| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Is anybody running Nitrogen in their tires? If so do you think its made a difference or worth it? I took the FRS in for a tire rotation and man were they pushing me to fill all the tires with nitrogen. It was expensive so said no for now but i left curious about the benefits. I got shown all these charts and stuff and they made me feel like putting regular air in my tires is a no no on this car. I call BS on that.
#2 |
Drives: 2013 FR-S, 2012 MCS
I think they busted this on Fifth Gear. It's no better than regular air...
#3 |
Drives: 2015 Raven FRS
I run nitrogen in my tires. I like it because once I get my pressure set I don't have to keep playing with it as tires heat up on the track.
I carry a bottle of Nitrogen in my trailer if I need to ever top them off. I would never go back to air for track tires myself. But see no benifit for street only tires. |
#4 |
Drives: 2014 WRB BRZ LTD
I had nitro fill on my Genesis tires. It was great because they never lost pressure with temperature changes. No reason to do it with the BRZ since I swap tires for winter.
#5 |
Drives: Whiteout Scion FR-S
I had a set of tires filled with nitrogen a few years ago on an old car. The tires went at least 2 years without needing pressure adjustment. Nitrogen is drier than most air fill, in addition to being a mostly larger and more uniform molecule. Moisture in the air really affects how the pressure responds to changes in temperature. When needed, you can top off the nitrogen filled tire with normal air, as the small amount will not affect it that much, as long as the air is reasonably dry at the time. I also really like nitrogen fill for tires that see track use, as they seem to keep more consistent pressure as the tires heat up.
What price were they asking you to pay for nitrogen fill? I just had a new set of snow tires mounted and had them filled with nitrogen for $5 per tire. I felt that it was worth it based on my past experience.
My cars always dress formally. They all wear black tires.
#6 |
Drives: BRZ DGM Limited
When you get new tires at Costco , they fill them with nitrogen at no additional charge. I did not notice any difference.
#7 |
Drives: 2013 GBS BRZ Limited
I'll sell you my very own special blend of Tire Air.
It is 78% nitrogen, 21% oxygen, and a special blend of trace gases. It's cheap and I will ship it to you in canisters. |
#8 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
#9 |
Drives: 2012 Toyota 86
We use nitrogen in all the aircraft in the navy, and we check and adjust pressure daily. The advantage comes from the lack of moisture.
http://www.tirerack.com/tires/tirete...jsp?techid=191 Last edited by troek; 11-01-2014 at 11:42 PM. |
#10 |
The ONLY advantage to using dry nitrogen in aircraft instead of dry air is that the N2 is non combustible which is important in aircraft, not cars.
And as for the "my pressure changes less due to temperature changes with the Nitrogen": Bullshit! Last time I checked PV-nRT applies to all gases which means that the Pressure change due to temperature is the same for Nitrogen as it is for "Air" especially since '"Air" is already 80% Nitrogen. The ONLY difference it makes is that less moisture can translate to more consistent pressure to temperature variation. That is because the presence of a phase change material (water) in the tire can make the pressure vs temp profile non-linear and NOT follow the ideal gas law. So if you use an air dryer on your compressor, you will see no difference between dry air and Nitrogen. But hey .... It's your money. Last edited by stugray; 11-02-2014 at 02:16 PM. |
#11 |
Off Topic
#12 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
My winters were put into storage last year - I just put them on the car 3 days ago. Exactly the same PSI as when I put them away (34). From my compressor. It's snake oil for a street car. |
#13 |
Drives: Lightning Red '13 Limited BRZ
Got my tires filled with nitrogen after the Georgia winter and fluctuating temperatures had me going to the air fill up almost every two days. My Subaru dealership offered it to me for free and I haven't seen my tpms light go off since. It was worth it for me especially since it was free.
#14 |
Drives: 2014 Scion FR-S
Don't the cars come stock with nitrogen-filled tires, or is it just based on the dealership?
My tires have the green cap on them which I thought indicates that the tires are filled with, and only should be filled with nitrogen - I've had my car for over a year now, and I've never had to refill them outside of when the dealership checks them during my oil changes. |
| Toyota filled my coolant overflow with washer fluid | Decay107 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 08-11-2016 10:18 AM |
| Is the front sway bar bushings liquid filled? | Rayme | Issues | Warranty | Recalls / TSB | 13 | 10-02-2014 05:06 PM |
| filled up w e85 now car wont start..id1000s dw65s jdl kit | kingkai23 | Forced Induction | 8 | 07-24-2014 10:56 AM |
| Prescription Filled!!! | SIC8D6 | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 04-12-2014 01:47 AM |
| Dealer filled my new FRS with 87 octane; Should I flash ECU? | Hakuzen | Issues | Warranty | Recalls / TSB | 37 | 01-09-2014 05:52 PM |
