Old 01-28-2015, 04:35 PM   #15
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Pkush View Post
Noob question. So OFT+OFH will give me about 20/30 HP on petrol/e85 for $1k.
If I want the flexfuel kit I need to get Ecutek and any good catless UEL header (for boxer rumble) and the flex fuel kit itself. What am I looking at if I go this direction? roughly double since the flexfuel is about $600? or more?
Thanks
You can run E85 with the OFT, just takes a little more effort. There are threads on it in the tuning section.
Old 01-28-2015, 04:37 PM   #16
Pkush
I'm aware, I was wondering about the whole flexfuel setup, so I can fillup with anything I want at any time and not have to run tanks down to reflash etc etc.
Pkush is offline   Reply With Quote
Old 01-28-2015, 04:42 PM   #17
OkieSnuffBox
Yes, that's the advantage of the flex fuel kit.
It's the only reason I'm considering selling my OFT, because I want to run a Flex Fuel kit since there aren't a ton of E85 stations around.
Old 01-28-2015, 04:46 PM   #18
phrosty
Originally Posted by congee View Post
Does anyone know if our cars have ECU flash counters?
My cars still under warranty but want to get a uel uncatted header plus openflash tune. I know openflash can reflash the ecu back to stock but will the dealership know how many times my ecu has been flashed???
Nobody knows definitively. I don't think anyone has found it in the software the dealers have (TechStream) so you're probably safe there but that doesn't mean corporate doesn't have something fancier they can do if they're trying to avoid paying for a blown engine under warranty.
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
congee (01-29-2015), steve99 (01-28-2015)
Old 01-28-2015, 05:02 PM   #19
Pkush
I suck at explaining what I want.
So my question is what it'll cost to run the flex fuel versus OFT and UEL header.
For the Flex fuel it'll be
649 for kit
749 for ecutek
UEL Header ~600
Anything else? Is there another tune that I need?
Of course labor if not installed by myself but that comes with either setup.
So total is 2,000, just double of the OFT OFH Combo?
Old 01-28-2015, 05:35 PM   #20
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
I've flashed my car over 20 times with OFT, brought it in for some pricey warranty work which involved the ECU.
They didn't notice anything. As long as you flash your rom back to the original file before you bring it in, everything should be fine
BAMF86 is offline   Reply With Quote
The Following 4 Users Say Thank You to BAMF86 For This Useful Post:
Blokatos (04-30-2016), Cacophony (10-05-2016), congee (01-29-2015), IDFWU 420 (02-11-2015)
Old 01-28-2015, 05:54 PM   #21
Turdinator
Señor Member
Turdinator's Avatar
Yet another great summary thread @steve99.
Originally Posted by Shady195 View Post
What do you have for a header? While I want more low/mid range. I really would like to go with an EL header and a dual resonated front pipe simply to have a nice smooth tone thats different from the usual boxer people hear.
Have a look at the dynos for the P&L and JDL EL headers, when tuned they have a nice hump of torque in the mid-range, they never seem to start the dyno low enough to check the low down torque though.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 01-28-2015, 05:55 PM   #22
steve99
Drives: FT86
Originally Posted by Hyper4mance2k View Post
My only gripe is your comment about an equal length header sounding like a Honda. Our cars do not have equal length runners in the heads; cylinders 1 & 3 are vastly different in length, diameter, and flow from cylinders 2 & 4. With an equal length manifold you still get a slight burbble. The only Honda thing about the sound is rasp you get from removing the cats and not having a properly resonated exhaust...
My car sounds like no other car on the road, and I constantly get told that.
no worries deleted that, not trying to be offensive, just did not know how to describe EL header sound,
The Following 2 Users Say Thank You to steve99 For This Useful Post:
chanomatik (01-29-2015), Lav (05-27-2019)
Old 01-28-2015, 06:01 PM   #23
steve99
Drives: FT86
649 for kit
749 for ecutek
UEL Header ~600
Im not up on all the Ecutek pricing
You will need a "flex Fuel" tune with Ecutek so it can read the flex sensor and adjust the timing/fueling ect this may be included with flex fuel kit pricing not sure.
the racerom feature pack is about $350 not sure if thats included.
Old 01-28-2015, 06:09 PM   #24
steve99
Drives: FT86
What @phrosty said plus.
I have helped or know about four guys with issues related to ecu flashing requiring ecu replacement and all have been replaced under warantee.
The dealer suspected, but appeared they had no means of proving.
congee (01-29-2015)
Old 01-28-2015, 09:47 PM   #25
Stumpygt86
Drives: Toyota GT86. N/A for life
This also depends on the header design. A true EL header is made equal length from the back of the valve face. I think the PTuning EL header is within 1.7% variance between runner lengths, the best I have seen so far.
Stumpygt86 is offline   Reply With Quote
The Following User Says Thank You to Stumpygt86 For This Useful Post:
Hyper4mance2k (01-29-2015)
Old 01-29-2015, 04:09 PM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What a thread... WOW
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
ramiram1984 (02-10-2015), s2d4 (02-06-2015), steve99 (02-01-2015)
Old 02-01-2015, 08:27 PM   #27
steve99
Drives: FT86
Added info on heads cams ect.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
IDFWU 420 (02-11-2015), phm14 (05-11-2020), Sportsguy83 (02-01-2015)
Old 02-01-2015, 09:35 PM   #28
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Did some flash tuning to my 03 Ford F250 with the 6.0TD. The consensus was returned it to stock before you took it in to get smogged or to get into the dealer a hundred miles before and they wouldn't know.
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) — General Topics 104 10-10-2016 12:45 PM
What mods next? Exhaust? Intake? Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2013 08:25 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
