Old 12-03-2014, 08:57 PM   #309
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Hey Tyler,
KEY!S looks great!!! The TEQ emblems compliments it well!
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
TylerLieberman (12-04-2014)
Old 12-04-2014, 09:50 PM   #310
2015firestormFRS
Drives: 2015 firestorm scion FRS
Originally Posted by TylerLieberman View Post
Well I just got back home and haven't gone to any events since I've been back. I will use the TEs at events for sure but I'm also going to get another set of wheels that'll be dedicated track spares so I'm not thrashing these wheels apart. The TEs will stay on up front 100% of the time. TEs or spares will run on back for events
Cool man, I love your build. I'm planning on getting stance coils this spring, but I'm up in the air about wheels. Would a 215/45 be too narrow for like 17x9 rpf1 or should I stick to 17x8? I plan to start attending drift events next spring also
2015firestormFRS is offline   Reply With Quote
Old 12-04-2014, 10:19 PM   #311
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
It's up to you on what size wheel you want to run. 17x8 and 17x9 can both be run with a 215 width tire. The 9j wheel is pretty wide for a 215 though so the tire will be stretched. Just comes down to what you want to run.
This was 17x8.25 with 215/45 on it.
This was 17x9 with 215/45 on it.
Both had zero issues with clearance and I was able to use full lock without any serious rubbing. Only time it rubbed was at full lock over bumpy surfaces because of the ride height.
Other stuff happened today..
Got my package in from Touge Factory
Also got my Grimmspeed intake from @xDanger_208x and installed it. Since I bought it used from him and all the rubber trimming had already been installed to the box, the full install seriously took me all of 30 minutes. Big thanks to him
Made a very slight difference from like 4.5k to 7k. Very slight. Just enough to notice a difference. Definitely a little more grunt but the real difference will be noticed I'm sure once the header and tune get thrown on the car.
Just waiting for my exhaust to come in now...
The Following User Says Thank You to TylerLieberman For This Useful Post:
xDanger_208x (12-04-2014)
Old 12-05-2014, 02:47 PM   #312
2015firestormFRS
Thank you very much, I appreciate all the advice. I can't wait to see how the header and tune turn out. I'm planning on keeping mine n/a
I came from a 96 civic hatch I had built for 4 years and daily drove. I used it to carve mountain roads in the Appalachian foothills where I live. The motor was stock but I rebuilt and replaced every single bolt of the rest of the car and over hauled suspension and brakes. This is my first serious FR and I'm in love with this chasis.
Not trying to thread Jack, just sharing my old passion for grip driving lol
The Following User Says Thank You to 2015firestormFRS For This Useful Post:
SciOnDrifTtSlIdeR (12-29-2014)
Old 12-06-2014, 03:18 PM   #313
TylerLieberman
Drives: '24 GR86
No worries lol. I've actually been thinking about taking the car to an event up north at Hallett and do some actual road course driving. It's been a long time. Not sure if I want to sink more money on different stuff though lol.
I actually had every intention of going with turbo or supercharger but the car is my daily driver and it's just too easy right now. I have just under 13k miles on the car. I've done a cross country trip, 5 drift events, and lots of hard driving, and all I've had to do is change oil/fluids. It's such a reliable car right now and I don't want to mess with that too much.
It just REALLY needs some extra grunt. I figure with the intake, headers/exhaust, and tune, I should be able to pull an extra 30ish whp out of the car which is a decent little bump. Maybe down the road when I have a different daily, I'll consider boosting this-if I still have it.
The zn6 is a great car from the factory. Just a blank sheet of paper for you to do whatever you want with. It has it's flaws but I'm pretty content with the car now at this point.
All that I have left for it is:
-Tune
-FLCAs
-Tie rods
-Subframe bushings
-Swift springs for coilovers
and I'm done. Maybe a BRIDE seat and brake upgrade down the road, but everything listed above will be addressed after winter. Plus, I still have parts sitting in the garage I need to install lol.
Old 12-07-2014, 07:55 PM   #314
2015firestormFRS
^thats awesome, I daily drive mine too to work and I've got 77XX so far, bought it in July. A friend that is sort of a local legend, has decided to bring his hatchi roku out of retirement and get back into the drifting ring. He's been doing it for a looong time and we all got a message on facebook this week to get ready for spring season. I was planning on going coilovers, but I think I may just invest in tires, fluids, and event fees(he will be able to get those reduced for us.). I'm afraid if I lower it the axles won't hold up.
Old 12-07-2014, 08:04 PM   #315
TylerLieberman
Drives: '24 GR86
Axles aren't really too much of a worry unless you're:
a. Running lots of power
b. Running lots of grip
c. Slamming your car to the ground
Or any combo of the 3. If the car is kept at moderate power levels and the grip levels aren't crazy and the ride height is kept reasonable, you shouldn't have any real concerns. Especially with just normal driving.
If you're going to drift the car, then the same applies. I haven't had any issues since my first axle that went but my car was a bit lower and more grippy. I just raised the car a tad and ran a higher rear tire pressure and since then, no issues. These axles have been going for over 10k miles too with loads of track time.
Old 12-07-2014, 10:41 PM   #316
2015firestormFRS
Awesome, thanks alot man for all the info I really appreciate it a lot. Also thanks for your service, my father is retired air force.
Old 12-09-2014, 02:57 PM   #317
TylerLieberman
Drives: '24 GR86
No problem, man. Always glad to try and help other people out.
Thanks for the support as well. Tell your Dad I say thanks as well. My grandfather is retired AF as well.
On the flip side... my classes start tomorrow. Goodbye to my free timelol
...worth it though
Old 12-09-2014, 05:44 PM   #318
2015firestormFRS
Oh yeah, one more question, in those pics you posted a few posts back with the 527's (I plan to get the same ones in white) how much were you lowered in those pics? Also how was your axle angle and do you think SPC lca's will be mouth or should I get stance LCAs?
Old 12-09-2014, 10:06 PM   #319
TylerLieberman
Drives: '24 GR86
I can't remember how much I was lowered but I was pretty low. I had SPC LCAs too and I think I only had like an inch of adjustment left on the rear coils. I know I was hitting the bumpstops a bit over really bad surfaces. The axle angle on these cars get pretty bad when you lower them. Mine were at a pretty decent angle before with that setup. After switching to Stance LCAs and raising the car a bit, the axle angle is not as bad and I also have over 2 inches of adjustment left on the rear coilovers.
I would honestly spend the extra for the Stance LCAs. They lower the mounting point by an inch and the aurora rod ends are top notch. Well worth the money.
Also, I went out today and took pics that don't suck so much cause they were taken on an actual camera instead of a damn phone
The Following 7 Users Say Thank You to TylerLieberman For This Useful Post:
10Stars (12-19-2014), Carlos_M (12-10-2014), illest86 (12-10-2014), ISDriven (12-11-2014), mmmcambelsoup (10-07-2015), srizzors25 (12-10-2014), Tye300 (12-10-2014)
Old 12-10-2014, 02:27 PM   #320
2015firestormFRS
That looks amazing.
TylerLieberman (12-10-2014)
Old 12-10-2014, 05:28 PM   #321
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
Like a stealth fighter.
Carlos_M is offline   Reply With Quote
The Following User Says Thank You to Carlos_M For This Useful Post:
Old 12-10-2014, 05:33 PM   #322
illest86
Yeah I'm all over that duckbill.
Great choice(s).
illest86 is offline   Reply With Quote
The Following User Says Thank You to illest86 For This Useful Post:
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 03:09 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Five Axis Spoiler - Painted "RAVEN" Black that_guy Canada Classifieds 29 12-18-2012 09:34 AM
