#2045 |
OeM seems to work well enough that I can't see an upgrade as necessary.
#2046 | |
i'm sorry, what?
Drives: Canada
on R1Rs, my oem pads produce a max of -0.7 g's while braking.. I'm sure that could be improved. then again I never stab my brakes, so who knows??
#2047 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Changing pads can give you different initial bite and modulation ability when braking. It's all down to the users' preference.
Plus in really hot climates, many runs can fade them.
| The Following User Says Thank You to Kido1986 For This Useful Post: | VADERR (01-12-2015) |
#2048 |
Completely Lost
Drives: 2015 CBS BRZ Limited
I'm seriously considering some carbotech xp10's I should be a lot of bite
#2049 |
The Stig's German cousin
You should be able to hit over 1g braking on top tier street tires. My torque app isn't the best way of measuring, but it pegged me at 1.1 and that sounds about right.
I use Hawk HP+ but most people won't like this pad - extremely high initial bite. Either it will force you to redefine what smooth means on a brake pedal, or you will force the pads through the garage wall. If you want a dual purpose autocross/track pad, look elsewhere; it couldn't cut the cheese for me on track, except for short sessions. |
#2050 |
Ive driven a fully prepped STX car on HP+, it was miserable. Even after 4 events I still could not modulate the brakes. It was an on/off switch. To each their own of course.
#2051 |
Dodging cones
More power to you if they work well for you but this car is too light to get enough heat for these pads and they will be really hard to modulate too. The AX6, two steps down, was too much for a 2600-2700lb car.
#2052 |
#2053 |
Completely Lost
Ughhhh lol I'm so confused haha i wish you could test drive parts like you can cars
#2054 |
Shoot me a message on what you want and maybe we can work something out? I've been testing various parts and have a decent amount of my used stuff in stock.
#2055 | |
Drives: 2013 FRS
Pads don't increase or decrease G's achieved under max braking. Tires and technique do that. Brakes either engage ABS/lock up or they don't and need to be fixed. Any car from the factory should be able to engage ABS/lock up if functioning correctly. Are you saying with sticky tires and factory pads you can't engage ABS? |
#2056 | |
i'm sorry, what?
Drives: Canada
in a straight line on a nice hot day at high speeds? no
#2057 |
Drives: 2013 FRS
#2058 | |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
