| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: WRB BRZ
That might have been my problem all along. I've been using the v1 tune with edited maf scaling. I didn't really understand the difference between the two.
#16 | |
Drives: 2013 Asphalt FR-S
it took me a few attempts to get to the v2 stuff, too many old links floating around and indexed on search engines... this is the correct current download link: scroll to the very bottom for the v2.062 ots maps.
~Namaste~ |
#17 |
Drives: WRB BRZ
I actually created an edited v2 stage 1 tune but wasn't sure if I could use it on my car (I used the correct v2 xmls to edit it). Can you explain the difference between v1 and v2, just a newer updated rom?
#18 | |
Drives: FT86
so should be no problems, however use the V2 deinition files that come in the download file or editing v2 maps. the v2 maps are better. especially stage 1 tunes , better afr control and less intake rasp arround 4000 rpm due better cam timings, slightly better top power you will still likely have to do the maf saling for your perrin 3" intake using vgi utility to get it correct |
| The Following User Says Thank You to steve99 For This Useful Post: | SpeedFromSwede (01-06-2015) |
#19 | |
Drives: WRB BRZ
Hopefully this will fix the issue, I can now wipe my finger in my exhaust tip and see fuel. In my mind that isn't good ![]() http://datazap.me/u/speedfromswede/o...log=0&data=1-9 |
#20 | |
Drives: FT86
double check for any intake air leaks and especially the little gasket on the maf sensor mount its very easy to pinch or crease it. i would expect the perrin supplied scaling to maybe be 5% off max but if your seeing 15% i am starting to suspect a hardware problem or air leak , |
#21 | |
Drives: WRB BRZ
I took the MAF out and inspected it all looked fine (clean, good gasket) so I'm not sure what else to do. I don't want to use VGI if my fuel trims are that high and there is potential hardware issue. ![]() Another note is the fuel trims are fine at idle (probably insignificant) Thanks for all the help, I really appreciate it. |
#22 | |
Drives: FT86
I just thought it was a bit unusual, but the stock maf sensors can vary 8% or more so its likely yours was just different from the maf sensor perrin did their scaling on. its a worthwhile excercise and good experience to scale maf sensor |
#23 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
It is likely your MAF sensor is out of calibration. Mine is and I had to rescale the MAF table. I imagine you could also get a new MAF sensor. The quality control on the MAF sensor for Subaru is not so good. Mine had high positve fuel trims too. Uncorrected I was about 1.0 AFR off from requested.
| High rev | Hempo | Engine, Exhaust, Transmission | 13 | 12-23-2014 07:01 PM |
| How high can i get my rpm in a new car? | 10series#1969 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-14-2014 02:52 AM |
| Why is my GoPro battery life so incredibly bad? | qoncept | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 05-20-2013 02:43 PM |
| High Beams | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-12-2013 11:44 PM |
