Old 11-23-2014, 03:46 PM   #1
ganz954
ganz954's Avatar
Drives: Subaru BRZ MT WR Blue
rom tuning for improved gas milage
My goal is to create a rom that will give 10%-15% mileage increase.
Im not looking for performance here I just want to see if it is possible to achieve that. Dont care if the car is slow as a Prius.
Anyone have a clue how to achieve better gas mileage?
What tables should I start looking into?
ganz954 is offline   Reply With Quote
Old 11-23-2014, 04:17 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
What tuning method, ECUtek or RomRaider?
I guess you could change the O2 sensor scale to read richer and therefore make closed loop operation be leaner. Having not looked into mileage tuning I wouldn't know how to adjust the timing although from memory you'd advance the timing a little.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2014, 04:45 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Don't expect any big gains for improving fuel economy without hurting performance. The factory a pretty good job in this respect. The problem with leaning the AFR target at cruise is that you will also see a loss in engine torque which will require more throttle which will then meter more fuel and you are back to square one. You can problem get some minor gains by leaning AFR slightly and then adding a small amount of advance (2-3 deg) at cruise conditions. The factory couldn't get away with these changes due to emission constraints (primarily NOx emissions concerns). But the effects on mpg would be small and take some very controlled testing to quantify. Probably too controlled to street driving.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
flippy (11-24-2014)
Old 11-23-2014, 07:18 PM   #4
ganz954
ganz954's Avatar
Romraider is my tuning method.
I have a stock car.
Ill try both of your suggestions and go from there.
Old 11-24-2014, 12:07 AM   #5
shif7i7down
Erected Member
Drives: frs
You 'll Have better luck with a 3.7final drive swap if you want that 10~15% mpg increase
shif7i7down is offline   Reply With Quote
Old 11-24-2014, 02:53 AM   #6
steve99
Drives: FT86
I got slightly better milage after installing OFH catless header suspect due better low end torque, but you have to drive very sedatly to achieve good economy in city.
Old 11-24-2014, 10:57 AM   #7
ganz954
ganz954's Avatar
@shif7i7down, I was going to swap out to a 3.7 final drive in a couple of years from now once I had a turbo installed. It seems like a good option to do it now and don't worry about the tune and just flash OFT rom files.
Old 11-24-2014, 01:22 PM   #8
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
I got better mileage with the OFT Stage 1 tune 29.2 (without tune) 29.6 (With tune).
fantah is offline   Reply With Quote
Old 11-24-2014, 01:31 PM   #9
Poodles
Drives: 2015 Series.Blue
Could possibly play with the drive by wire setup so it's not possible to full throttle.
Electronic equivalent of putting a block under the gas pedal.
Old 11-24-2014, 03:46 PM   #10
Koa
hate to be 'that guy' to question the OP or suggest something contrary to what you're asking, BUUUT
is that ~2-3mpg increase really worth cutting the nuts off this car? One doesn't die with their money. Memories and experiences are all we really got at the end of the day.. just some food for thought.
I feel your pain though man. I drive 130 miles a day. Everett to Kent, WA.
Old 11-25-2014, 08:40 AM   #11
Over 51,000+ miles I have averaged 32.65MPG, as documented in my owner's journal thread. An increase of 10 to 15% would mean an increase in mileage of 3.2 to 4.8MPG.
Given the current focus on fuel economy requirements, I just don't see any way that Toyota/Subaru would have left that on the table if a simple ROM change would have upped it, even if it meant sacrificing performance a bit particularly given that straight-line, top speed performance was not their focus with the 86 platform.
Old 11-25-2014, 10:17 AM   #12
wparsons
wparsons's Avatar
You'll get far better gains by changing your driving patterns than by re-tuning for economy.
flickr
Old 11-25-2014, 01:04 PM   #13
s2d4
s2d4's Avatar
Choke your intake so it can't flow enough air for 100hp. Redo MAF scale, retard some cam timing, done.
The Following User Says Thank You to s2d4 For This Useful Post:
cdrazic93 (11-25-2014)
Old 11-25-2014, 02:04 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Step 3:???
step 4: drive slower than a prius
Does Turbo effect gas milage?? beesmiff07 Forced Induction 86 10-30-2014 10:25 PM
WTB: FRS/BRZ high milage cools20 Cars for Sale/Trade 0 10-13-2014 01:10 AM
Circuit Motorsports Tuning - EcuTek/RaceRom - New and Improved! Circuit Motorsports Software Tuning 7 05-20-2014 02:26 PM
At what milage did your OEM tires start to lose grip? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2013 05:38 PM
Milage App. execoll Scion FR-S / Toyota 86 GT86 General Forum 11 09-14-2012 12:23 PM
