#85 |
Drives: 2013 Firestorm Scion FRS
I have OFT tune stage 2 v2.04 it raised the idle from 650-750
the RPMs still drop when braking but it doesnt go as low as 550 anymore 550 rpm is rough and shakes but 650 is okay and it's never stalled before on idle |
#86 | |||
Drives: '93 MR2 Turbo
The dealer had the car for two days and ensured that the software was the latest and greatest available from Scion.
I am not exactly sure why I should invest in after market tuning when I think I have every right to expect Scion to deliver a vehicle that idles correctly in the first place. I gave them 100% of the money they were expecting and they seem to be happy to give me 99.5% of the vehicle I was expecting. Quote:
And all this time I thought that "fly-by-wire" systems meant that they had decreased the size of the throttle cable. I also did not know that one of the significant engineering trade-offs required during the advancement of automotive technology was "it has become so complex that the engine will no longer idle smoothly". I also find it strange that the technological advancements and increase in complexity have not affected all vehicles. There appear to be many available that do not exhibit the idle hunting that the FR-S does. Why is that? When you are thru insulting my intelligence maybe we can have a meaningful conversation.
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads |
#87 | |
Sorry but as soon as you started throwing around your 50 years of auto experience it opens you up to critique I will leave with a valuable, relevant piece of perspective that may explain why I feel the need to contest your stance on the ordeal: "Learning over knowing" I am anxious to learn how this "idle hunting" behavior is adverse to our engines, trust me I want to know! |
#88 | |
Where to start? The first 30 years worth of cars do not mean shit in this case! Mechanical advanced timing and adjusted carburetors did not have the fine responses the electronically controlled engines do (come on you know that). The 73 Pontiacs were sadly lacking in computer controlled systems of I have been very wrong in how I worked on my cars. Great, you drove a bunch of cars but I do not see any Subarus on that list. After "50 years" of owning cars I would think you know that different makes can have different traits. You want something to be wrong sooooo badly that when the dealer and several very knowledgeable people tell you that the situation is normal you throw out your 50 year of expertise as your only answer? That is the kind of shit that makes the older guys look bad on here! If you are so sure it is wrong take it to another dealership or shop and get a second opinion and then another, and another. If you just keep fishing you find somebody that agrees with you
#89 | ||
I don't care beyond that because it's not damaging the engine at all. Oil pressure is just fine for an excursion to 500 RPM with no significant load.
#90 | |
Drives: BRZ DGM Limited
I can tell you my '13 BRZ does NOT idle like than..even with the AC on. Is it a sign of a problem or a future issue with the car? Can't tell you. |
#91 |
Drives: 2015 FR-S (Halo)
My Camry did it, my dad's Hyundai did it, my mom's Odyssey did it. If it doesn't damage the car and many, many people have it I think it's less of a problem and more of "something that it does".
Edit: like crickets. Sent from my HTC One_M8 using Tapatalk
#92 |
Drives: WRB BRZ
There is a ECU update for this issue with 2013 BRZ. Just take your car in. I did it and my car no longer has RPM fluctuation.
#93 |
Drives: 2015 AOZORA EDITION
How many people.has this problems with 2015 models
#94 |
None! It was an early model problem that was fixed. If you read all of the posts you will see that other then a couple of people that expect a rock solid idle from a boxer engine all the vehicles were early 13s.
The idle does go up and down but it is a normal function of a very precisely computer controlled system. If it is dropping so far that you are stalling then you may have a problem that requires service but otherwise don't worry it is perfectly normal.
#95 | |
#96 |
Drives: '15 Hot Lava FRS
#97 |
#98 | |
It is waaaay too easy to read something on here and think "hey maybe I have that" and create the symptoms in your head. Just a friendly heads up: You will hear weird noises you never heard before in other cars - RWD + Boxer engine + almost no sound proofing = strange sounds You will probably have a noisy fuel pump (crickets) - There is no guaranteed way to change (not "fix" but change it isn't broken) this no matter what some may say. There are things you can try but there is no one method that works for all. Do not take the time or effort to get the pump changed. Much (if not most) of the issues and Service bulletins that you may read about here were only applicable to early to mid production 13s. These problems were fixed way before yours or even my car (14) were built. If you do think you have an issue check and see if it is already on here someplace - If you can't find anything then ask, but remember that "my car makes a swooshing noise when I start it" doesn't mean squat to anybody. Also keep in mind that there are a lot of experts on here but there are also a pile of people that think they are but are full of crap! Verify anything you find out through another source or be very sure you trust what you are told. And above all remember it is a car and as sad as it can be shit happens!
