| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
I fill mine with helium!
My car is .0000000000001 pounds lighter now!
| The Following User Says Thank You to Tcoat For This Useful Post: | flippy (11-20-2014) |
#16 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I use an approximately 78% concentration of nitrogen with 20% oxygen and some other proprietary compounds.
#17 | |
#18 |
Drives: 2015 Series.Blue
The supposed other advantage is that the tires won't oxidize from the inside out... Dunno how much I believe of that, but if I was given the option to use nitrogen for free/cheap, I'd probably do it as a "why not?"
I'm sure we do dumber things to our cars that has no real function... |
| The Following User Says Thank You to Poodles For This Useful Post: | Bristecom (12-03-2014) |
#19 |
Drives: Toyota 86 13'
Waste of money for street driving and the track day regulars (imo), unless you're chasing ten tenths competitively.
Ran it once to trial out it's characteristics on track and wasn't blown away, finished the day and refilled tires with "regular" air... because its free... Last edited by tnle; 11-03-2014 at 07:37 AM. |
#20 |
Poor College Kid
Drives: ~.~
I thought we get it for free.. well at least for me.
#21 | |
Mitsu salesguy tried that line when I was looking at Evos. Said as soon as you put air under pressure the oxygen level sky rockets and destroys the tires from the inside. I laughed so much I almost puked right in the showroom. The great part was when I asked if they would change the air in my Lancer GT tires to nitrogen (as a joke) he said they couldn't do it there as they didn't have a tank.
| The Following User Says Thank You to Tcoat For This Useful Post: | gramicci101 (11-03-2014) |
#22 |
i kill cones.
Drives: around cones in a parking lot
the only reason is to limit the fluctuation in pressures due to temperature changes.
that is the only reason. regular driving you probably wont notice any difference (except around this time of year as temps cool off) on the track it is much more stable. anyone that says it doesnt do anything is wrong.
2013 SSM BRZ Limited 6MT
#23 | ||
Drives: 2013 GBS BRZ Limited
AIR is 80% Nitrogen AND ~20% Oxygen. Nitrogen & Oxygen are RIGHT NEXT TO EACH OTHER on the periodic table Therefore a cylinder filled with 100% Nitrogen will experience EXACTLY the same change in pressure with temp as a cylinder filled with 80% nitrogen & 20% oxygen. Quote:
SCIENCE Bitches! |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | rice_classic (11-20-2014), Tcoat (11-04-2014) |
#24 | |
i kill cones.
You're right with your idea but in the real world "air" in your tires is whatever "air" your compressor pumps in... not dry. I'm not wrong.
#25 |
I fill my tires with used coolant so the pressure doesn't change at all.
#26 | |
Just put my winter air in as the summer stuff just wasn't cutting it anymore!
#27 | ||
I will rephrase: "There is no difference between using dry air versus Nitrogen to fill your tires. Anyone who says otherwise is wrong" Quote:
IF you could find a phase change liquid that evaporates right at the final target temp of the tires at race temps, then you could have MORE STABLE temps than anyone experiences right now. The liquid would work as a tire balancer (like the little beads that some use) and would evaporate to keep the tire temps stable. I have never heard of that before. We use some interesting liquids at work as cooling fluid. It evaporates at 70F and leaves NOTHING behind. I used it in my ultrasonic cleaner to clean some carb parts. It was cool - pour in fluid, turn on cleaner with heat. Come back in 20 minutes and parts are clean, dry, and there is now dry-dirt at the bottom of the cleaner. It is similar to dry cleaning fluid. |
#28 | |
| Toyota filled my coolant overflow with washer fluid | Decay107 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 08-11-2016 10:18 AM |
| Is the front sway bar bushings liquid filled? | Rayme | Issues | Warranty | Recalls / TSB | 13 | 10-02-2014 05:06 PM |
| filled up w e85 now car wont start..id1000s dw65s jdl kit | kingkai23 | Forced Induction | 8 | 07-24-2014 10:56 AM |
| Prescription Filled!!! | SIC8D6 | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 04-12-2014 01:47 AM |
| Dealer filled my new FRS with 87 octane; Should I flash ECU? | Hakuzen | Issues | Warranty | Recalls / TSB | 37 | 01-09-2014 05:52 PM |
