Old 05-28-2014, 12:11 AM   #183
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Did you find that the final ride height isn't equal on either side?
Fizz is offline
Old 05-28-2014, 04:21 AM   #184
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
yes. driver side is slightly higher than passenger side. (2~3mm)
with factory setting.
Yobiwan is offline
Old 05-28-2014, 04:47 AM   #185
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I forgot which side was higher on mine, but I noticed the difference was close to 5mm between left and right. I've adjusted the ride height to make the ride height equal.
Fizz is offline
Old 06-14-2014, 12:37 PM   #186
BrianBlueBRZ
Drives: 2014 BRZ
With the minimum 1 inch drop do you need to get a alignment or camber plates or anything. Or is this pretty much a bolt on and go? Will tires wear out much faster with a 1 inch drop or is that to small to make any big changes.
BrianBlueBRZ is offline
Old 06-15-2014, 12:25 AM   #187
was385
Drives: MT WRB BRZ Limited, 2007 911s
A good rule of thumb is to get an alignment after every change to suspension. Camber plates are up to you but if it's just a street car then I would say that the oem crash bolts are enough. Tires wear out based on the alignment. The only real change you'll see that's not correctable is a little more rear camber but it won't really lead to any significant extra wear. So to sum up, drop one inch, get the camber bolts from a Subaru dealership, get it aligned, and you're good to go.
was385 is offline
Old 06-15-2014, 01:33 AM   #188
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I wonder if anyone tried, or can't wait till someone tries, different/linear springs on these.
I wonder how/if they'll handle 6k or 7k or 8k springs, OTS.
fooddude is offline
Old 06-28-2014, 09:32 AM   #189
Yobiwan
Yobiwan's Avatar
Flickr에서 Yobi-Wan님의 new wheel
Flickr에서 Yobi-Wan님의 P6280026
Flickr에서 Yobi-Wan님의 SSR type C 17x8J 35ET
I raised rear to maximum height.
so both front & rear height is highest position now. ( F:120mm R:160mm)
[EDIT] after some exciting drivings on mountain roads, I decided to lower rear about 5mm ( from above picture ) .
and it is my final height. ( maybe =0 ) F:120mm R:155mm
17x8J ET35 + 225 45 17 Bridgestone RE002
front camber -2.0 with camber bolt
Yobiwan is offline
The Following 2 Users Say Thank You to Yobiwan For This Useful Post:
chanomatik (07-08-2014), Manji (08-02-2014)
Old 06-28-2014, 03:27 PM   #190
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
^ Looks to me like the highest setting on these is about as low as my Eibach Pro-Kit? Or am I all screwed up?
Sellout is offline
Old 06-28-2014, 07:19 PM   #191
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
That's about right.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline
Old 06-28-2014, 11:28 PM   #192
Yobiwan
Yobiwan's Avatar
bilstein said B14 will lower car about 20mm.
but it lowered front more than that . (highest position is about 30~35mm lowering)
Yobiwan is offline
Old 08-03-2014, 07:10 AM   #193
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Looks great. And very nice wheels.
S.Koreans are really good at modifiying cars. Its not all about POWER; it's about balance and function.
Thanks for your review above.
Manji is offline
The Following User Says Thank You to Manji For This Useful Post:
Yobiwan (08-03-2014)
Old 09-14-2014, 10:38 PM   #194
Yamshi
Kenji Garage
Yamshi's Avatar
Drives: Frs, Corolla, Mr2
Just received my bilstein b14 coilovers, ride quality is almost the same as oem. Handles very well on sharp corners and steering is very responsive.
Yamshi is offline
The Following User Says Thank You to Yamshi For This Useful Post:
chanomatik (09-15-2014)
Old 09-15-2014, 05:27 PM   #195
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Installed my B14s about 2 months ago and I really like them. I'm still using the OE rubber so the thing wants to drift all the turns. I will upload some pics when I put my cool winter wheels on.
Install was really simple but I did notice that a magnet sticks to the shock. I thought the b14s were stainless?
Either way, the silver coating is real pretty and hopefully that alone protects from the upcoming chicago winter.
spdfreak is offline
Old 11-17-2014, 09:41 AM   #196
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
I do not believe the valving are the same between b14 and b8.
B14 are valved to match the B14/B16 Springs.
B8 for lowering springs
B6 for OEM springs
I personally believe B14 is better for most people due to the fact that when it comes time for rebuilding, it is MUCHH cheaper than the B16 counterpart.
Also, you should have higher spring rates than you do with OEM which means it would be better for performance than say B6 with OEM springs, and probably B8 with Lowering Springs.
CyberFormula is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 09:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 12:26 PM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 01:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 02:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 04:12 PM
