#15 | |
Ridge Racerrrrrrrrr
#16 |
Honarary Member
Drives: 2015 FRS
Hey OP, instead of spending 15k on cosmetics. Why not get a supercharger? Then after that, get coils and wheels and your car will stand out alot plus a header and exhaust. 15k on just a cosmetic kit is too ridiculous much imo but if youre aiming for how cool your car looks then by all means go for it. :p
#17 | |
Drives: 86
Very good point. Even if you are only aiming to make it look cool, you can do a lot for way less than 15k. Yeah the RB curb appeal is 10/10 but 5k in aesthetics could land you a 9/10 if not a 10/10 as well. As for performance, if that interests you, refer to what IDFWU said. I'd personally respect an FRS w/ 15k on performance mods more than aesthetics anyways. |
#18 |
Custom User Title
Drives: Asphalt FR-S MT
Yes, but in this case, you are cutting the car up, literally. Exterior doesn't mean much, but if the core is destroyed, I would think that that would have quite an impact. After all, replacing the quarter panels is around 5k (with labor) per side. (Vague number as I do not remember exactly, but you get my drift.)
#19 | |
Drives: 2013 Scion FR-S Raven
Are there any just bolt on kits that can be taken off easily? |
#20 | |
Drives: brz
#21 |
Drives: '24 GR86
There's loads of information out there regarding the topic. While some people choose to not be productive in their responses, the fact is the answer to your questions are out there and can be found with a bit of searching. While I don't personally have one, by best friend here does and I've helped him nuermous times with parts and the build aspect for the car.
In regards to your questions: 1-How much did it all cost you in the end? So like, how much did you pay for your kit, paint, install etc.? For the entire kit with the wing (Fenders, skirts, lip, diffuser, GT wing), you're looking at about $4,600-$5,000 depending on who you buy it from and assuming you're buying authentic products and not replica items. As far as everything else, it depends on who you take it to for paint and installation. Install is relatively easy and can be done without much hassle if you have a helping hand. There are threads and info regarding how to cut and install the kit. There's even a template to you to determine where to cut the original fenders/quarter panels. If you can manage to do the install yourself and only require a third party to do the paint, you'll probably be in around $5,500-$6,000 from the get go; assuming who you take it to does quality work. That's also assuming you have the tools required to install the kit. 2-Do I need anything in particular with the kit when I buy it? I plan to get a new exhaust when I get the kit, but also some new rims and wheels too, but is anything else NEEDED? Besides rivets/screws to bolt the kit on, nothing else is really NEEDED; but when I say that, that means that the kit would fit on the car without adding extra modifications. HOWEVER, you will DEFINITELY WANT to add proper size wheels (and spacers, if applicable), in addition to some type of aftermarket suspension to fill the extremely large wheel arches and some type of aftermarket exhaust to fill out the large cutouts in the rear diffuser. It's not a requirement to make the kit work, but it will look extremely awkward without it. 3-How is rear visibility with the wing? If possible, could one of you guys hop in your car and take a pic of your rear view mirror ![]() I can't help you with this as I haven't been in one with the rear wing, but I would imagine it's not that bad. I imagine it would be similar to the likes of the OEM STI and Evo wings. While they can be seen in your rear view mirror, they don't really block a large amount of your vision out of the rear window. 4-Any place I should take it to in particular? I'm from CT, so I don't think there are too many well known body shops here ![]() I would go into the regional section of the forums and ask in there simply because anybody who isn't from or familiar with CT will not really be able to help you. I'm from CA and currently live in OK and cannot even begin to tell you what is up there in CT, as I've never been. Hell, at this point, I'll just assume that it's a fictional place and doesn't even exist. Just to humor you on this, I'll price out an estimate now: -TRA Widebody w/ GT Wing: Approx $5200 (shipped price) -Enkei RS05RR Wheels (18x10/18x10.5): Approx $2400 -245/35 & 265/35 Dunlop DZ102 Tires: Approx $850 -5x100 to 5x114 Wheel Adapters: Approx $250 -Stance SuperSport Coilovers w/ swift springs: Approx $1400 -Stance Rear Lower Control Arms: Approx $500 -Project Kics Lug Nuts: Approx $250 Just with everything listed above, you're in about $11,000. That doesn't included costs for installation or paint if you have somebody else do it. For me, I'd install myself and I have a friend who paints so I'm covered. I simply pay for supplies which is a few hundred bucks. Keep in mind this is just an estimate and the overall cost can be higher or lower. You can buy more or less expensive wheels, tires, suspension components, lug nuts etc.; but the fact is that the Rocket Bunny route as a whole is going to run you around $10,000 total for authentic items.
#22 | |
I've already accepted the fact that this is going to cost me more than I had planned, so it's a good thing I asked you guys! Guess I'll just have to do a little more saving until I have enough money
#23 |
Drives: 2015 Subaru BRZ Series Blue
Just out of curiosity, how much more money are we talking to have that kit molded into the body?
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
#24 | |
Drives: '24 GR86
To have all of the work and paint done at a shop who does extremely high quality work, I wouldn't be surprised if you're in another few thousand dollars simply because once it's all molded in and ready, pretty much the entire car will need to be repainted.
#25 |
Drives: 2014 Toyota FRS
I have the Aimgain front/rear/sides/spoiler and Greddy v1 fenders...
heres the math so far... Kit - $4500 shipped (4 month wait) Paint/Install - $3000 Skunk2 Coilovers - $1100 Stance LCA - $500 Wheels - $1800 Tires - $800 Lug nuts - $150 You'll need either Spacers - $400 OR Hub Conversion - $750 Brakes/rotors - $2000 So unless you're getting a PHAT tax return...don't do it... ORRRRR ... do it in stages... ![]() ![]() I still need to paint/install the widebody Greddy v1 fenders, they're just sitting in my garage...switch out the rims...buy spacers ( or go hub conversion I'm torn on which to do at the moment ) So...that's another 5k job. Currently saving
#26 |
Thanks for the response man! I was thinking of doing it in stages too haha I'll buy everything else first before the body kit and do the body kit last so I don't have to drop ~15k all at once haha
#27 |
The RB kit is in stock in the US right now so no wait time. Im AZ local and watched my friend James build his up. It starts to all add up quick but looks great when finished.
#28 | |
Drives: It's black.
PM me if you have further questions, I know members can be abrasive.
2013 Subaru BRZ Limited- Crystal Black Silica
