Old 01-22-2015, 09:24 AM   #15
aagun
Drives: 86
I think i know what is ur issue. U do u feel like poping when you go WOT between 2500rpm and 5000RPM ?? . If yes change ur DI as a set
aagun is offline   Reply With Quote
Old 01-22-2015, 12:26 PM   #16
aagun
Drives: 86
sorry not sure where ksa is located. is that south africa
is your fuel 95 RON.??
yes it does rearly need 98RON fuel for best performance and smoothness.
do you know what ecu calibration id your car is like ZA1JA01G.
IF your car was made before mid 2013 it may have an old ecu calibration and dealer should reflash if you have idle problems.
suggest you take to dealer and get them to check
Hey
What is IAM ??
How do i know my ecu not updated . Mine is ZA1J700J
Old 01-22-2015, 05:21 PM   #17
steve99
Drives: FT86
Originally Posted by aagun View Post
Hey
What is IAM ??
IAM is ignition advance multiplier, you will need an ecu logging device to see it or techstream software.
700J is an old calibration, latest one for that model would be ZA1JA01J
that old calid will not have the DI seal fix or the lastest idle dip fixs. you dealer should update it for you.
if you have a flashing device the updated rom is at end to tactrix ecuflash post link below
Old 01-26-2015, 03:29 AM   #18
H-KYD
Drives: gt86
I will discuss these responses with a friend in the workshop this evening
And I'll tell you if something new
H-KYD is offline   Reply With Quote
Old 01-26-2015, 08:35 AM   #19
aagun
Drives: 86
CEL code ??
Old 02-02-2015, 02:31 AM   #20
H-KYD
Drives: gt86
Good morning
Sorry for the delay
After you return to the history of the Cheak Engine
i got
p0113........intake air temperature circuit high input
p0017........crankshaft position -camshaft position correlation (Bank 1 Sensor B)
p0102........ mass air flow circuit low
And this is a reaction to the lack of octane in gasoline.....
Is there a possibility of programming the car ?
Old 02-02-2015, 03:43 AM   #21
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
The car is under warranty, right? Take it to your dealer as soon as possible.
I'm no expert, but if I got a P0017 I'd be worried.
Old 02-02-2015, 05:16 AM   #22
steve99
Drives: FT86
Good morning
Sorry for the delay
i got
as previous guy said take it to dealer Asap it looks like you may have a problem with the cam vvt actuator and also possibly maf sensor as the temp sensor and maf sensor are in same package in intake tube.
Old 03-26-2015, 03:29 AM   #23
H-KYD
Drives: gt86
Good morning
Unfortunately, does not have anything new about the problem
I must updated the car computer my is (A01)
The local agent does not respond to Emails
The Ministry of Commerce procedures take a lot of time.....It is responsible for customer complaints.......
Is there a way in case of failure of all attempts......Is there a way to get the programming outside the agency TO (A02)
Old 03-26-2015, 07:48 AM   #24
steve99
Drives: FT86
Good morning
You could flash that update yourself with Tactrix Ecuflash updaed rom attached to post see taxtrix ecuflash link below or buy openflash tablet its easier to use but more expensive see links below
Sportsguy83 (03-26-2015)
Old 03-26-2015, 10:22 AM   #25
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Id buy the Open Flash Tablet. It is relatively cheap and offers so much. First it would ( or should) solve your problem. Second, you would be able to find tunes for different fuel sources. third, data logging capabilities so you can see what your car is doing and feeling. Fourth, you can check and clear check engine lights.
those are the four major points that sold me on the device but there are a hundred other things it does. My car had an idle issue on the stock tune and would almost stall out without the AC on. The dash lights would all come on and the radio would kick out. Solved by flashing to 91 oct map (95ron equivalent?) and when i want more performance I can add an octane booster and flash over to the 93 oct map (98ron?)
GotBRZ1691 is offline   Reply With Quote
Old 04-08-2015, 06:29 AM   #26
H-KYD
Drives: gt86
Good morning
What's New in thes issue........There are plenty of car's affected , Were sent a detailed email about the problem to the dealer....... After a month ....Person in charge Was on vacation.....!
he says,i will see and speak on the topic of Directors.....!
We are now on the process of gathering the largest number of owners To provide a big complaint
Because patience has ended ....We want a solution
Open Flash Tablet........Is an excellent idea ... but I'm afraid that the conflict with the old programming A01 ,If he was able to replace the OLD MAB I will now calling I WILL Buy it now
Old 05-04-2015, 04:03 AM   #27
H-KYD
Drives: gt86
Good morning
The agent replace the old ECU .....And things are excellent at the moment
I will continue to experiment for a week
But I want to make sure of the Calibration ID
Old 05-04-2015, 07:27 AM   #28
steve99
Drives: FT86
Good morning
buy elm327 adapter
http://m.ebay.com.au/itm/251936784556?nav=SEARCH
and download android torque application from google playstore
