Old 01-17-2015, 03:09 AM   #99
Originally Posted by HotLavaChick View Post
me. i should post the video. idk where to host it though. but i drove it off the lot and as soon as i went over 100 miles it started doing it. pisses me off.
Is it stalling? Or just going up and down a few 100 rpm?
Old 01-17-2015, 03:25 AM   #100
86Tony
Drives: 2015 AOZORA EDITION
That happens a lot on here!This is an absolute treasure trove of knowledge but that can be a double edged sword!
It is waaaay too easy to read something on here and think "hey maybe I have that" and create the symptoms in your head.
Just a friendly heads up:
You will hear weird noises you never heard before in other cars - RWD + Boxer engine + almost no sound proofing = strange sounds
You will probably have a noisy fuel pump (crickets) - There is no guaranteed way to change (not "fix" but change it isn't broken) this no matter what some may say. There are things you can try but there is no one method that works for all. Do not take the time or effort to get the pump changed.
Much (if not most) of the issues and Service bulletins that you may read about here were only applicable to early to mid production 13s. These problems were fixed way before yours or even my car (14) were built.
If you do think you have an issue check and see if it is already on here someplace - If you can't find anything then ask, but remember that "my car makes a swooshing noise when I start it" doesn't mean squat to anybody. Also keep in mind that there are a lot of experts on here but there are also a pile of people that think they are but are full of crap! Verify anything you find out through another source or be very sure you trust what you are told.
And above all remember it is a car and as sad as it can be shit happens!
Thanks a lot Tcoat, all the info you gave me was very informative , yes this is my first boxer so I'm new to the flat engine layout. I love this car so much I just don't want it to break on me. I will put more km on mines and see if I notice anything unusual if I do I will report back? For now I will just enjoy it until then. Thanks again Tcoat hope to see you around
86Tony is offline   Reply With Quote
Old 01-17-2015, 03:34 AM   #101
Oh you will, you will!
And I am a Tony as well!
Old 01-17-2015, 11:38 AM   #102
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
it doesn't stall but almost does. sometimes. other times it fluctuates hard
HotLavaChick is offline   Reply With Quote
Old 01-17-2015, 11:41 AM   #103
Well get it checked then because that is not normal but it is not common either.
Old 01-22-2015, 04:59 PM   #104
86_dion
Drives: 2015 FRS RS 1.0 # 379
I actually had this issue for a while only used shell v power on a 2015 frs rs1.0. Issue was solved once I installed the Crawford eco block q2. Had it installed for 500 miles haven't had idle drop since.
86_dion is offline   Reply With Quote
Old 01-23-2015, 07:39 PM   #105
86Tony
What is the Crawford eco block you speak of??
Old 01-28-2015, 10:05 AM   #106
arvidj
Drives: '93 MR2 Turbo
I will speculate it is this ... http://crawfordperformance.com/product/eco-block-q2/ ... though I am not exactly sure what 'this' is.
It looks like it re-positions the MAF sensor and the description is reminiscent of a snake oil medication.
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 04-01-2015, 01:54 AM   #107
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
I have a 2015 RS 1.0 AT and I have pretty bad RPM fluctuation (goes from 1000 to 400) in park. It seems to occur at the same time as my other issue, my car has really jerky upshifts, both in auto and manual modes. The upshifts seem cause the engine to hiccup, or pause for a split second. Both problems goes away if I restart the car, but seems to come back randomly. Would I be able to get a reflash on my 2015? Or is that only available to certain VINs, I assume early 2013 models.
I had a 2013 FR-S, also AT, that I drove 15k miles on and I never had the jerky upshifts nor RPM fluctuations. My 2015 RS 1.0 I started noticing these issues past the 1000 break in period (which is when I started to push the car harder).
No defroster, AC or anything was on for that video btw.
cdo221 is offline   Reply With Quote
Old 04-08-2015, 12:30 AM   #108
elyugi1
Drives: raven black
Hey i have a 2015 FRS also does the rpm drop but mine only drops to 500 and goes back up to 1000 ? But i have 700 miles only have you found the issue?
elyugi1 is offline   Reply With Quote
Old 04-09-2015, 10:14 AM   #109
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
How many people.has this problems with 2015 models
Late to this, but I have this same issue intermittently with my 15 AT BRZ. Ive noticed it 3 times. The AC was not on in each case. So far i have about 3500 miles. It randomly goes away and its never outright stalled so im not too concerned about it.
Shinobu's Smile is offline   Reply With Quote
Old 06-11-2015, 10:19 AM   #110
KidRed
Drives: 2015 FRS
None! It was an early model problem that was fixed. If you read all of the posts you will see that other then a couple of people that expect a rock solid idle from a boxer engine all the vehicles were early 13s.
The idle does go up and down but it is a normal function of a very precisely computer controlled system.
If it is dropping so far that you are stalling then you may have a problem that requires service but otherwise don't worry it is perfectly normal.
Wrong. I have a month old 2015 FRS and I came here because I have this issue. It's nothing too bad. I'll come to a stop at a light, the rpms will come down, then dip for a sec, car gets wobbly for a second, and then it evens out. AC is on, 500 miles so far.
It only happens at stop lights when I was driving fast and slowed down quickly. Otherwise, I do not experience the issue. I just wanted to confirm the 2015 do suffer from the dip at idle.
KidRed is offline   Reply With Quote
Old 06-11-2015, 11:19 AM   #111
Not the same issue as before which would happen with the AC off and all the time not just under special circumstance. What you are describing is not unusual for many cars not just ours.
Old 08-05-2015, 01:26 PM   #112
Astral Abyss
Drives: 2016 Halo FR-S
I have a brand new 2016 that started doing this today. 280 miles on it. Drove it into work on the interstate for 22 miles, AC on. Pulled into my parking garage downtown, no issues, but when I parked and turned off the AC, it started dropping down to 400rpm, started to stall, jumped up to 1100rpm, slowly started to fall all the way to 400 again, and back up to 1100. It did this about 5-6 times before I turned off the car.
To me at least, it seems like an ECU programming/learning issue. I bet if I pulled the battery for 15 minutes and reconnected it that it would be fine for a while. My 2014 Mustang would do the same thing, but only occasionally and never this bad.
Astral Abyss is offline   Reply With Quote
