#2227 | |
Here's some confounding variables for your comparison. - Hoosiers have FAR FAR higher rolling resistance, resulting in less acceleration - Hoosiers are lighter than most street tires, resulting in less rotational inertia - Alignment data on the two cars is unknown; toe has a large effect on acceleration - Wheel data is unknown; sunk wheels generate less drag, which is significant at the speeds you are going. Lighter wheels are less inertia. Based on the dyno numbers, I'm gonna guess that the rolling resistance of the hoosiers resulted in less acceleration. |
#2228 |
Drives: '22 BRZ
I don't see how OFT is missing anything that's really that relevant for track use vs any other tuning solutions. I'm not going to take this thread off topic, but I thought you had some sort of valuable input on this that I was missing.
#2229 | ||
#2230 |
Drives: '22 BRZ
#2231 | |
Unfortunately, I cannot ask you to do anything more than take my word for it, since I will not provide the tangible evidence you see. My history of providing sound feedback is all I can provide, as well as the fact that CSG sells neither Ecutek nor OFT. If you choose to use OFT, then best of luck to you. I dislike EcuTek, but it is , quite unfortunately, the best tuning solution currently available. I'd much rather have something akin Cobb AP or Hondata FP. |
#2232 | |
Drives: '22 BRZ
If I was racing the car I'd go with a standalone ECU and replace the factory ABS while I was at it.
#2233 | |
#2234 |
Drives: '22 BRZ
#2235 | |
As another data point, I can say just comparing with my own car, I gained 1-2 mph on the back straight at Shenandoah going from stock --> OFT stage 1 (went from peak 103-104 mph --> 105 mph consistently). I reflashed in between track days so the conditions were roughly similar. I'm interested what going to stage 2 netted me, maybe another 1-2 mph. Will find out next spring
2022 BRZ Build 2013 FR-S Build |
#2236 |
Drives: 2016 FR-S
I've stayed away from R-comps for the same reason. I've been using AD08's and RE11's and even with these tires I've found that the Xp12s last about 4 track days; which isn't horrible, but not great. Brake feel and fade are fine; I do have brake ducts. I will try a set of Cobalts to see if they last longer, but, I'm very close to pulling the trigger on bigger heat sinks...
#2237 | |
Let us know when you want a BBK! Put it this way. The CP8350 version of the XP12 is 7 bucks more for around 80% more pad. 7 bucks! |
#2238 | |
Drives: '23 BRZ Limited
Yikes. Yeah on the Miata we put 10 sessions on the car in one day with XP10/8 combo, I don't think you could measure the wear on them at the end of the day. |
#2239 | |
Drives: 2004 Toyota RAV-4 5M
Here's the video: While it isn't a very scientific measure of power, I'd say it's a fairly safe bet that @DarkSunrise had a higher top speed and delta than me was due to his power advantage. Keep in mind that I'm pretty sure I was also braking later than Dark. I had dyno'd my car on the same dyno that he did and got ~185whp so I wouldn't be surprised if Dark's car is putting out somewhere in the low 190's or more. I'm not trying to say the OFT tune will get you more power, not at all. I'd bet the main difference came down to Dark having a header+other exhaust mods while I was totally stock exhaust and just a drop in filter. It will be more interesting once all the parts I've ordered come in (GrimmSpeed intake and JDL EL Header/overpipe/frontpipe+HFC, stock cat back though as it doesn't really add any power and my car is already underweight for TTD). Hoping to be well over 200whp with those mods. |
#2240 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
I now have a Kraftwerks C38 blower on my car with the Skunk2 oil cooler tuned at 10psi. I don't go lapping much maybe 2-3 events each summer, and its generally cooler up here in Canada for lapping days (25 degrees Celcius). Should I seriously be looking for a aluminum radiator for the coming year?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
