Old 11-12-2014, 12:03 PM   #1
pseudo
pseudo's Avatar
Drives: 2008 Cayman S
2nd gear syncro
Every once in a while, I get kinda lazy with my shifting and don't exert enough force to get all the way into second gear.
Sometimes, when this happens I get a nasty grinding noise as if I was shifting without the clutch. (clutch is all the way to the floor when this happens)
This is not normal, right? I am thinking there is something wrong with the 2nd gear syncro since it is sometimes hard to drop into second as well.
The issue isn't very repeatable, and only seems to happen at high rpms sometimes, so I am not confident that I can recreate the issue at a dealership.
Any advice? Am I worrying about nothing, or should I try to further diagnose this?
pseudo is offline   Reply With Quote
Old 11-12-2014, 12:17 PM   #2
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Sounds normal to me. If you don't fully engage the gear when shift, its going to grind!
billwot is offline   Reply With Quote
Old 11-12-2014, 12:22 PM   #3
extrashaky
Drives: 2014 BRZ Limited
Right. It is not normal to get lazy with your shifting and fail to exert enough force to get all the way into second gear. Fix the failing part behind the wheel, and this problem should go away.
Old 11-12-2014, 12:33 PM   #4
pseudo
pseudo's Avatar
Fair enough, thanks!
Old 11-12-2014, 01:41 PM   #5
sergiomordo
sergiomordo's Avatar
Drives: 2014 Scion FR-S Whiteout
This happened to me 3-4 times since I bought the car about 5 months ago. Last time was yesterday. Each time, I was shifting at a high rpm, the second gear did not engage well and got the grinding noise. I owned 2 other manual cars before and drove many more, and never had such an issue. Idk if this is an issue with the syncro or not but I try to exert more force especially while shifting into second, to avoid this issue.
sergiomordo is offline   Reply With Quote
Old 11-12-2014, 02:24 PM   #6
I'm going to plug your post with the video. This <ahem> tutorial <ahem> is <ahem> excellent.
<ahem>
http://www.ft86club.com/forums/showt...37#post2017737
OP, you're shifting through the syncro but not into gear. This video will make it all clear.
extrashaky (11-12-2014)
2nd Gear Syncro Problem nashsnazzy Issues | Warranty | Recalls / TSB 22 07-14-2014 10:20 AM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
