Old 01-05-2015, 12:39 PM   #1443
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Hm, might be too low now, but I'll think about it. Not really comfortable pushing the car at non-drive height for extended periods of time because tire wear.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Extreme86 (01-06-2015)
Old 01-05-2015, 04:10 PM   #1444
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
as long as you don't have an obscene amount of toe then your tire wear will be no different than normal.. You could have 3 degrees of camber and have no more tire wear than if you had 0.
Toe is what gives abnormal tire wear. Because you're causing the tire to scrub in a direction it wasn't intended to travel.
Ranatsu is offline   Reply With Quote
Old 01-05-2015, 05:31 PM   #1445
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Sign me up as tentative, I have asked for the last week of January off, but may or may not actually have the 24th off.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following 2 Users Say Thank You to Turkish For This Useful Post:
AteMyShorts (01-05-2015), Extreme86 (01-06-2015)
Old 01-05-2015, 11:30 PM   #1446
Jyn
Noob
Jyn's Avatar
I'm on air, so raising my car up from regular drive height changes my alignment. I wouldn't be sure if I had toe from raising it up an inch or not.
Old 01-06-2015, 09:05 AM   #1447
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
January 24th Twisted Sisters Run - Weather Permitting or we'll reschedule.
  1. Extreme86
  2. AteMyShorts
  3. weederr33 - maybe
  4. Jyn - maybe
  5. Turkish - maybe
  6. zoth - gonna try
  7. alv012 - tentative
Extreme86 is offline   Reply With Quote
The Following User Says Thank You to Extreme86 For This Useful Post:
AteMyShorts (01-06-2015)
Old 01-06-2015, 09:25 AM   #1448
Extreme86
Extreme86's Avatar
If we're rained or drizzled out on the 24th we'll try the 31st. In the past, January runs are pretty fun as nobody else is out there! Hope you can make it, Justin!
Old 01-06-2015, 12:42 PM   #1449
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I'll try to make it.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
Old 01-06-2015, 03:24 PM   #1450
alv012
Seeing as how:
1. I'm a newb to the SA 86 scene even though I've been here for a while
2. I might be moving back to Dallas at some point this year and will sorely miss the hill country
3. I want to really test out my new OFT Tune
I think there's no better time than now for me to come out and meet y'all.
Put me down as a tentative please (Grad school starts up again next week hoping I won't be too busy to come!)
alv012 is offline   Reply With Quote
The Following 2 Users Say Thank You to alv012 For This Useful Post:
AteMyShorts (01-06-2015), Extreme86 (01-06-2015)
Old 01-06-2015, 10:43 PM   #1451
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Autocross this Sunday, if you really want to test it out.
Details are HERE.
bimmer635csi is offline   Reply With Quote
Old 01-07-2015, 03:33 AM   #1452
Ranatsu
Cone basher
Your front toe wouldn't change as they are completely independent of each other in the front. The rear however would change. I think the more negative camber you have the more toe in it gets.
Old 01-07-2015, 09:59 AM   #1453
Jyn
Noob
Jyn's Avatar
I see. I'll think about it, there's some pretty big road hazards on the run.
Old 01-07-2015, 11:45 AM   #1454
Extreme86
Extreme86's Avatar
@Jyn RR336 has the cattle guards...after the 4th one or so they are not too bad. RR335 is the roller coaster run with about 4 or 5 good dips esp. when going fast. Bottom line is that lowered, you'd need to run quite a bit slower than those who push the envelope. Rule of thumb is faster drivers to the front and slower to the rear. Pretty sure we'll do a counter clockwise run and stop at 336 and 41 and then stop on the bridge on 335. We can wait for you to arrive at each of those spots before we take off again as you'll likely be heading up the rear a few minutes behind us when get get to those spots. Weather is the wildcard...if it is wet, we won't go. If it is dry and just cold, I'll be driving slower on curves anyway as my halfway worn down summer tires do not like cold weather at all! Dang PSS tires have been breaking loose on straight line acceleration on dry roads lately. (Parking lot drifting has been fun though.) Hope you can make it Jyn as twisties are fun regardless of the speed you drive them.
AteMyShorts (01-07-2015)
Old 01-07-2015, 11:50 AM   #1455
AteMyShorts
AteMyShorts's Avatar
Drives: Scion FRS Whiteout
Tires the same here!
AteMyShorts is offline   Reply With Quote
The Following User Says Thank You to AteMyShorts For This Useful Post:
Extreme86 (01-07-2015)
Old 01-07-2015, 11:52 AM   #1456
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
How low are you? As stated above if slow down for cattle guards you will have no issues. For 335 and the roll or coaster if you stay under 65 should be fine, lowered on coiloversat bottom out at anything oer 70ish. Always fun throwing sparks from your exhaust scraping.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Official San Antonio , TX Thread!! track_warrior Southwest 3762 03-28-2019 03:03 PM
FR-S/BRZ Bay Area Meet Thread Coconuts Southern California 619 08-10-2015 01:46 PM
*Meet Up & Events* GTA FR-S/BRZ Members Thread joergasm CANADA 72 05-03-2013 04:11 PM
Bay Area Meet Thread ! TheFRSChick Southern California 32 01-06-2013 12:06 AM
Official GTA FR-S/BRZ Meet Photo Thread Hamza7 CANADA 11 07-16-2012 01:40 AM
