Old 11-08-2014, 08:46 PM   #1
Itzed
Drives: 2014 BRZ Limited
Which parts are Toyota, and which parts are Subaru?
We all know the boxer engine is Subaru, and the direct injection is Toyota, but beyond that, what is what? I was following another thread about learning stick where wearing out the clutch was discussed, and having a lot of experience with Subarus, I felt like commenting not to worry, because the throw out bearing will wear out way before the clutch anyway. But then it occurred to me, I'm thinking of this car as a total Subaru, when in fact I don't even know if it's really a Subaru clutch!
Itzed is offline   Reply With Quote
Old 11-08-2014, 10:07 PM   #2
CoupedUpSubie
Drives: 2013 BRZ Limited
From what I found the OEM clutch is an Exedy clutch(same company Subaru uses). From what I know the parts that lean towards one manufacturer are as follows.
Subaru:
engine
headlights(limited are adjustable like the STi)
wheel studs(12x1.25)
Toyota:
rear diff
direct injection
keyless entry
The rest of the car was custom designed(unibody does take after a Subaru) to be what it is or suitable parts sourced such as the Aisin transmission.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 11-08-2014, 10:56 PM   #3
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
The ecu/electrical system is toyota. For instance the turn signal stalk has toyota stamped on it. I found this while switching a fog light turn stalk in to my car. I'm willing to bet the wiper stalk is the same thing and a lot of the electrical components.
VacantSky is offline   Reply With Quote
Old 11-08-2014, 10:58 PM   #4
radroach
Drives: car
Originally Posted by Itzed View Post
Subaru, Toyota, but beyond that, what is what?
Denso for generic parts, Exedy clutch, guessing Takata airbag.
Old 11-08-2014, 11:38 PM   #5
The 3 knobs for the cabin hvac and probably all the related stuff is Toyota.
Chassis/suspension is Subaru. Clutch and pedal cluster are also Subaru
Old 11-09-2014, 12:02 AM   #6
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
The FR-S badge is subaru - someone here had a pic of the back.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
Jrryjms07 (11-10-2014), Ultramaroon (11-09-2014)
Old 11-09-2014, 12:09 AM   #7
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
I believe the electric steering is lifted from some lexis models. I also believe the 6-speed gearbox is an IS250 part. I could be wrong on both counts.
Jar is offline   Reply With Quote
Old 11-09-2014, 12:28 AM   #8
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
If I learned anything from the Internet, everything that breaks is a Subaru part, and everything that doesn't is Toyota.
Bobblehead is offline   Reply With Quote
The Following 8 Users Say Thank You to Bobblehead For This Useful Post:
AznBRZer (11-09-2014), GotBRZ1691 (11-10-2014), hmong337 (11-09-2014), Jrryjms07 (11-10-2014), manonastick (11-10-2014), maxjedi (11-09-2014), NIN69 (11-09-2014), strat61caster (11-09-2014)
Old 11-09-2014, 12:30 AM   #9
Here's the story on the tranny. It started out as an AZ6 (IS250) but it was totally redesigned for the twin.
Were we (and Aisin) wrong about the BRZ / FR-S / GT 86 manual transmission? Or is Scion?
DAEMANO (11-09-2014), Jar (11-09-2014)
Old 11-09-2014, 12:58 AM   #10
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
Um WRX platform? Bueller.......bueller?
Dwood11 is offline   Reply With Quote
Old 11-09-2014, 01:08 AM   #11
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Trans is an asin tl70
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 11-09-2014, 04:18 AM   #12
Jegan_V
Drives: 2023 Subaru BRZ
This thread has done a good job at showing most of the important components.
http://www.ft86club.com/forums/showthread.php?t=71898
Jegan_V is offline   Reply With Quote
The Following User Says Thank You to Jegan_V For This Useful Post:
Bristecom (11-11-2014)
Old 11-09-2014, 11:00 AM   #13
extrashaky
I rented a Camry last week. I think all the stalks were the same, including the cruise control. I rent cars a lot for my job, so every time I drive something new I have to figure out where things are. It was strange to get into the Camry for the first time and already know where all the controls were.
Old 11-09-2014, 11:11 AM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
Denso electrial parts and Aisin tranny all fall under the Toyota umbrella I believe.
So in general, fuel injection, much electrical and tranny is Toyota. Also, various switch gear.
Chassis, suspension, engine and virtually everything else Subaru.
Concept and styling Toyota. Execution and assembly Subaru.
Safe to say neither could have made this car without the other. Financially, Subaru needed Toyota. For the boxer engine and available production facilities Toyota needed Subaru.
Toyota conceived the idea, Subaru eventually capitulated. This is probably the most visible benefit of Toyota acquiring 17% stake in Subaru.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
DAEMANO (11-09-2014), hmong337 (11-09-2014)
Toyota vs Subaru parts prices???! Minovsky CANADA 5 07-18-2013 08:43 AM
Subaru vs Toyota parts pricing Turdinator AUSTRALIA 17 03-07-2013 10:07 PM
Toyota vs Subaru Parts 86drift AUSTRALIA 9 11-12-2012 06:51 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
