Old 01-18-2015, 11:18 PM   #2227
Tromatic
Originally Posted by jxl00 View Post
This upcoming year, I already spent enough money on the car (got wheels), so i'm gonna stick to just stock everything. i'm interested in stage 1 gains. I was wondering is the stage 1 tune noticeable and what actual benefits are there for AT. my real question is the OFT worth it just for the stage 1 tune.
Yes, and E85 in the stock car is an eye-opener. Why would an AT be any different?
Old 01-18-2015, 11:22 PM   #2228
steve99
Drives: FT86
Originally Posted by j_Zer0 View Post
So this seems strange to me: I flashed to stg 2 E85 UEL tonight after following the process to switch over from petrol. After the flash finished I went for a drive to start letting the ECU sort out fuel trims. To my surprise, right off the bat my LTFT was in the single digits and half the time it was at zero. I was expecting to see values much higher than that. I was expecting to have to drive 20 - 30 miles before I saw the kind of numbers I did. Is this unusual? Has anyone else had the same experience or was your LTFT high for a while after flashing?
Log at: www.datazap.me/u/jzer0/first-e85-driving-session?log=0&data=1
if you follow the proceedure i wrote then thats what should happen, i was just being cautious and getting people to check fuel trims before they went banzi, just in case all the petrol was not ot of the lines or they flashed wrong tune ect
Old 01-18-2015, 11:25 PM   #2229
j_Zer0
Drives: Asphalt FRS 2014
Awesome. Thanks Steve. Following your process made the switch to E85 a cake walk.
j_Zer0 is offline   Reply With Quote
The Following User Says Thank You to j_Zer0 For This Useful Post:
steve99 (01-18-2015)
Old 01-19-2015, 01:09 AM   #2230
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
just a disclaimer because I know the gearing is different but I have never been in an auto so I can't personally attest to the results.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 01-19-2015, 02:02 AM   #2231
Tromatic
I suspect the result of the OFT in a manual is much the same as in my AT, something along the lines of "holy shit!" The OFT tunes just seem to get better with each release.
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
Shiv@Openflash (01-19-2015), Triumphrider (01-19-2015)
Old 01-21-2015, 05:09 PM   #2232
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
Hi Open Flash Team,
there are my first 2 logs with the UEL header and Stg.2 93 flash.
Running on 98ron, outside temp was 1°C (34°F)
This one is right after the flash followed by 2-3 min. idle, and some 5km slow traffic driving.
http://datazap.me/u/tomita-san/stage...-7-11-12-13-14
The second one is after 25-30 km of mixed accel. and steady rev driving..
http://datazap.me/u/tomita-san/stage...5-6-7-11-12-14
There is some weird throttle movement, dunno about ..was floored all the time.
Tomita San is offline   Reply With Quote
Old 01-21-2015, 05:32 PM   #2233
steve99
Drives: FT86
Possibly traction contol kicking in ?? was road slippery, logged parameteris throttle plate angle not throttle position of drive by wirethrottle.
Old 01-21-2015, 05:41 PM   #2234
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
I floored it joining the highway before a bridge, the surface was a bit "frozen"..so yes, may be..
What about the results..?
Old 01-21-2015, 05:52 PM   #2235
Wusaa
Newbie
Wusaa's Avatar
Drives: 2013 BRZ ;2004 RX8 GT (SOLD)
i have a OFT
does it feather on-board tuning?
like hondata
Wusaa is offline   Reply With Quote
Old 01-21-2015, 05:52 PM   #2236
steve99
Drives: FT86
other than the weird throttle whch appears to be traction kicking in looks fine
ltft are low
iam is one
minimal knock tny bit of flkc only 0.65
afr looks normal for oft tune
Old 01-21-2015, 06:00 PM   #2237
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
ltft are low
iam is one
Old 01-21-2015, 06:37 PM   #2238
Tromatic
The 2.063 ROM is sweet!
Old 01-22-2015, 01:17 AM   #2239
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Has anyone else not been able to log data? My save and record button are greyed out. The real time diagnostics run I just can't save anything. It worked for the first couple days.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-22-2015, 04:00 AM   #2240
steve99
Drives: FT86
try connecting oft to pc running latest version of openflash manager 1.15.1 i think and let it update also update template file from the oft downloads site
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
