Old 01-04-2015, 06:18 AM   #1
kilohercas
Drives: Subaru BRZ (soon?)
Custom GPS/GSM alarm for BRZ and others
Hello,
I am planing to buy Subaru BRZ, and i am 5 months short,so i decided to use this time to develop GPS/GSM tracker for my future car. Since i like do that kind of stuff myself, i stared to collect parts for it. At the moment, alarm system will have this futures:
  • Two reed switched for doors
  • One reed switch for trunk
  • One read switch for hood
  • One reed switch for fuel filler cap
  • Four reed switches for lamps, if any one try to remove it
  • One contact-less temperature sensor for engine compartment
  • One contact-less temperature sensor for passenger compartment
  • Motion sensor for passenger compartment
  • Fuel pump cutoff via SMS
  • 4500mAh battery for 1 weak operation without main lead acid battery
  • Compass/accelerometer if some on try to tow the car.
  • Single reed switch for disabling alarm, so i can drive it
  • Get GPS coordinate request triggered by SMS with correct text
  • Call and listen what's happening inside the car, also speaker is possible to add too
So basic idea, i have lot of reed switches, and if any one is triggered, as example some one will open door, it will send SMS message with error code and location ( simple Google maps link, that will generate flag on top of current location with ~1m error). example of sms message : "Fuel filler cap error http://tinyurl.com/p9sk9wb "
Second line of defense is temperature sensors (MLX90614), if one of two sensors will go above temperature threshold, SMS with error code is send, and i still don't know will i add CO2 gas release valve, so it can put off fire with no damage if that was false alarm is generated.
Third line of defense is MEMS compass/accelerometer, If any one try to tow car, gps compass will generate that car just made a turn, that means, some one try to tow it. If accelerometer event is captured, that will means that some one parked inside your car.
All electronics, charging circuitry , GPS/GSM modem, and battery will fit inside 80x53x24mm aluminum box, and will have two RF connectors for GSM/HSDPA and GPS antennas , that can be mounter above glove box, or on top of the roof. Each reed switch will use only single wire from my electronics, and it will be grounded in series with reed switch, so when magnet is removed, it will generate low level signal for my electronics, while default state will be pulled high inside electronics, so standby current is minimized as well as wiring is simple.
So first question for ft86club members, does any one have idea for simple but useful future that can be added to this system ? But it must be simple to make, since i am a bit limited by my programming skills.
And second question, does any one woulds like to have system like this in your own car ? Only parts will cost around 150$ and i still need to make o profit. Because if more than ten people would want this system inside the car, i will need to add usb programming option for phone numbers, and so on, and it is more complex that just program my phone number into micro controller flash.
kilohercas is offline   Reply With Quote
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 11:35 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 03:01 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 12:42 PM
Alarm? ft86me Scion FR-S / Toyota 86 GT86 General Forum 10 04-15-2013 01:27 AM
Custom Car Alarm? enjoi23 Electronics | Audio | NAV | Infotainment 0 07-31-2012 04:57 PM
