#15 |
Ya, I was baffled why every time I put my phone on the seat to charge the light came on. Turns out the seat uses an electronic proximity type sensor instead of a mechanical contact switch. Any electronic device can set it off.
#16 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I'm currently at 44,000kms in about 16 months of ownership. No issues whatsoever. However, my car does see literally no abuse and I commute 95% highway so it is extremely easy on the car. I plan to get at least 300,000 kms out of this car with hopefully no issues.
Would be nice if people posted their build date. Mine was built May 2013.
#17 |
Drives: '13 FRS - STX
32k miles, daily driven, been driven relatively hard (I'm not that good of a driver though) never been back to the dealership.
#18 | |
#19 |
Drives: Whiteout FR-S MT
I would say if you get a 2013, as long as you make sure to get the rough idle TSB taken care of you will be fine. The rough idle TSB is the only way to get the updated tune to fix the direct injection seal issue.
I have a 2013 with 30k miles. No issues. It was a pain to get that tune fixed though. |
#20 | |
Drives: 86
#21 |
Emperor JDM
Well, majority of the issues as it seems appear to be with early production cars. Basically the pre-order cars - the ones out on the road late 2012. Being a May 2013 build, hopefully the early issues were resolved by then. Still no resolution for our chirping fuel pump though. I don't think there are any TSB's in Canada.
#22 | |
Drives: RV-7
| The Following User Says Thank You to torqdork For This Useful Post: | Tcoat (11-08-2014) |
#23 | |
There are of course the "know issue" items (tranny, throw out bearings, etc)that seem to pop up at random regardless of build date but in the overall scheme of things these are relatively rare. The fuel pump TSB does apply to Canada but I didn't bother as I only had the issue for 3 days after using some crappy gas, it isn't really an "issue" and the TSB action doesn't fix it anyway. In many of the cases this forum has created a false indication as to exactly how bad some of the issues actually were. The person yelling loudest always gets the most attention so those without issues go unnoticed. I bet there are thousands of people out there driving with one or more of the problems that have never even noticed it since they do not read forums!
#24 |
AutoX-10/10ths every run
I bought mine May 30, 2012 BTW.
#25 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#26 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Also I purchased min May 31, 2012 FWIW. Build date March 2012.
#27 |
Drives: BRZ CSB Limited
I've dealt with almost all the major issues.
I've had the car in the shop about 10 times for check engine lights regarding cam gears, bad ecu, and oil seals. I am also currently dealing with throw-out bearing squeal (which will in due time result in a replaced clutch/new bearing. Out of basic warranty I've replaced the fuel pump 3 times for chirps and gave up after the third time (2nd gen pump). I did not drive this car hard at all, except for the occasional canyon run. I purchased mine March 2013 and have roughly 44k miles on the vehicle. Still love the car, but do question it's long-term reliability. |
#28 |
Sarcastic SOB
Bought mine the day they went on sale. Took delivery April '12. No issues other than taillights condensation, keeps returning. I'm OK as long as they keep replacing them AFTER my warranty ends this April.
| Tags |
| brz, frs, subi, toyota |
| FR-S / BRZ reliability stats | mkaresh | Scion FR-S / Toyota 86 GT86 General Forum | 82 | 03-12-2017 03:40 PM |
| Turbo Reliability VS Supercharger reliability | KGB | Forced Induction | 130 | 09-08-2015 10:55 AM |
| Concerned with reliability... should I be? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 07-01-2013 08:02 AM |
| ECU Tuning for Reliability | regal | Engine, Exhaust, Transmission | 7 | 06-27-2013 08:07 AM |
