Old 12-23-2014, 02:40 PM   #15
Covo_86
Covo_86's Avatar
Drives: Whiteout FRS
Originally Posted by mmmcambelsoup View Post
The ride is perfect for my daily commute all over Houston (riddled with potholes). From my own personal experience, I've owned a 3 Series (BC coilovers) and a Jetta (Raceland) which both rode like dog shxt lol. Since I've installed the ST's, they feel like butter to me.. Not too stiff, not too soft.. right in the sweet spot.
Thank you. Yeah I had BC extreme low and wasn't a fan. Are you maxed out or can you go any lower. That height is perfect imo though!
Covo_86 is offline   Reply With Quote
The Following User Says Thank You to Covo_86 For This Useful Post:
mmmcambelsoup (12-23-2014)
Old 12-23-2014, 02:53 PM   #16
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Right now, its maxed out in the front and plenty of room to play in the rear. I plan on getting some LCA's for the rear to make the rear more flush since it's cambering naturally at the moment. Yeah, my BC's on the bmw made so many noises and rode pretty stiff even at the lowest damp setting.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
Covo_86 (12-23-2014)
Old 12-23-2014, 04:28 PM   #17
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
How do you like those Cusco Strut Tower Bars? I was going to get front and rear ones but was talked out of it. I guess because they aren't one solid piece they don't do what they are supposed to do? What has been your experience?
Frishkorn is offline   Reply With Quote
Old 12-23-2014, 05:31 PM   #18
mmmcambelsoup
Tbh, I installed them for more of cosmetic purposes w/ the whole 'blue' and 'polished' theme. What I did notice was a better 'brake feel' if you will. But I'm not sure if that was all in my head. As far as body roll etc, I can't determine if thats from my suspension setup as a whole including the strut bar or not. What I do know is that the setup together w/ coils feels much better than stock in cornering
IG: @Lucky_FatPat
Frishkorn (12-29-2014)
Old 12-24-2014, 10:30 AM   #19
mmmcambelsoup
Coming soon:
Works Bell Rapfix II Quick Release
Works Bell Boss Short Hub
Nardi 350mm Deep Corn W/ Red stitching
IG: @Lucky_FatPat
Old 12-25-2014, 07:22 AM   #20
mmmcambelsoup
Merry Christmas!
IG: @Lucky_FatPat
Old 12-29-2014, 06:12 PM   #21
Calbee
Drives: B8 A4
how did you get the horn button onto the hub? i got a rapfix and a nardi and can't for the life of me put the horn button in
Calbee is offline   Reply With Quote
Old 12-30-2014, 01:25 AM   #22
mmmcambelsoup
I took out the metal ring with the notch that sits inside the quick release.. Then I used a flathead screwdriver to wedge the pins on the horn into the center. Fairly simple process when you take out the ring.
IG: @Lucky_FatPat
Old 12-30-2014, 10:09 AM   #23
mmmcambelsoup
Christmas week consisted of the new steering wheel install and a fumoto quikvalve. Surprisingly, with all the horror posts on here about steering wheel issues.. It was fairly simple and only took about 30-35min. First oil change for this car not done by the stealership, looking forward to using the fumoto in 5-7k.
IG: @Lucky_FatPat
GT86_PRAGUE (12-30-2014)
Old 12-31-2014, 05:41 AM   #24
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Those enkeis really compliment the silver ignition! Nice clean build!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
mmmcambelsoup (12-31-2014)
Old 12-31-2014, 11:06 AM   #25
mmmcambelsoup
iPhone 6 shot
IG: @Lucky_FatPat
The Following 8 Users Say Thank You to mmmcambelsoup For This Useful Post:
86geek (02-02-2015), dattran86 (10-14-2016), D_Thissen (05-01-2017), johnnyfast11 (01-28-2015), Koa (12-31-2014), lupindub (12-30-2015), NABoxer (03-22-2016), naticedog04 (01-04-2015)
Old 12-31-2014, 11:08 AM   #26
Koa
beauty!
The Following User Says Thank You to Koa For This Useful Post:
Old 01-01-2015, 01:13 AM   #27
Calbee
Drives: B8 A4
it seems like such a tight fit though. can't seem to get it
Old 01-01-2015, 02:11 PM   #28
mmmcambelsoup
Try putting in 2 clips first (1 being the bottom clip).. Then use a flat head to get the last pin wedged in. It'll fit, you just gotta mess with it. Good luck!
IG: @Lucky_FatPat
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 08:32 PM
BRZ series.blue/FRS Series 1.0 photos Johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-26-2014 12:23 AM
EFR series dabocx Forced Induction 32 11-20-2013 11:43 AM
FR-S Or FR-S 10 Series? Seattle_FT86 FR-S / BRZ vs.... 13 11-19-2013 09:16 AM
10 Series are Release Series kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 4 04-30-2013 09:23 AM
