ1691 is offline   Reply With Quote
Old 01-30-2015, 03:10 PM   #5
evan
Drives: fr-s
Originally Posted by goshem View Post
Is this normal?
I can't speak for everybody else, but mine does not do that. Make sure the mounting surface is clean (grit builds up in there) when changing the filter and make sure you get a nice bit of oil around the new filter gasket ring.
Rinse, Repeat and Update us.
evan is offline   Reply With Quote
The Following User Says Thank You to evan For This Useful Post:
chas3wba0 (01-30-2015)
Old 01-30-2015, 05:11 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
No it's not normal if it was clean when the filter was installed, it means there's a leak. Remove the filter, clean the surface and O-ring, re-lube and re-install.
On the other hand if there was oil there when you changed the filter and it was never wiped clean, then yes that would be expected.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 01-30-2015, 06:56 PM   #7
BRZnut
Drives: BRZ DGM Limited
I've never noticed that. I do my own oil/filter changes and only use the Subaru black filter and always rub some oil on the rubber ring and install the filter only hand tight. What filter are you using?
Old 01-30-2015, 07:03 PM   #8
BRZnut
BTW, some have reported similar leaks with the K+N filter:
http://www.ft86club.com/forums/showthread.php?t=71882
Old 01-30-2015, 07:18 PM   #9
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
I don't have that. Mines has been clean, since the first oil change and oil changes since. But I do my own oil changes could be someone wasted some and neglected to clean up afterwards and if so its normal, otherwise might have a leak.
00NissanNinja is offline   Reply With Quote
Old 01-30-2015, 07:23 PM   #10
chas3wba0
chas3wba0's Avatar
Drives: Yes
Not supposed to happen, but the catch plate is there in case it does... not a big issue, just make sure you lube up the O-ring next time and tighten as much as you can with your bare hands only (no tools)
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-30-2015, 07:24 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I wouldn't worry about a little bit seeping out over the course of several months/thousand miles.
If you don't do your own oil changes it could be buildup since you got the car as a tech has little incentive to wipe down the interface or use a dab of oil on the rubber seal, and I've had terrible luck with techs not tightening or over-tightening things, both could lead to seepage. If your really bothered by it you can pull the filter off wipe down in there and reinstall it and keep an eye on it.
Old 01-31-2015, 04:39 AM   #12
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I inspected this on my car and I do not have this.
Currently have on a Toyota Oil Filter (literally branded Toyota) that is black.
N1rve
Anyone use Kenu Airframe vent mount for phones? Or any other mount? jhh3000 Electronics | Audio | NAV | Infotainment 2 03-12-2014 12:44 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 10:28 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 02:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 11:58 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
