Old 01-21-2015, 05:29 AM   #1
H-KYD
Drives: gt86
Unhappy my 86 is sufferning
Hello Everyone
Ibegan to hate my 86
Ilive in KSA and we have two options for fuel 95octane and 91octane and actuaiiy it less octane than that !
ats funny to be in country floats above oil and hes no 98octane......Im afraid that will damaged the Engungafter time
any suggestione because i feel that the engine is suffening , vibrate strangely especially an traffic jim or suddenly stoping after along ride.....
sametimes the RPM go down 800RPM and get Cheak Engine
1- is there a salution to the fuel problem?
2- iheard from alat of 86 owners thet heat which comes from the headers cause damage to onn of the lgnition coil's.....and case the same symptoms....trur or not ?
Thank s ...
Iapologize for spelling arrors due to translation
H-KYD is offline   Reply With Quote
Old 01-21-2015, 05:55 AM   #2
steve99
Drives: FT86
Originally Posted by H-KYD View Post
Hello Everyone
Thank s ...
sorry not sure where ksa is located. is that south africa
is your fuel 95 RON.??
yes it does rearly need 98RON fuel for best performance and smoothness.
do you know what ecu calibration id your car is like ZA1JA01G.
IF your car was made before mid 2013 it may have an old ecu calibration and dealer should reflash if you have idle problems.
suggest you take to dealer and get them to check
Old 01-21-2015, 06:24 AM   #3
WesleyG
Drives: 2014 Satin White Pearl GTS auto
we only have 95 RON here in SA and our cars seem to run ok with them, even though the fuel flap says 98 RON only
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 01-21-2015, 07:06 AM   #4
steve99
Drives: FT86
thats correct it will run ok but at reduced performance.
if you have ecu logging device have a look at your IAM its probably about 0.5 or less and you will have sognificant knock although you may not hear it.
you guys run same ecu calibration as here in australia and i have seen stock cars with IAM of 0.7 or less on 98 Ron fuel and knock correction of 3 or 4 degrees.
however the original poster apears to have other problems possibly related to early ecu calibrations such as 700 900 or A01 ecu calibrations or the cam actuator problem if his car is running that rough and stalling and idle dip and stability issues.
Old 01-21-2015, 07:08 AM   #5
Guillaume
Guillaume's Avatar
Drives: Exige S 240
KSA=Kingdom of Saudi Arabia
Guillaume is offline   Reply With Quote
Old 01-21-2015, 07:18 AM   #6
steve99
Drives: FT86
wow thought those guys would have great fuel.
sounds car has a problem though if its under warantee should take it to dealer
WazzuGrad (01-27-2015)
Old 01-21-2015, 08:12 AM   #7
H-KYD
Drives: gt86
Unfortunately, my friend KSA is not as many people imagine
Is the use of 95 will damage the engine....؟
Or just about losing power.......
I need to solve problems ....Or may be forced to sell
And I will make sure of the date of manufacture of the car soon
Old 01-21-2015, 09:30 AM   #8
The use of 98 is recommended the use of 95 is required so don't think you have a fuel issue. Since mine is a daily driver and I am not worried about top performance I run 91 (the NA equivalent to your 95) pretty much exclusively with zero issues.
Like has been said already get you ECU flash level checked as that is more likely your problem.
Old 01-21-2015, 09:53 AM   #9
Hydaral
Drives: 2014 Toyota GT86 Pearl White
You could always add some octane booster at every fillup.
Hydaral is offline   Reply With Quote
Old 01-21-2015, 10:04 AM   #10
WesleyG
I really need to try this, with some good octane booster, on a hot day you can feel a serious drop in performance
so what you are saying is that with the knock you mentioned above, this will actually affect longivity of the engine?
2014 37J 86 Auto
Old 01-21-2015, 05:37 PM   #11
steve99
Drives: FT86
theowners manual recomends 98 ron fuel for best performance , it also states 95 ron fuel can be used but it will reduce performane ue to the ecu pulling timing when it detects knock.
the ecu should control knock well enough to prevent engine damage.
however if your car is stalling and idling erraticly this is likely to be another problem and you should get that fixed
Old 01-22-2015, 01:49 AM   #12
H-KYD
Drives: gt86
Good morning
my car date of manufacture JF1ZN12........
Tomorrow I will meet some friends All of them have 86 We will Cheak the lgnition coil
Old 01-22-2015, 03:55 AM   #13
steve99
Drives: FT86
Good morning
that number is vin or vehicle id number, what you need to know is the ecu calibration id you will need an obd scanner or similar to read cit from ecu.
if your car is pre mid 2013 manufacture there is likerly an updated ecu calibration the dealer or you can flash.
Old 01-22-2015, 05:38 AM   #14
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
95 octane is fine. The engine will adjust the timing.
Also, the idle RPM without A/C is only 650 rpm so 800 should be ok, unless if it is fluctuating all the time.
If the RPM is fluctuating without A/C and check engine light on then bring it to dealer!
gzpermadi is offline   Reply With Quote
