Old 11-13-2014, 10:38 PM   #43
thunderfox
Drives: 2013 BRZ GBS Ltd (RIP)
Originally Posted by Monogram View Post
I do not have an explanation, but after having everything but the master cylinder replaced and the noise never changed, and then having the master cylinder replaced and the noise went away, the answer was obvious.
It's a pretty simple fix to replace the master cylinder, and the noise will go away... but people can argue about it on the internet.
How are you getting these things replaced? 3 dealers later and a call to Subaru of America and I have squat. Now I'm dealing with some of the grinding issues reported in other threads.
thunderfox is offline   Reply With Quote
Old 11-14-2014, 08:03 PM   #44
thunderfox
Mine is an FR-S, and our local Toyota/Scion dealer is great. They worked with the field technical specialists until they had my vehicle fixed.
Ah, that's why. I've seen all over the forums people with the FR-S getting things fixed where Subaru says it isn't an issue.
Old 03-14-2015, 02:28 PM   #45
SpidyJ
Drives: 2013 FRS
So, have we landed on the clutch master as the culprit??
I have almost 17k on my '13 FRS and the sound is with me everyday unless I'm listening to the radio.
I don't want to go to the dealer unless I am confident that they will fix it. It sounds like a simple resonant vibration somewhere in the clutch linkage and the clutch master is in that linkage for sure. It definitely doesn't sound like a bearing noise to me. The FRS is a blast to drive and this simple little quirk does not affect it's performance at all........but it is annoying as hell.
SpidyJ is offline   Reply With Quote
Old 03-14-2015, 03:27 PM   #46
brianhj
Drives: 2017 Camaro 1SS
http://www.ft86club.com/forums/showthread.php?t=62034
I had a honking noise when driving at certain rpms, I think it was resonant vibration as well. It eventually went away. I'm at 11k miles now.
EDIT: Unfortunately the youtube videos are gone but it sounding exactly like a car honking. I thought people were honking at me the first day I heard it.
brianhj is offline   Reply With Quote
Old 03-14-2015, 04:35 PM   #47
I am with you in that it is something in linkage or master. I can make it happen at will just by pushing in the clutch at a certain rate. Never get it during my regular driving though.
Old 03-15-2015, 03:53 PM   #48
Ozzman
Drives: old
Mine is RPM dependent and only occurs when revs rise or fall between 3000-4500 rpm with the clutch depressed. It will happen with no pedal movement during those revs.
Ozzman is offline   Reply With Quote
Old 03-15-2015, 07:48 PM   #49
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
I get it, too, only under hard acceleration... It rarely happens, but as long as it is not damaging, I can live with it.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-18-2015, 12:30 PM   #50
MFPC
MFPC's Avatar
Drives: 2013 Subaru BRZ
Posted under the other thread regarding this issue. Still waiting on Subaru to clear my warranty claim so they can get to work on the car. Tech said he's going to be swapping out the Throwout Bearing in the transmission once all the red tape is cleared.
I'll keep you guys posted and try to see if I can get a glimpse of the old Throwout bearing.
MFPC is offline   Reply With Quote
The Following User Says Thank You to MFPC For This Useful Post:
Tcoat (03-18-2015)
Old 03-19-2015, 02:29 PM   #51
MFPC
MFPC's Avatar
[Update]:
Interestingly enough, they're not just replacing the throwout bearing. They're replacing the entire clutch assembly...
Looks like I'm in my loaner for another week...
Old 03-19-2015, 07:16 PM   #52
Monogram
Drives: 2014 FR-S
Toyota replaced the transmission, clutch, and throw-out bearing in my FRS, and it did not fix the honk noise. They then replaced the clutch master cylinder and slave cylinder which fixed the noise. The noise is coming from the clutch master cylinder, and replacing the trans/clutch/throw-out bearing does not fix the noise.
Monogram is offline   Reply With Quote
Old 03-19-2015, 09:24 PM   #53
SpidyJ
Drives: 2013 FRS
Thanks Mono...I'm going to pass this info on to Sparks Toyota and see if they'll believe me/you. What is the name of your dealer, maybe they will call to verify?!?
Old 03-19-2015, 10:44 PM   #54
Monogram
Drives: 2014 FR-S
Just let your dealer know that the FTS was involved, and made the call to try the trans/clutch/to bearing. The dealer only installed what they were given.
Old 03-20-2015, 07:12 PM   #55
MFPC
MFPC's Avatar
Well that's a bummer if that's the case.
Here's my little report I got after I got my car.
If it makes the noise again, I'll be sure to mention it to be the clutch master cylinder and slave cylinder.
Old 03-20-2015, 08:33 PM   #56
SpidyJ
Drives: 2013 FRS
Sorry I'm such a dumazz Mono, but what is an FTS?
....aaaah "Field Technical Specialists" (Google is my frenn!)
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 03:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 05:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 07:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 02:33 AM
