Old 12-08-2014, 02:16 PM   #1
bellison13
Bellison
Drives: 2013 Whiteout FR-S
Clutch engaging in NEUTRAL!!! Toyota hasn't solved it yet...
Has anyone else had this issue?
Cold start...and it has to be pretty cold out...but cold start, let clutch out, RPMs drop 200-300 and in neutral she pulls forward a few inches. Put clutch in and RPMs raise back up..let out and they drop... When it first happened I felt it just bump the ebrake some...but when I put the ebrake down the car actually pulled forward a few inches. Once warmed up there is no issue and no pull. Car has been with toyota for almost a week now with no answer yet as to why.
Any help is appreciated! Thank you!
bellison13 is offline   Reply With Quote
Old 12-08-2014, 02:18 PM   #2
radroach
Drives: car
Why would the car move forward in neutral. Something doesn't add up. Make us a video.
Old 12-08-2014, 02:23 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
In a manual trans, there are parts rubbing against each other even with the engine in neutral.
The drag for the oil (which is worse when cold) will exert some torque on the gears even when they are not engaged.
This is in the needle bearings between the gears and the drive shafts.
This is normal.
Now if you said it was doing that with the clutch disengaged then you have a problem.
If you start a man trans car in neutral on jackstands, the wheels WILL begin to spin up but you can stop them with just your hands.
The Following 2 Users Say Thank You to stugray For This Useful Post:
DieselDog (12-09-2014), kevman_101 (12-08-2014)
Old 12-08-2014, 04:07 PM   #4
kevman_101
Drives: 2013 Scion FRS
This is normal.
It`s normal. Don`t sweat it.
kevman_101 is offline   Reply With Quote
Old 12-08-2014, 07:45 PM   #5
Ozzman
Drives: old
Just exactly how cold are you talking about. A 2-300 rpm drop when releasing the clutch in neutral is not normal, and there should never be enough friction in the system to move the car on flat ground in neutral.
Ozzman is offline   Reply With Quote
Old 12-08-2014, 08:12 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
This is normal.
[ame="https://www.youtube.com/watch?v=Y_VcwWjFf-4"]Exhaust note comparison - stock vs Tomei Expreme 80R - YouTube[/ame]
for a visual representation of this.
-alex
axelo (12-08-2014)
Old 12-08-2014, 08:51 PM   #7
Akari
Drives: 2013 DGM BRZ
That doesn't sound normal to me. Sure there is still a bit of friction, but friction from fluid shouldn't be enough to move thousands of pounds of car forward. On jackstands you can see there is normally so little force that you can stop a wheel with one hand.
Akari is offline   Reply With Quote
Old 12-08-2014, 09:18 PM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
This is 100% normal.
Old 12-08-2014, 09:25 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I'm so confused by all the details in this thread
Old 12-08-2014, 10:18 PM   #10
mav1178
mav1178's Avatar
What oil are you running in the car?
What clutch do you have?
How cold is "very cold" at startup?
Seems like your fluid is causing some type of excessive drag on the input shaft, which is making your RPMs lower when the clutch is engaged with the flywheel.
The armchair mechanic in me thinks your transmission fluid is too thick for your temperature range.
-alex
DocWalt (12-08-2014)
Old 12-08-2014, 10:22 PM   #11
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
-alex
Exactly. If I leave my track gear oil in over the winter and start it up on stands I can't grab the wheel and slow it down unless I want a finger taken off.
I have a feeling the OP has OEM fluid, which slightly surprises me that the car physically moves, but who knows.
Old 12-09-2014, 01:23 AM   #12
Perfectly normal. All of my cars have done it in cold weather - significantly below freezing. This is a pretty light machine.
Old 12-09-2014, 01:43 AM   #13
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
What you are experiencing is normal
Even though many have said it already.
DieselDog is offline   Reply With Quote
clutch, transmission
Clutch popping when engaging pedal & Car off -- SOLVED 86-tundra Issues | Warranty | Recalls / TSB 97 09-29-2014 12:28 PM
Shuddering noise when engaging clutch Lido Issues | Warranty | Recalls / TSB 15 04-11-2014 10:46 PM
Thud when engaging 1st anyone else? earthsscum Engine, Exhaust, Transmission 47 06-13-2012 08:26 PM
Xtreme Clutch Upgrade for the Toyota 86 & Subaru BRZ Xtreme_Clutch Transmission and Driveline 0 06-13-2012 04:58 AM
Why hasn't the FR-S shown up on the 'build your Scion'? Chenslee Scion FR-S / Toyota 86 GT86 General Forum 3 05-04-2012 10:35 PM
