Old 12-26-2014, 11:55 AM   #29
qoncept
qoncept's Avatar
Originally Posted by s2d4 View Post
Actually, it does considering people are saying it doesn't saved weight by referring to the wet, purely cosmetic pieces.
It doesn't matter because you could just take the hood off, replace it with nothing at all and you wouldn't have appreciable weight savings.
qoncept is offline   Reply With Quote
Old 12-26-2014, 12:28 PM   #30
s2d4
s2d4's Avatar
Yeap, you are totally right.
Old 12-31-2014, 10:38 AM   #31
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Carbon fiber wheels....the only real weight bbq saving , u can do. Do it!
Old 12-31-2014, 11:08 AM   #32
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I put a Seibon CF hood on my car. I didn't do it for the weight savings, although it was a little lighter than stock. Nor was it for looks. I did it to vent heat from my engine bay for the turbo kit. I had it Opticoated, so its held up fine for almost 2 years. Once it does start to fade I'll paint match it.
kmbkk is offline   Reply With Quote
Old 12-31-2014, 01:14 PM   #33
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Originally Posted by JiroZero713 View Post
Happy with my cold-air TRD intake from the factory. And I prefer less grippy tires myself in fact I like the stock ones.
Also you are talking to someone with no prior car knowledge of any modding. Cat-back...bushings? Might as well speak Spainish
to me haha.
As I am sure you've noticed, people have a widely differing opinions, even when about the same point of view. Don't worry about being new. You're in the right place and doing some reading through member journals will give you ideas. Speaking car, like speaking spanish, is a skill which can be learned just by emersion. You'll pick it up as you go.
Things to explain. "Cat-Back" refers to an exhaust system which replaces the piping from the Catalytic Converter to the tail of the vehicle. Your "Cat" or catalytic Converter is a device incorporated in the exhaust system of a motor vehicle, containing a catalyst for converting pollutant gases into less harmful ones. While illegal in some, most, or all (I'm not certain which of the 3 is true anymore) states, it's also common to run "Cat-less" which is, as you've guessed, running without any installed.
Your vehicles will usually have 2 Cats. 1 off the vehicle header (This is the exhaust portion that bolts directly to the engine and takes gases from each cylinder) and one in the Mid / Front pipe (Which is the portion of the exhaust usually in the middle of the vehicle.
The bushings are simply the rubber that holds the exhaust to the vehicle in the example of "Exhaust Bushings". (A lot of areas of the vehicle will have bushings in them).
---- Now what caught me as interesting in your post is when you stated you enjoyed the "less grippy" tires. While I enjoy the stock rims, they are heavy. In racing, they are ineffecient. I still have mine because money and I rather enjoy the look of them. My tires, however, bothered me. I am no longer on prius tires, but I am not on heavily "grippy" tires either. I am running a 225/45/r17 (slightly wider than stock) and I believe I am running on Falken Ziex tires (Though I can't remember off hand if that's my FRS, my shitty porsche 924, or my wife's econo-box Versa).
What makes you enjoy "Less grippy" tires?
hope the information helps. If you have questions, please feel free to ask or pm. I'm sure there are a LOT of people here willing to help you get started.
Old 12-31-2014, 02:20 PM   #34
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Just to clarify, they aren't prius tires so to speak. They are a summer tire that was fitted on a sport edition Prius in Japan. The same summer tires that you'll find on a BMW 5 series and other similar sedans. They certainly aren't the grippiest summer tires, but they aren't what was on my wife's Prius. As far as I know, they've never offered summer tires on a Prius in the U.S.
Sent from Tandy 400
Quentin is offline   Reply With Quote
Old 12-31-2014, 02:27 PM   #35
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Sent from Tandy 400
Correct, never offered here on the Prius form factory. Still also correct to say they are Prius tires though.
Old 12-31-2014, 03:52 PM   #36
Bergen23
Drives: '15 Halo FR-S
As been said, cf isn't totally worth it. Although I'm considering CF fenders just because of the bling factor, but its hard to justify cf fenders when they don't add (or subtract for that matter) anything to the car except looks. That 2k or so could be better spent in a tfsa that'll help pay for a supercharger.
Bergen23 is offline   Reply With Quote
Old 12-31-2014, 07:55 PM   #37
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Carbon fibre tailshaft.
Unfortunately there is no bling factor unless the car is up on a hoist.
3rd Brake Light *Low Profile Carbon Fiber (OMG CARBON) (GB OVER- see link) wheelhaus Cosmetic Modification (Interior/Exterior/Lighting) 153 01-26-2021 03:02 AM
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 11:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
FS: Pair of Carbon fiber mirrors cover and a pair of real carbon fiber side fin FRSToyota86 Canada Classifieds 3 03-19-2014 02:07 AM
