| Software Tuning Discuss all software tuning topics. |
#15 |
Junior
Drives: a car
The thermal efficency of an engine is pretty static when its built, thus it can be as efficient as it can given the ideal conditions (right AFR producing the hp they want), the milage will be dictated by the amount of fuel flowing into the engine which is controlled by your foot. Youll have an easier time regulating gas milage with your foot, than remapping and retarding the engine.
#16 | |
| The Following User Says Thank You to Koa For This Useful Post: | cdrazic93 (11-26-2014) |
#17 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You can get a 10-20% improvement altering the factory ECU. With direct injection, you can run some absurdly lean mixtures like the lean burn motors from the 80's did (think 16+ AFRs).
But they definitely would be less than ideal for emissions, so you won't find it from an OEM. Probably not the best for the catalytic converter either. But yes, it can be done. We toyed with it for quite some time and found about a 15% improvement on pump and e85. While legalities prevent us from offering this, if you're using a DIY platform, you should be able to extract several more MPG with the right approach. |
| The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
#18 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I removed the proprietary pictures of the VVT tables, but you can check them yourself by opening them in RomRaider.
Last edited by KoolBRZ; 11-27-2014 at 05:15 PM. Reason: removing proprietary pictures |
#19 |
Drives: UK GT86
.: Stealth 86 :.
| Does Turbo effect gas milage?? | beesmiff07 | Forced Induction | 86 | 10-30-2014 11:25 PM |
| WTB: FRS/BRZ high milage | cools20 | Cars for Sale/Trade | 0 | 10-13-2014 02:10 AM |
| Circuit Motorsports Tuning - EcuTek/RaceRom - New and Improved! | Circuit Motorsports | Software Tuning | 7 | 05-20-2014 03:26 PM |
| At what milage did your OEM tires start to lose grip? | Liquidsnake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-18-2013 06:38 PM |
| Milage App. | execoll | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-14-2012 01:23 PM |
