Old 12-29-2014, 05:38 AM   #1
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Recommendation for Cordless Impact Wrench?
Hey all,
I'm looking for recommendations on a good cordless/battery powered impact wrench that I can use to loosen and tighten lug nuts (and potentially other bolts) on my car. Most of my tools are for 1/2" drive, so I'd prefer one that uses that.
I live in a condo, so air powered or corded isn't really an option, as power outlets aren't readily available in the parking garage. Any recommendations? What should I be looking for? Is there anything else I should also consider when buying an impact wrench (accessories etc.)?
Thanks in advance!
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 12-29-2014, 08:32 AM   #2
jvincent
jvincent's Avatar
I picked up a Craftsman from Sears last year that uses a 19.2v Li-Ion battery. Plenty of torque for lug nuts and also handled the subframe bolts with ease.
The Following User Says Thank You to jvincent For This Useful Post:
gdrider77 (01-24-2015)
Old 12-29-2014, 08:35 AM   #3
vroom4
I've used damn near every brand, they are all pretty good. The Milwaukee and kobalt are the best bang for the buck but whatever you can find on sale will be good....not Hf
vroom4 is offline   Reply With Quote
Old 01-01-2015, 03:35 AM   #4
PNW FRS
PNW FRS's Avatar
Sears had the Craftsman on sale about month ago... Picked it up for under $90
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 01-01-2015, 04:04 AM   #5
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I got the 3/8 craftsman with the 18v Nicad. Apparently they do sell Li packs that fit as well, but in retrospect I should have gone with 1/2".
Whatabouteggs is offline   Reply With Quote
Old 01-01-2015, 04:51 AM   #6
cnk
Drives: '13 DGM BRZ Limited
Milwaukee FUEL M18 model 2763 is what I would recommend and use. 1100 lb-ft of torque for removing nuts and 700 lb-ft of torque for fastening. I pretty much don't even start up my compressor any more after getting this impact.
The Following 2 Users Say Thank You to cnk For This Useful Post:
mitosis (01-04-2015), TofuJoe (04-28-2017)
Old 01-01-2015, 10:14 AM   #7
jvincent
jvincent's Avatar
I have the 1/2 inch one. I didn't think the 3/8 would have enough torque.
Old 01-01-2015, 02:40 PM   #8
Whatabouteggs
[Citation Needed]
It does the trick but it seems underpowered. I might get a Li and see if that helps. Or swap the pack with a harbor freight one, they make 20v.
Old 01-01-2015, 04:18 PM   #9
CoupedUpSubie
Drives: 2013 BRZ Limited
I have the 3/8" Milwaukee fuel impact. It can do 200 ft-lbs of torque. Plenty for lug nuts and most other applications. You don't need anything crazy like 700 ft-lbs. everything on a car can be torqued with a 1/2" torque wrench(normally calibrated upto 150 ft-lbs).
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 01-01-2015, 04:51 PM   #10
cnk
You should never torque anything with an impact, only a torque wrench. Also, just because you torque something to 150 doesn't mean that it will only take 150 to remove it. Factor in time, rust, etc. and it can take a lot more to remove. I have the M12 Fuel 3/8", m18 Fuel 3/8", and the M18 Fuel 1/2" high torque and there are some things that you just need the high torque impact for such as axle nuts or crankshaft bolts (on Honda cars especially). After last winter, the M18 3/8" wouldn't take the lugs off, but the high torque took them off without issue. That's after a winter with lots of snow and salted roads.
Go read up on the garagejournal.com forums and you'll see all reviews on any impact you want.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 01-01-2015, 05:35 PM   #11
CoupedUpSubie
I never said anything about torquing fasteners with an impact. As for your 3/8" M18 not removing your lug nuts after a winter of driving, I think you need a new one. Either that or you never rotated your tires and ensured the threads were clean. Our cars call for 89 ft-lbs if I remember correctly.
The newer m18 3/8" impact is good for most applications that your average car owner would do.
I do know that torquing something to 150 ft-lbs will result in needing more then that amount of torque to remove it, I have experienced this more then enough times from Maine winters and working on ships.
If you have a stubborn bolt or nut a penetrating fluid followed by a proper breaker bar is the correct way to remove it. Grabbing a highly over powered impact for the job will result in stripped threads.
As for having 1/2" drive tools already I recommend getting an adapter to go from 3/8 to 1/2. The nice thing about 3/8 is the sockets are usually slightly slimmer and shorter allowing easier access.
Old 01-01-2015, 05:50 PM   #12
cnk
I swap from winter and summer rims/tires every year so no chance of not rotating. My experience with the M18 FUEL 3/8" is different from your experience although in line with what others have experienced on GJ.
I use the M12 FUEL 3/8" for small tight spaces and the HTIW (high torque impact wrench) for everything else. There are multiple settings on all of the Fuel impacts so not much chance of stripping anything. And yes, if an impact won't loosen something then the breaker bar and penetrating oil comes out. . .followed by a torch if all else fails.
My point is, why bother with the regular M18 FUEL 3/8" when you can get the 1/2" model instead and have the flexibility to use a lower setting. The physical size of both M18 models is negligible and you can use a 1/2" to 3/8" adapter if you want.
Old 01-01-2015, 06:23 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You can pry my Dewalt cordless impact from my cold dead hands. It has proven very helpful for all sorts of work. Even gently getting seized bolts loose without snapping them. Best tool purchase I ever made.
Old 01-05-2015, 12:22 AM   #14
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I myself have a Milwaukee. Check out the warranty on the gun and batteries compared to other brands. I remember being pretty impressed with the Milwaukee warranty at the time of purchase. Its not all about ft/lbs...though if you ever want to do a wheel bearing or axle etc (im not sure the torque specs on these cars) having extra grunt makes things much much easier...
Briankbot is offline   Reply With Quote
How does AC impact power? scionfrs2014 Scion FR-S / Toyota 86 GT86 General Forum 48 05-13-2019 06:58 PM
FS: Snap-on 1/2" cordless impact wrench & driver vc86 Mechanical Maintenance and Tools 1 08-04-2014 05:40 PM
Way too loud. Best fix for minimal impact? transition Engine, Exhaust, Transmission 55 07-24-2014 12:02 PM
[SYD] Milwaukee M18 1/2" High-Torque Impact Wrench 2663-22 eckoflyte Australia Classifieds 2 08-27-2013 06:19 AM
