Old 11-30-2014, 04:11 AM   #113
rx3
Originally Posted by emirdtm
I got my wheel installed with a works bell 540s hub and a NRG quick release and now my track and ABS light is on and my traction control and ABS doesn't work just perfect for winter time. What are my best options to fix this I tried disconnecting the battery for 10min and took it to a few dealers to reset the ECU they didn't Evan want to come close to the car like its a ticking time bomb lol o man so what are the first things I should check for thx.
First make sure that the connector of the steering angles sensor (doughnut shaped black plastic part where the cable of the cruise control etc. is connected to) is top center when the wheels are straight. Otherwise you will have this exact error.
rx3 is offline   Reply With Quote
The Following User Says Thank You to rx3 For This Useful Post:
emirdtm (11-30-2014)
Old 11-30-2014, 04:31 AM   #114
rx3
Here's a picture of my aftermarket wheel with a cruise control bracket:
http://www.ft86club.com/forums/showthread.php?t=78397
In the second picture of this thread you see the connector which needs to be top center. http://www.ft86club.com/forums/showthread.php?t=56868
Old 11-30-2014, 11:38 AM   #115
emirdtm
Drives: Toyobaru
Thank you so much man i will check it out.
emirdtm is offline   Reply With Quote
Old 12-01-2014, 07:40 PM   #116
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Hey everyone check out the "Damd" steering wheels we have on group buy! They allow you to retain the OEM airbag just like the Cusco one. They are made in Japan as well and have a couple different styles to choose from.
http://www.ft86club.com/forums/showthread.php?t=77798
Kami Speed is offline   Reply With Quote
Old 01-28-2015, 08:42 PM   #117
JoeBro
JoeBro's Avatar
Drives: Scion FR-S
So from what I've read, the nrg short hub needs modifying to work properly, what do you mean by modifying? I bought the hub thinking that it would work then found this thread and noticed everyone uses the work bell hub...
JoeBro is offline   Reply With Quote
Old 01-29-2015, 09:43 PM   #118
Blizzard
Drives: '13 FR-S Whiteout
I replaced my fr-s clockspring due to me being an idiot. The original clockspring had part #83111CA20 on it. The new clockspring part #83196CA010 from a subaru parts store (since the sticker on the original clockspring had a subaru logo on it). I was hoping the dealer could reset my traction and ABS lights when I put in the new clockspring, but they said the steering angle sensor code wont go off. Took it apart and all the sensors are plugged in correctly. Clockspring is centered. My question: are there different clocksprings for the two cars? Why is this happening?
Blizzard is offline   Reply With Quote
Old 01-30-2015, 01:26 PM   #119
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
I screwed up my clock spring SUUUPER bad, but I ghetto rigged it back into the column, put resistors in the airbag sensor, and I am good to go. I didn't want to deal with having to buy something new, or going to the dealer. I'm too lazy for that haha,
gl2filmerguy is offline   Reply With Quote
Old 02-10-2015, 04:20 PM   #120
jaime3
jaime3's Avatar
Drives: Scion FR-S
is there a DIY link to putting on the resistors to get rid of the trac/abs light problem?
jaime3 is offline   Reply With Quote
Old 02-10-2015, 04:46 PM   #121
gl2filmerguy
Thats your clock spring that causing it. Make sure it's centered.
Old 02-10-2015, 05:54 PM   #122
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
Here's a pic of my resistors on the connectors - assuming you have a WORKS bell hub. Blue to orange. Black to black.
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
Old 02-12-2015, 05:42 AM   #123
jaime3
jaime3's Avatar
Drives: Scion FR-S
i have a nrg hub and quick release. where can i get resistors if i dont have WORKS
Old 02-23-2015, 10:17 PM   #124
adamg
Drives: brz
Works bell hub with Nardi 340mm wheel
adamg is offline   Reply With Quote
Old 03-25-2015, 10:30 PM   #125
jaime3
jaime3's Avatar
Drives: Scion FR-S
As i read through this thread i realized that no one has been able to know how to modify the nrg hub to fix the light issues. Does anyone with an NRG hub accomplished a problem free nrg hub set up?
Old 04-07-2015, 05:11 AM   #126
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Just a heads-up, Works Bell doesnt seem to provide the resistor for the black terminals coming off of the airbag. I installed the 540 tonight and immediately got an airbag light. Heading to Fry's to get the parts to make it on my own. Also, i had to cut-off the tabs on horn of my Sabelt wheel to make it fit. Not sure if those with by the "Short" version had these issues, as i chose the regular size.
Side tip, no where in my japanese instructions did i see a picture for repinning the harness coming off the cruise control. I opted to keep mine so i dont lose the option to switch maps with my ecutek tune. Flip over the supplied harness (has two red wires), take a micro-flathead and pop-up the clip. This clip is what keeps the pins in. Remove the two red wires from the harness and set aside. Proceed to do the same off the OEM harness, remove ONLY the blue wire. Feed the red wires to the corresponding locations from the supplied harness. One red wire will replace the blue one you removed, and the other will go on the opposite end. Snap the clip back in and give the wires a gentle tug to make sure they're secure.
Plug the harness back in and feed the wires per instructions. I ghetto rigged the cruise control stalk onto the backside of the hub for now, need to fab a better piece to make it clean.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 01:56 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 09:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 11:43 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 07:17 AM
