Old 11-05-2014, 08:02 PM   #1
kbogarto
Drives: 2013 BRZ limited WRB
Wide Band AFR questions
I am going forced induction next month and have a couple questions regarding a wideband AFR gauge.
1. If I get an AFR gauge I would like to have a failsafe built into my tune based on the readings from the AFR sensor. I assume with a custom tune this is easily added?
2. I plan on installing the kit myself but have no way of welding the bung into the exhaust. Is this a pretty straightforward thing for most shops to do? how much would they charge for this?
Thanks for the responses, I have learned a ton form reading through this forum.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 11-05-2014, 08:17 PM   #2
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
1) yes tuner can do that based of the exhaust manifold sensor as well as your wideband - once you feed the signal back into the ECU.
2) AEM offers a 30 dollar or so kit to drill your own bung into the exhaust. Its a slip on device with no welding: http://www.aemelectronics.com/produc...-sensor-mounts
I personally would get one welded.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
kbogarto (11-05-2014)
Old 11-05-2014, 08:21 PM   #3
bakerr6
Drives: 2013 raven black fr-s
That no-weld bung was a good idea. I agree though, just get it welded in. The bung will probably cost around the same price e to have it welded in (I would think no more than 40-50, including the bung).
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
Old 11-06-2014, 01:51 AM   #4
ztan
Drives: Toyota 86
Just wondering if anyone has done the scaling work on the stock sensor at the rich end.
I was wondering and posted earlier today in mad_sb's thread:
http://www.ft86club.com/forums/showthread.php?t=27793
ztan is offline   Reply With Quote
Old 11-06-2014, 02:23 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Mine reads down to 11.02. How accurate it is that low though would need a true WBO2 installed.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-06-2014, 02:33 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm still confused about how to hook up a aftermarket wideband sensor. Can I just remove the rear O2 sensor and replace with the aftermarket one? How do you connect the wires?
Fizz is offline   Reply With Quote
Old 11-06-2014, 11:57 AM   #7
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
That's a good question, I'm not certain if the factory one can be swapped out with the wideband.
However, I know others that just feed their wideband signal into the secondary o2 sensor blue wire after snipping that wire.
Old 11-06-2014, 12:45 PM   #8
kbogarto
So if i ran an AFR failsafe through a custom tune off the stock O2 sensor I wouldn't need to do any wiring at all correct?
Old 11-06-2014, 01:03 PM   #9
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
More info from this thread - I had forgotten all about it:
http://www.ft86club.com/forums/showthread.php?t=57902
Edit: And these:
http://www.ft86club.com/forums/showthread.php?t=42764
http://www.ft86club.com/forums/showthread.php?t=49557
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
Fizz (11-06-2014), kbogarto (11-06-2014)
Old 11-06-2014, 06:21 PM   #10
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
But isn't the whole point of swapping out the stock rear sensor for the wideband sensor is because the aftermarket one gives more accurate reading?
If you are just hooking up the failsafe to the stock sensor then you're still basing your safety cut on inaccurate readings....no?
Old 11-06-2014, 06:37 PM   #11
Xuningshen
Drives: Subaru BRZ
man you guys are confusing me even more.... I've been trying to research this. I assumed you can't just replace it with a stock one.
I was planning on getting the berk overpipe that has a bung welded into it.
http://counterspacegarage.com/berk-t...-frs-gt86.html
off topic: Although doing this with the stock headers would be completely useless because of the cats correct? I wanted to start off with a wideband on the Jackson racing SC w/ the carb tune.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 11-06-2014, 06:42 PM   #12
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
First off a wideband o2 must be before any cats.
Second you can run the signal from a wide band into the factory ecu (see previous links) but you need a good tuner and ecutek to build in a failsafe.
The stock o2 is pretty good, but it's not perfect.
I have an aem failsafe wired into my ecu.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
kbogarto (11-06-2014), Xuningshen (11-06-2014)
Old 11-06-2014, 09:45 PM   #13
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Not true. The tuner must know about the cats or lack there of when tuning. My tuner was able to tune with the wideband sensor after the cat, no problem. Accuracy was spot on.
If you're going to flash with the off the shelf carb tune then having a wideband would be for your own observation / logging. Adding a failsafe mechanism would require the tuners assistance.
Old 11-06-2014, 10:34 PM   #14
Xuningshen
Drives: Subaru BRZ
Sweet thanks a lot for the info dude.
2014 WRB BRZ
PTUNING V Band Exhaust (PRICE DROP) REVstylez Mid-Atlantic 1 10-01-2014 10:27 AM
215 wide tire on 8.25 wide rim question barabia Tracking / Autocross / HPDE / Drifting 15 06-30-2014 08:59 PM
Perrin catback v-band's nut issues Roarke Engine, Exhaust, Transmission 11 06-26-2014 01:59 PM
FS: Ptuning V Band Dual/Single Exhaust REVstylez Engine, Exhaust, Bolt-Ons 2 09-20-2013 04:10 AM
Perrin 2.5" V-Band Clamp BRZerk Engine, Exhaust, Transmission 5 08-27-2013 01:10 PM
