#295 |
i'm sorry, what?
Drives: Canada
sorry I'm missing something
how are you accelerating at the same rate at half throttle as you are at full throttle? your first instance is the outside rear doing a small spinup as you've almost completely let off the gas (note that the TPS won't read below 20% for some reason) Maybe this was a surface issue? and the second instance is on the inside wheel, but you did stab the gas so I'm not too sure this is out of the ordinary? .. hmmmmmmmmm I don't know what to say :o
#296 |
crew chief
Drives: Race car FR-S
first one is the inside wheel, it is turning right, look at where the cursor is, blue line is right rear
the other one does spin under acceleration but it is still spinning... Have you taken data out of you car? It never read below 20%, i would guess this is because there is no iacv on this car and it controls the engine idle by keeping the throttle always above 20%. This is the TPS, not the throttle pedal. |
#297 |
crew chief
here is the difference between TPS and pedal position. This is an untuned car. Also, it is an extremely bumpy track so the uneven throttle is because modulation is very hard when the car is jumping a lot, being steady is impossible.
edit: just realised i didn't take the same lap as the previous printscreen but you can see it still does it in this lap (a little bit less though) and the rear swaybar was disconnected in this lap.
#298 |
crew chief
| The Following User Says Thank You to puma For This Useful Post: | Captain Snooze (11-11-2014) |
#299 |
crew chief
#300 |
i'm sorry, what?
Drives: Canada
my bad, I read the track map in the wrong direction.
and yes, I also have a solo DL and it annoys me that the TPS doesn't go below 20%, which to me sounds like a little too much for mere idle.. as the car idles with the throttle plate closed through a bypass valve/tube/hose/hole and if you plot your throttle application vs TPS you'll see a bit of delay.. also a bummer but again, we see a wheel spin with minimal throttle application in the first instance, you say that the track is bumpy, this could very well be the reason.. if the rear unloads the torsen stops working and you get spin
#301 |
crew chief
exactly, the lag is also something really annoying, look at the last portion of my last graph, you can see how the tps doesn't move with the pedal at all.
Also, it is true we get that a lot because of the bumpy track and the fact that my driver like to run on the curbs. I checked with an other track which is much smoother and we still had some inside wheel spin but not as much as this track. I think in our case the mechanical LSD would help with the tracks we are running with but i can see how this is not a mod needed for everyone like some were trying to debate. One thing is for sure, when we install a diff during the winter i'll make some new logs when we go test again. One thing that scared me when i looked at those data wasn't much about performance but about snapping axles with the violent drop in speed when the wheel touches the ground. I suppose the lsd should help with that and make the purchase of stronger axles unecessary. what do you guys think? |
#302 |
I'll give you guys something to think about
#303 |
i'm sorry, what?
Drives: Canada
5 G leteral load what the fuck?
also your accelerometer is set to record at a high frequency
#304 |
crew chief
i must admit i really don't know what i should be seeing as i don't see anything out of the extraordinary
the high G lateral is only because the DL wasn't calibrated, it's 0 must be somewhere in between the highest and lowest value |
#305 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
I'm looking at the steering (wheel?) angle and thinking...that looks like someone was having fun!
#306 |
#307 | |
Drives: GT86
Thanks! Is it possible to combine OSG with FD 4.88/5.1? |
#308 | |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 08:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 07:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 08:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 01:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 12:49 PM |
