Old 01-04-2015, 04:02 PM   #1065
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Originally Posted by AZbrz89 View Post
@Jive Turkey thanks for chiming in, what would you recommend? I have no clue about tires and offset lol
That size Raijin only comes in a +45. I run that setup, you should be good with coilovers.
ApolloSki is offline   Reply With Quote
Old 01-04-2015, 04:12 PM   #1066
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I'm wanting forgestar 18x10's and they are custom made. Just need to know what offset with coilovers.
texasbound972 is offline   Reply With Quote
Old 01-04-2015, 04:14 PM   #1067
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
@ApolloSki so you're saying the 18x9.5 with 255/35/18 will fit all the way around if I install skunk2 coilovers im about to order?
AZbrz89 is offline   Reply With Quote
Old 01-04-2015, 04:34 PM   #1068
pleong
Drives: 2013 Whiteout FR-S
Volk ZE40 18x10 squared
295/30 Toyo R888
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following 7 Users Say Thank You to pleong For This Useful Post:
BRZZZZZZZZZZ (01-04-2015), fx35s (01-04-2015), Hicklinc (02-17-2018), Jake360 (07-08-2015), srizzors25 (01-05-2015), texasbound972 (01-04-2015), ultra (01-10-2015)
Old 01-04-2015, 04:36 PM   #1069
texasbound972
USMC
295/30 Toyo R888
Attachment 99608
Attachment 99609
How much wider are those front fenders compared to stock? Also what offset are you on?
Old 01-04-2015, 04:37 PM   #1070
pleong
Originally Posted by texasbound972 View Post
Are those front fenders the same width as stock? They don't look like they stick out any further.
No they're 20mm wider made by victory function
The Following User Says Thank You to pleong For This Useful Post:
Old 01-04-2015, 04:38 PM   #1071
texasbound972
USMC
You have excellent taste in license plates sir!
The Following User Says Thank You to texasbound972 For This Useful Post:
pleong (01-04-2015)
Old 01-04-2015, 04:43 PM   #1072
pleong
Lol thanks
Old 01-04-2015, 06:01 PM   #1073
texasbound972
USMC
http://instagram.com/p/oMD83XBXdJ/
Old 01-04-2015, 06:17 PM   #1074
ApolloSki
Stealth
ApolloSki's Avatar
They should be good, although you might rub on hard turns depending on your springrates. I'm actually running a 245/35 tire right now with kwv3's and I dont rub on anything and I've run it through almost everything.
The Following User Says Thank You to ApolloSki For This Useful Post:
Old 01-04-2015, 08:04 PM   #1075
AZbrz89
I read somewhere that the mpss run a size bigger that actually a 245 is a 255?
Old 01-04-2015, 09:26 PM   #1076
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
295/30 Toyo R888
Attachment 99608
Attachment 99609
I have to ask if you have done much rear fender modification?\\
I think I am in love with that set up.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-04-2015, 11:11 PM   #1077
ApolloSki
Stealth
ApolloSki's Avatar
I heard they run wider too, and I'm using MPSS.
Old 01-04-2015, 11:57 PM   #1078
AZbrz89
How do you like them? Do you have fi? Im thinking about just going black raijins 18x8 with 255/35/18 mpss with coilovers and that should be perfect for my fi set up. What you think?
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
