Old 11-26-2014, 08:14 PM   #225
Buurz
Drives:
I haven't had them on in a sunny day yet, today was the first day I've had them and it was sunny so here are two more
Sorry for triple post
Sent from my SAMSUNG-SM-G900A using Tapatalk
Buurz is offline   Reply With Quote
Old 11-26-2014, 11:19 PM   #226
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Buurz View Post
Figured with the caster being 6.2° I'd have enough lean on the tire during cornering that I wouldn't need more camber.
No rubbing as of yet, however I have the Öhlins coilovers so I can easily change the alignment if I need to with the camber plates
Nope. Unless your cornering speeds are 3-5mph... I'd go -1.8 camber up front minimum... I'll end up around -3.2 I think, but may have a different end goal than you. I'm still making sense of this platform so I could be off, but ...
Is that straight up yellow or is it a touch green? I had a NYG Neon for years and still have a soft spot for that color. I like the look. I've fought about the OZ green for my BRZ...
Old 11-26-2014, 11:26 PM   #227
Buurz
Drives:
Haha yeah I take tight offramps about 70-90mph, going back on the alignment rack soon though.
Going to get it to -1.8, that's seemingly everyone's preferred setup
Old 12-28-2014, 02:43 AM   #228
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
tigermack is offline   Reply With Quote
The Following 8 Users Say Thank You to tigermack For This Useful Post:
akahenry (02-12-2017), HatchetBurial (01-07-2015), JMon85 (10-13-2017), Keenercarguy (03-30-2017), ryann.mendoza (02-19-2018), spicyricecake (10-06-2015), sprintertrueno86 (02-01-2015), tahdizzle (01-02-2015)
Old 12-28-2014, 04:02 AM   #229
Buurz
Drives:
Oh wow I didn't even see a question at the end.. It seems a touch green sometimes in a specific lighting, but it is mostly fluorescent yellow. I believe that the undercoat is white so it is more bright yellow than yellow-green I think it'd look even greener at certain angles if the undercoat was black based.
Thanks for the input on camber, I might get it to about -1.5 or so.. With the Öhlins you can't really lower much so I know that I'm not going to have to do crazy camber because as it sits, it's a tad lower than Öhlins recommends.
Old 01-01-2015, 09:11 PM   #230
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Is this paint or powdercoat?
hamlet is offline   Reply With Quote
The Following User Says Thank You to hamlet For This Useful Post:
Buurz (01-01-2015)
Old 01-01-2015, 10:49 PM   #231
Buurz
Drives:
It is powdercoat, I ordered on evasive and they send the wheels to whoever they use, and then ship them out when finished.
Old 02-01-2015, 11:42 PM   #232
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
ApolloSki is offline   Reply With Quote
Old 02-03-2015, 07:17 PM   #233
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Got my wheels in and on my car
What tire size you running?
SG02WRX is offline   Reply With Quote
Old 02-03-2015, 09:26 PM   #234
Buurz
Drives:
I have 245/40 Bridgestone Potenza RE-11A on there, Bridgestone tires run wide for the size so they aren't really stretched, a thing that I like about my setup
The Following User Says Thank You to Buurz For This Useful Post:
SG02WRX (02-04-2015)
Old 02-07-2015, 01:02 AM   #235
Buurz
Drives:
Here are some more... So the wheel design is simple to clean but anyone considering bright wheels... Gotta keep on cleaning them to keep them clean OMG
I have been cleaning them like every three days and I do pull the wheels off to clean the inside barrels easier.
Old 02-26-2015, 12:01 AM   #236
shifter907
Lurker
shifter907's Avatar
Drives: '14 BRZ Ltd 6MT
245/40 Sumitomo HTR ZIII's, Parts Shop Max coilovers, Stance Rear LCAs
Instagram : @brampbell_candon
Facebook : Hipster Vision Photography
shifter907 is offline   Reply With Quote
Old 03-19-2015, 02:03 PM   #237
androopoo
androopoo's Avatar
Drives: 2014 Lighting Red BRZ
does anyone have photos of these in the hyper silver color?
androopoo is offline   Reply With Quote
Old 03-19-2015, 03:21 PM   #238
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Yeah, it's like all over the thread...
dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport
Wedssport TC105N 17x9+25 5x100 YDNA Wheels and Tires 24 04-04-2014 02:05 PM
FS: Wedssport TC105n 17x9 +25 donutfilling Wheels and Tires 19 03-26-2014 07:59 PM
Wedssport TC105N 17x9 and 17x8 donutfilling Wheels and Tires 9 09-27-2013 05:04 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 12:49 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
