Old 12-28-2014, 05:15 AM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
OEM Audio+ Enclosure squeaking?
I started noticing my sub enclosure with amp is squeaking at freeway speeds. It's barely noticable with the backseats up but with them down and volume off it can be pretty annoying. Tightening the screws seemed to help a little bit but it's definitely still there. Also with extremely high bass (I'm on full profile) and loud volumes it definitely rattles a bit. Anyone else have a similar experience?
Not sure if it's just mine since I took out my amplifier to send it in before; I've definitely tightened them to the max with a t10 but maybe something went wrong.
edit: looking more into it, I realized that there might be a part missing from my enclosure causing it to squeak. Was this support piece not included in the earlier batches? Is it even in the later ones?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 12-28-2014, 01:44 PM   #2
Chimera
Drives: FRS
Mayhaps some dynamat?
Old 12-28-2014, 05:22 PM   #3
l0aded
Addicted
l0aded's Avatar
I've tried deadening it, filling the gaps, etc but no good. The amp heats up a good amount and might cause some expansion and contraction softening up any soft materials in contact.
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 01:41 PM
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
Alpine audio system upgrade w/ custom sub enclosure rjm86 Electronics | Audio | NAV | Infotainment 11 06-23-2014 11:16 PM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
Squeaking windows bdanisi Scion FR-S / Toyota 86 GT86 General Forum 29 02-10-2013 10:54 AM
