Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
12-14-2014, 11:29 PM | #1 |
Drives: 2015 Scion Fr-s
More HP?
What can i do to make my frs faster? It only pulls 200 hp ! Cold air intake or a chip? The frs is a drift machine but i think it needs more hp!
Thanks for the help |
12-14-2014, 11:49 PM | #2 |
Drives: In between cars... 2018 Ninja 1000
Obvious troll is obvious. Please go away.
12-14-2014, 11:55 PM | #3 | |
Drives: white subaru brz
Step 1: Go to ford dealership Step 2: Trade car in for Ford Mustang Gt Step 3: Delete your account on ft86club |
The Following 17 Users Say Thank You to jdmblood For This Useful Post: | Arcadien Angel (12-15-2014), billyk (12-15-2014), Braces (12-15-2014), El Guapo (12-15-2014), Frers (12-17-2014), Koa (12-15-2014), Mad1723 (12-15-2014), Mr.Impreza (12-15-2014), Quentin (12-15-2014), Rampage (12-15-2014), raven1231 (12-15-2014), rs999 (12-15-2014), shifter907 (12-15-2014), STV3 (12-15-2014), Tcoat (12-15-2014), tennisfreak (12-15-2014), x1UP (12-15-2014) |
12-15-2014, 01:01 AM | #4 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Serious answer - Header + Tune + E85
Non-Serious answer - AWD Turbo LSX Swap with a Motec System Exhaust and a NOS Frogger System. |
The Following 3 Users Say Thank You to Wise For This Useful Post: |
12-15-2014, 01:05 AM | #5 |
NOS
The Following User Says Thank You to funwheeldrive For This Useful Post: | Mr.Impreza (12-15-2014) |
12-15-2014, 01:18 AM | #6 |
Drives: Raven
These stick on vents are the best bang for the buck. DIY is simple and straightforward. Peel the tape back and slap it on under the 86 piston. You get about +100hp PER addition, this means you can get +100 hp to your rear right wheel and another +100hp to your rear left wheel if you decide to put one on each end. Be careful if you only put one on. That side will be pushing twice as much power as the other wheel. On a more serious note, if you bought this car for HP, I think you got the wrong car. There are definitely many more cars that are better for the $ if you care for HP+Drifting.
The Following 2 Users Say Thank You to 艾洛 For This Useful Post: | Mr.Impreza (12-15-2014), rs999 (12-15-2014) |
12-15-2014, 01:19 AM | #7 |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
The Following User Says Thank You to Apoc For This Useful Post: | raven1231 (12-15-2014) |
12-15-2014, 01:19 AM | #8 |
Drives: 2005 Toyota Camry
12-15-2014, 01:24 AM | #9 |
Drives: Raven FRS/c5 Corvette
get out of your car and push it
The Following User Says Thank You to Obja For This Useful Post: | campy (12-15-2014) |
12-15-2014, 05:55 AM | #10 |
Drives: Red BRZ
Lost my shit @ NOS frogger system.
12-15-2014, 06:35 AM | #11 |
Drives: Toyota GT86 Aero 2012
There is this new thing out now, It adds 5 hp without even touching your engine!
If you decide to try this, plea let us know if this is a hoax or not! Ty.
-2012 GT86 Aero
12-15-2014, 07:59 AM | #12 |
Remember
Drives: 2015 Asphalt
For ultimate weight reduction, remove yourself from the vehicle for best results.
This is my 17th car. Most fun so far!
The Following User Says Thank You to Defuser For This Useful Post: | rs999 (12-15-2014) |
12-15-2014, 08:21 AM | #13 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
The Following User Says Thank You to themadscientist For This Useful Post: | D_Thissen (12-15-2014) |
12-15-2014, 08:49 AM | #14 |
Drives: 2015 Scion FR-S 6MT
Are you running on race gas? Anything less than 110 octane and the engine limits itself to 200hp for reliability and safety reasons. I suggest buying some 114, after you burn a couple tanks of that the ecu should realize that it's race fuel and it will unlock the secret beast mode level fuel/timing maps. That'll give you about 300hp and push the torque through the roof. After using race gas for 1337 miles do the pedal dance and then start filling up with nitromethane whenever the low fuel light comes on. But don't fill it above a quarter tank or you'll be adding to much weight. Once you've achieved a minimum ratio of 88% nitromethane and 12% race gas you should see the power jump to almost 600 horses (although the technical measurements were given in MLPP or "my little ponies power", 600hp is the approximate conversion). If you are still not happy with that you'll need to add a straight through exhaust system for +60hp and a cold air intake for +90hp.
The Following 3 Users Say Thank You to Amaya For This Useful Post: |
