CANADA Canada
Old 11-26-2014, 04:27 PM   #7071
jvincent
jvincent's Avatar
@Pbrown maybe they will confirm the Supra launch before the spring, in which case you can put all of that money towards the down payment.
The Following User Says Thank You to jvincent For This Useful Post:
jhx741 (11-27-2014)
Old 11-26-2014, 05:10 PM   #7072
Pbrown
Drives: 2013 Scion FRS Raven
LOL! I need to know by June 6th, 2016. I was looking at the videos of the car over the weekend and there is no way in it's current form it will be under 70 k especially if the engine is over 400 horse. Stunning vehicle for sure.
Pbrown is offline   Reply With Quote
Old 11-26-2014, 05:28 PM   #7073
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by normancw View Post
So, what mods (performance and cosmetic) are you guys planning over the winter? Another carbon lip Ken?
Super-secrat track mods.
Slick is offline   Reply With Quote
The Following 3 Users Say Thank You to Slick For This Useful Post:
FRS_Ken (11-27-2014), normancw (11-26-2014), Pbrown (11-26-2014)
Old 11-26-2014, 07:41 PM   #7074
normancw
normancw's Avatar
Drives: 128i
Originally Posted by HeadBanger View Post
Lowering springs. - hey Norm, yours still available?
Yep - Eibach ProKit. With the springs and the $7 crash Subaru bolts to give you more camber and you'll be set for the track suspension wise! The drop is a bit less than 1"
The front ones just need to be removed from the OEM struts - I don't have a spring compressor.
You can have them if:If I can find the crash bolts, you can have those as well (not sure if they can be used more than once).
However I'll bring my car into Subaru about my trans issue first.
What's wrong?
normancw is offline   Reply With Quote
Old 11-26-2014, 07:47 PM   #7075
normancw
normancw's Avatar
Drives: 128i
Question
Originally Posted by Pbrown View Post
2015
wire harness
Why?
Old 11-26-2014, 07:48 PM   #7076
normancw
normancw's Avatar
Drives: 128i
Originally Posted by Chico View Post
Already picked up my first mod(s) for next summer, just need to get them mounted at Slick's place. Also planning on OFT tune/header and hopefully I'll stop there, but probably not.
You have excellent taste!
The Following 4 Users Say Thank You to normancw For This Useful Post:
Chico (11-26-2014), FRS_Ken (11-27-2014), Mike86CelicaGTS (11-27-2014), pushrod (11-26-2014)
Old 11-26-2014, 08:09 PM   #7077
normancw
normancw's Avatar
Drives: 128i
Planning on doing a water-oil cooler for sure. Haven't decided which of the plumbing options (throttle body, Cusco-like, Forester) to to with yet.
I will also probably do an OFH. There is a place in town that does ceramic coating (RLD) if it isn't too outrageous, I'll probably get it ceramic coated.
Edit: Forgot that I will also be adding the Perrin steering rack bushings.
Outside chance I will do some suspension stuff as well.
Let me know how much it costs.
Old 11-26-2014, 08:12 PM   #7078
jvincent
jvincent's Avatar
Will do. I sent them email today so I should hopefully hear back this week.
Anyone else interested in case there is group pricing?
The Following 3 Users Say Thank You to jvincent For This Useful Post:
Chico (11-26-2014), normancw (11-26-2014), Pbrown (11-26-2014)
Old 11-26-2014, 08:41 PM   #7079
Pbrown
Why?
recommended by Vortech at time of install along with new plugs, 18 months out and I'm already studying the install guide. Need a life.
The Following User Says Thank You to Pbrown For This Useful Post:
Old 11-26-2014, 08:43 PM   #7080
Pbrown
Ditto for me as well
Old 11-26-2014, 09:29 PM   #7081
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
I have a few things lined up, but I'm spending all my mod money on purchasing a new camera
I need a cheaper hobby.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 11-26-2014, 09:54 PM   #7082
Chico
Drives: '14 BRZ WRB
You're fast enough, Andre. No need to get more mods.
Chico is offline   Reply With Quote
The Following User Says Thank You to Chico For This Useful Post:
Old 11-26-2014, 10:03 PM   #7083
Chico
Drives: '14 BRZ WRB
How much of a difference did you notice switching from this setup to your coilovers?
I'd be interested as well. Thanks!
Old 11-26-2014, 10:34 PM   #7084
normancw
normancw's Avatar
Drives: 128i
It was a huge difference, but I changed a lot of other suspension things at the same time (steering rack bushings, rear subframe inserts, rear sway bar, wheels/tires, caster/camber plates, rear LCA, front camber from -2.0 to -3.3). I did notice the damping was much better.
The Following User Says Thank You to normancw For This Useful Post:
Chico (11-27-2014)
