Old 11-16-2014, 07:50 PM   #141
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
That's cool, might have to do this one
B-R-Z is offline   Reply With Quote
Old 11-16-2014, 08:11 PM   #142
MasterMech77
MasterMech77's Avatar
Drives: 2014 Scion FRS 10 Series
Does it work off 6Volt too? That would mean convenience of integration with the Toyota86 head unit. Does it have a wire to cut to remove the guidelines?
Not sure about the 6 volt issue, I have installed a couple of reverse cameras in to a few different vehicles (including my FRS) and have not had any issues with power off the main head units. There is no guide lines to speak of since this particular camera is designed for the BRZ head unit and that has guide line built in to it.
I am not clear from the pics but it looks as if the video cable does not go inside the light.
I could be muddled about this as I have forgotten the exact setup within, but if it does then it may not be necessary to go through the grommet?[/QUOTE]
There is a "notched" slot in the upper portion of the lens, just below and behind the camera itself. That is where you route the cable through. The cable does not go in to the light housing itself but in to the slot provided.
2014 Sc10n FRS 10-Series
#655 of 2500
MasterMech77 is offline   Reply With Quote
Old 11-16-2014, 08:32 PM   #143
MasterMech77
OK just bought the camera/lens combo (http://www.ebay.com/itm/Car-RearView...item5d46de615f)
I will get pictures of the install and let everyone know what I think of it. The Camera I have in there now got damaged when someone closed the deck lid down on to something. Anyway I will do a quick DIY of this camera once I get it and install it.
#655 of 2500
Old 11-16-2014, 08:49 PM   #144
MasterMech77
I forgot... my original install I used the BeSpoke camera wire harness. That was posted somewhere on this Forum. Anyway there is no need to run a power with all the way from the head unit to the rear. I just used the power source from the reverse light to power the camera. The only wire I have running to the front of the car is the RCA that sends the video to the head unit.
Reason for this was a cleaner install by not having to many wires running through the vehicle, not wanting to deal with more then one cable (lazy), the 6volt issue and having to wire in a relay. Besides when the reverse lights come on the camera comes on and that is fine by me.
#655 of 2500
Old 11-17-2014, 12:16 AM   #145
notout86
Drives: GTS 86 auto
Originally Posted by Foobar View Post
Exactly. I've learned to know exactly where the front is eventually, but it's added insurance.
Here's an example of the switch: http://www.aliexpress.com/item/front...675896600.html
That sounds great and would perhaps have saved me heaps of time and extra parts and wiring and farnarcling with soldering etc compared to the system that I ended up using.
Have you integrated yours into the Fujitsu-Ten satnav headunit?
Does it work reliably?
I am proud of my DIY effort as suggested by another forum member (thanks GreenCounty). It has an advantage as it uses a single switch which allows full time front or rear view at any time. Also, neither camera is powered if not giving a picture. But as it sometimes fails to work correctly I would consider getting this system.
GTS86 Auto (Australia)
Old 11-17-2014, 12:25 AM   #146
notout86
Drives: GTS 86 auto
With a front cam I scrape more accurately
I am still waiting for an auto bumper raiser system. I would trade that for heated seats or the sound tube feature any day!
Old 11-17-2014, 01:08 AM   #147
Foobar
SLO NO MO
Foobar's Avatar
I am proud of my DIY effort as suggested by another forum member. It has an advantage as it uses a single switch which allows full time front or rear view at any time. Also, neither camera is powered if not giving a picture. But as it sometimes fails to work correctly I would consider getting this system.
My camera was equipped with the Fujitsu-Ten but I've since upgraded to the Ca-Fi Dashlinq 4. That one actually had multiple inputs, so I could have skipped the switcher box, but then I'd have to mess around with the apps to view the aux input. The switcher box is a single button I have on my dash that lets me turn on the front view at any time, I don't need to see out my rear unless I'm in reverse, but had I wanted that, there was an option for that as well. The particular model I have didn't have it. Like the DIY option, neither camera has power until you press the switch or go into reverse.
The Following User Says Thank You to Foobar For This Useful Post:
notout86 (11-17-2014)
Old 11-17-2014, 08:28 PM   #148
pepe
Drives: gt86
It would be marvelous you put the full tutorial front and rear camera installation
pepe is offline   Reply With Quote
Old 11-20-2014, 01:39 AM   #149
notout86
Drives: GTS 86 auto
http://www.ft86club.com/forums/showt...t=57644&page=3
This link lacks info on fitting the rear cam but there are many other posts on how to do that. One tip is to send the wiring down the center of the car rather than the side. I am pretty sure I posted other rear-cam tips ... search under Advanced with User Name notout86
Old 11-20-2014, 10:55 AM   #150
pepe
Drives: gt86
very interesting thread the cable through the center of the car ..... do you have pictures of this?
I found this connector to two chambers .... It would be possible to use it?
Old 11-20-2014, 04:58 PM   #151
notout86
Drives: GTS 86 auto
Sorry ..... no pictures. Take a rear seat out.(Undo the bolt, press down hard near the rear of where you sit to free a hook, and lift up the front edge while still pressing Just run the wiring under near the center then to the front dash and tuck the wiring up under the edge of the center console.
Old 11-20-2014, 05:05 PM   #152
pepe
Drives: gt86
ist not necessary do all this disassembly?
http://www.ft86club.com/forums/showp...48&postcount=3
http://www.ft86club.com/forums/showp...87&postcount=4
cable slides well without difficulty to the front without removing anything else?
You pull the cable through the side where the leg rests driver?
Old 11-20-2014, 05:20 PM   #153
notout86
Drives: GTS 86 auto
No dissassembly necessary. Just push the wiring up under the lower console edge with your finger and it is jammed into the carpet and stays there. I have run wiring down the door sides as well the first time but would never again.
Old 11-20-2014, 05:33 PM   #154
pepe
Drives: gt86
The cable passes through the side of the shifter? or the lateral plastic upholstery
and .... as you do to bring the cable to touch screnn area?
It would be possible for you to paint the cable run over a photo of the car?
Thank you very much for your instructions
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 12:10 PM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 02:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 04:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 09:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 01:56 PM
