Old 11-21-2014, 02:45 PM   #29
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Originally Posted by shifter907 View Post
Buy some cheap used WRX wheels with crap tires and go drift around on those. It's so much more fun, and a lot less worrying than burning up my stock tires. This car is easy enough to slide around without having to add much power.
Yeaa i use my stocks for drifting i have separate wheels for every day use.
Sorry to ask, but you DID disable TC/VSC right?
I tried to spin the car in a parking lot in the rain and it refused to do so with TC/VSC in the default state.
With the TC/VSC disabled (5 sec press), you can slide, but you can feel the car fighting the slide somewhat.
After the pedal dance, I filpped end for end a few times (on purpose of course).
Yeaa i did the pedal dance and yes i spun out a couple times lol
DavidBob is offline   Reply With Quote
Old 11-21-2014, 03:18 PM   #30
Akari
Drives: 2013 DGM BRZ
I never really got the hang of it until I had some time on a skidpad. Once you get some more practice you'll start to pick it up pretty quick, my main mistake was not being smooth enough with my throttle input after I entered a slide.
I easily burned a few 32nds off of my stock tires getting this right. It's much, much more fun on Pilot Super Sports but I refuse to ruin my good tires!
Akari is offline   Reply With Quote
Old 11-23-2014, 08:33 AM   #31
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
[ame="http://youtu.be/QSfn7wN7Uuc"]http://youtu.be/QSfn7wN7Uuc[/ame]
Not a long clip because I didn't want to stink up the garage too much
You need to do the pedal dance, otherwise it'll basically cut the engine.
Clutch in
~4500 RPM
Dump the clutch, and immediately get on the brakes with your left foot
You might not figure it out the first try
You'll need to play with how much throttle and brakes you're giving. If you see your revs are dropping give it a little less brakes.
Just make sure there's nothing around you, and if you feel like you're going to hit something or get into trouble or whatever, then clutch in, and brakes if you need to.
Hope this helped
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 11-23-2014, 10:12 AM   #32
White64Goat
Originally Posted by Fastbrew View Post
Yes - yes there are safety precautions you must take before even thinking of attempting the very technical "burnout".
1) Make sure you have a will because you will probably die
2) Make sure you have life insurance that is up-to-date
3) Make sure there is nothing in your oven
4) Make sure all animals and children have proper supervision while you are entering "The Zone"
5) Make sure you have splatter proof pants
6) Put on your +2 undies of self-confidence
7) Put on your +3 cod-piece of Hoonage
8) Adjust your helmet
9) 5-point harness
10) Over inflate the tires
11) Drink 2 Redbulls
12) Put 3 or 4 new stickers on your car
13) Flash some Vs at nearby cameras
14) Make a stop to the restroom to get rid of additional weight
15) Get an AVO turbo (ding!)
16) NoS - Gonna need at least a double-shot
17) Be inside the car
18) Pedal Dancing with The Stars
19) Fill Tank with rocket fuel
20) Spray ground with Extra Virgin Olive Oil
21) Turn up VH Runnin with the Devil
22) Install positraction and a Hurst shifter
23) Wheelie bars
24) Sleep at a Holiday Inn Express the night before
25) Eat your Wheaties
26) Start the car
28) Grab the wheel as hard as you can
29) Put on your gloves
30) Grab the wheel as hard as you can again
31) Rev the engine menacingly
32) Have self-doubt
33) Have tuner enable in rev-limiter
34) Go back through all these steps again
35) Realize the parking lot will be too small
36) Rent an airstrip
37) Get Goose and Iceman to do a fly-over
38) Say a prayer
39) Don't Forget To Drink Your Ovaltine
40) Text your loved ones
41) Put down the clutch
42) Rev it up
43) Check your instrumentation panel
44) Disable your airbags
45) Wave at the pit crew
47) Deploy bleach
48) Pop The Clutch
49) Enjoy the little tire squeak
50) Post video to youtube
51) Get Dominic Toretto to show you how
The Following User Says Thank You to White64Goat For This Useful Post:
raven1231 (11-23-2014)
Old 11-24-2014, 06:14 PM   #33
2pt5RS
Berz
Originally Posted by mav1178 View Post
Poor technique.
If I had a longer sweeper I can slide it all day.
This was without clutch kick... if I clutch kick, zero issues sliding.
Engine is stock except for Crawford BPB.
-alex
hey alex, how many cats did you get to have sex to make the tires screech like that?
2pt5RS is offline   Reply With Quote
Old 11-24-2014, 06:19 PM   #34
juliog
juliog's Avatar
Drives: 86
Wow @mav1178 I need some drifting lessons :O
juliog is offline   Reply With Quote
Practicing rolling shots with my new GoPro :D Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 05-22-2014 09:41 PM
burnout mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 04-29-2014 09:54 AM
Passenger DRL Bulb Burnout Help blackfireball5 Cosmetic Modification (Interior/Exterior/Lighting) 4 04-18-2014 12:25 AM
Can't Launch AT? Do a burnout then Ericfrs Scion FR-S / Toyota 86 GT86 General Forum 30 10-07-2012 01:24 AM
Burnout Vid from Youtube. amilleri FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 06-03-2012 03:34 AM
