Old 01-17-2015, 07:01 PM   #1
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Lightweight Pulley Install on Automatic?!
Frustrated, I have the GrimmSpeed tool but don't see anyway to use it with the stock pulley. Pulley just spins with car in park or drive so no Bueno there. Do I have to buy an OEM tool to get it out?? Also could get the alternator pulley loose with my 100lb impact.... This is turning not fun in a hurry.
Appreciate advice from anyone with AT Trans install experience.
Thanks
F1fletch is offline   Reply With Quote
The Following User Says Thank You to F1fletch For This Useful Post:
BabaYaga (03-05-2015)
Old 01-17-2015, 07:05 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I don't think this will be appreciated, and I'm sorry, but as a guy who had one on his car. It was the most pointless mod I ever did. Couldn't feel a damn thing in responsiveness. If there was any The autotrans muted it.
I had a shop install mine, but they did mention it was a bitch to do
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
BabaYaga (03-05-2015), Calum (11-21-2016)
Old 01-17-2015, 07:47 PM   #3
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I was able to use the grimmspeed tool as a wedge along with the 1/2 drive. Once rotated to where the idler pulley sits it came loose with the breaker. Alternator pulley finally came loose too!! Patience is key.
I don't expect huge gains from anyog the pulleys (5) but it won't hurt and should look nice
Old 01-19-2015, 01:17 AM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
There have been many people on this forum who would claim otherwise. I am not an expert on engine balancing and dampening, but I know several have had issues after installing various types of aftermarket pulleys.
The Following User Says Thank You to Lonewolf For This Useful Post:
Old 01-19-2015, 09:40 PM   #5
asphaltfrs2014
Drives: Frs
I've had my Perrin lightweight crank, accessory kit pulleys on my auto for over 4 months, no issues whatsoever. It was a pain to get the crank pulley loose, eventually bought the removal tool from Rally Sport Direct. Two days later I had tool in hand. OEM part was easy to uninstall with tool, but the install of the Perrin was tricky. Wound up bending the bolts on the tool but I got it installed. (Air tools would have made it easier, but was concerned I would spin the crank)
asphaltfrs2014 is offline   Reply With Quote
The Following User Says Thank You to asphaltfrs2014 For This Useful Post:
Old 01-25-2015, 11:43 PM   #6
86_dion
Drives: 2015 FRS RS 1.0 # 379
Thanks
Very difficult install. Suggest getting it done by a professional to avoid any problems in the future. Upon install of the three raceseng pullies, i felt an improved throttle response. Revs were a bit quicker. Hardest part imo was breaking the bolt that held the crank pulley but once thats out its a piece of cake just be very careful. Well worth it as a bolt on in my opinion. Good luck and looks great in engine bay.
86_dion is offline   Reply With Quote
The Following User Says Thank You to 86_dion For This Useful Post:
Old 11-18-2016, 04:11 PM   #7
Imperius
Imperius's Avatar
Drives: Subaru BRZ
According to the new service manual the crank shaft bolt should be tightened in a different way from 94lbf, the new way is 14lbf and than another 90 deg turn on the bolt.
I was wondering if people are doing it the old way or the new way ?
I have AT and I am not sure i can pull the replacement the new way without some damage to the aluminum pulley.
Imperius is offline   Reply With Quote
Old 11-18-2016, 05:16 PM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
Mine was tightened to 94 ft lbs. I have around 5-7km on it with no issues. I can't quite recall the mileage when it went on.
Old 11-18-2016, 05:23 PM   #9
Somerandom18
Drives: 2017 manual BRZ
I'd avoid 14 + 90 degrees. My last car had a new torque spec like that and the pulley flew off after 20 miles. It's not enough just be safe with 94.
Sent from my SM-N930V using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 11-18-2016, 05:27 PM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The second method is more safe, but in general both methods are usually identical.
The Following User Says Thank You to nikitopo For This Useful Post:
Imperius (11-20-2016)
Old 11-20-2016, 11:30 PM   #11
Imperius
Imperius's Avatar
Drives: Subaru BRZ
So you are saying 14 + 90 is over kill ?
Old 11-21-2016, 07:31 AM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
I installed a pulley because I thought it would be a good mod.
The only difference I felt was the engine vibrated more. I took it off.
Old 11-21-2016, 07:33 AM   #13
Calum
That Guy
The torque setting with an angle is a torque to yield setting. If you're doing that you need to use a new bolt each time.
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 02:10 AM
FS: Lightweight Pulley Set dj petey Engine, Exhaust, Bolt-Ons 11 05-01-2014 08:41 PM
Lightweight crank pulley on an AUTOMATIC Gani21 Engine, Exhaust, Transmission 17 09-30-2013 11:27 AM
*****Lightweight Pulley For your FR-S/BRZ/86 ***** SOURCE,LLC Engine, Exhaust, Bolt-Ons 2 03-07-2013 09:21 PM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 02:00 PM
