#127 | |
Drives: '13 Whiteout FR-S (M/T)
Regarding the rear shock adjuster, do you have to hold the hold piece steady while you turn the silver seat CCW? Is there a torque spec for re-assembly? Funny that the instructions make no mention of this step... Thanks!
#128 |
Drives: 2014 BRZ
I've had mine for several months, several thousand miles, and many track days and am very happy with them on and off the track. I would buy them again.
| The Following User Says Thank You to Sleepless For This Useful Post: | GT86_PRAGUE (12-24-2014) |
#129 |
driving smoother faster
Drives: Sold
^ that, awesome dampers and well worth the money for occasional track and AX use. I'm having them rebuilt now with 500lb rear springs and revalving. Would buy again.
| The Following User Says Thank You to dp1 For This Useful Post: | GT86_PRAGUE (12-24-2014) |
#130 |
@dp1 are you having them services through Ohlins? Do you mind me asking how much rebuilding runs around? Cheers.
#131 | |
Drives: 2005 Toyota Camry
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | 1Cor10:23 (12-24-2014) |
#132 |
I've been on the Ohlins R&T for about 8000 miles which includes maybe 10-12 track days. They are a great balance for street and track use and very solid in terms of build quality and reliability.
My only criticism would be the spring rate; I've switch over to 350/425 F/R and the car rotates much better. It also shows a better distribution of temps on a tire pyrometer. If I want to go stiffer in the rear (as @dp1 is doing), I'd send them in for a revalve. When I called Ohlins about this, they said it would be $125/corner with a one to two day turnaround. |
| The Following 5 Users Say Thank You to kster1 For This Useful Post: | 1Cor10:23 (12-24-2014), Chazzzy (08-04-2016), GT86_PRAGUE (12-24-2014), mokinbird87 (01-12-2015), Sleepless (12-26-2014) |
#133 | |
Drives: Sold
Ohlins Road & Track for FRS/BRZ suspension install/review thread
Yes, they are being rebuilt by Ohlins and they were kind to order correct 500lb springs for me from a well known spring manufacturer and to revalve since the difference in spring rate is more than 20-30% from stock. Can't comment on the price, give them a call, great customer service. Note that full rebuild price will be higher than revalve only price. |
| The Following User Says Thank You to dp1 For This Useful Post: | 1Cor10:23 (12-24-2014) |
#134 | |
Drives: FR-S Whiteout
#135 |
Drives: Sold
I am sorry but I can't disclose the full rebuild price. I am getting a full rebuild that includes revalving so I don't know how much for revalving only, but I had seen the same quote before for revalving per corner as mentioned above. |
#136 | |
BOXER FR
Drives: WRB BRZ Limited
one question. does it feel just as comfortable as they were with the 343lb springs, or is it now at that uncomfortable/track smooth surface only setting? i would assume with proper valving, it would still be very comfortable.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#137 |
Drives: Sold
BTW, I ended up ordering 380f/425r spring rates. These are not progressive springs, so, depending on the adjustment, I suspect that they will work a little better for either low or high speed bumps. They are quite comfortable on the street with stock 345lb f/r springs and I expect that they will remain with the slightly stiffer rates. I'll post impressions in late March when they're back on the car and after Apr/May track days. I will probably do some AX from April on.
| The Following User Says Thank You to dp1 For This Useful Post: | mokinbird87 (01-12-2015) |
#138 |
On the street, the higher spring rate (350F/425R) is noticeable when going over bumps and and ruts in the road. But it's not that much stiffer where I'd call it uncomfortable (at least for my tolerance). I don't daily drive my car but I do drive to the track which is 2-3 hours and it's not too bad.
| The Following User Says Thank You to kster1 For This Useful Post: | mokinbird87 (01-12-2015) |
#139 |
BOXER FR
i think the Ohlins set up is more comfortable than stock, so I can`t imagine the stiffer setting all of a sudden becoming so uncomfortable. maybe if i make it up to Laguna Seca I can hitch a ride in your car @kster1 ?
#140 |
@mokinbird87 why are you in need of a stiffer setup? Just because one prefers stiffer doesn't mean it works for others.
The tires you will run makes a bigger difference for "normal" driving, to be honest. If I gave someone rides with my previous setup (street - Toyo T1 Sport / track - Falken RT615K) vs now (street - Falken FK453 / track - Hanhook RS3), one would swear I changed my suspension setup. Sidewall stiffness makes a huge difference in ride quality. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | AceHeader-MT (01-12-2015) |
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 06:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 01:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 05:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 04:27 PM |
