Old 11-01-2014, 08:32 PM   #1
SocalBurt
Exclamation Nitrogen Filled Tires
Is anybody running Nitrogen in their tires? If so do you think its made a difference or worth it? I took the FRS in for a tire rotation and man were they pushing me to fill all the tires with nitrogen. It was expensive so said no for now but i left curious about the benefits. I got shown all these charts and stuff and they made me feel like putting regular air in my tires is a no no on this car. I call BS on that.
SocalBurt is offline   Reply With Quote
Old 11-01-2014, 08:54 PM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I think they busted this on Fifth Gear. It's no better than regular air...
Old 11-01-2014, 08:55 PM   #3
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I run nitrogen in my tires. I like it because once I get my pressure set I don't have to keep playing with it as tires heat up on the track.
I carry a bottle of Nitrogen in my trailer if I need to ever top them off.
I would never go back to air for track tires myself. But see no benifit for street only tires.
Lunatic is offline   Reply With Quote
Old 11-01-2014, 09:00 PM   #4
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
I had nitro fill on my Genesis tires. It was great because they never lost pressure with temperature changes. No reason to do it with the BRZ since I swap tires for winter.
Annahra is offline   Reply With Quote
Old 11-01-2014, 09:08 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I had a set of tires filled with nitrogen a few years ago on an old car. The tires went at least 2 years without needing pressure adjustment. Nitrogen is drier than most air fill, in addition to being a mostly larger and more uniform molecule. Moisture in the air really affects how the pressure responds to changes in temperature. When needed, you can top off the nitrogen filled tire with normal air, as the small amount will not affect it that much, as long as the air is reasonably dry at the time. I also really like nitrogen fill for tires that see track use, as they seem to keep more consistent pressure as the tires heat up.
What price were they asking you to pay for nitrogen fill? I just had a new set of snow tires mounted and had them filled with nitrogen for $5 per tire. I felt that it was worth it based on my past experience.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 11-01-2014, 09:42 PM   #6
BRZnut
Drives: BRZ DGM Limited
When you get new tires at Costco , they fill them with nitrogen at no additional charge. I did not notice any difference.
Old 11-01-2014, 09:49 PM   #7
stugray
Drives: 2013 GBS BRZ Limited
I'll sell you my very own special blend of Tire Air.
It is 78% nitrogen, 21% oxygen, and a special blend of trace gases.
It's cheap and I will ship it to you in canisters.
The Following 18 Users Say Thank You to stugray For This Useful Post:
8R6 (01-15-2015), AndMsc (09-22-2021), Bobblehead (11-02-2014), brandonblt2 (11-02-2014), Canehda (11-01-2014), Creole (11-04-2014), Dadhawk (11-03-2014), flippy (11-20-2014), fstlane (11-02-2014), Ganthrithor (12-07-2014), gramicci101 (11-02-2014), Mike86 (11-05-2014), Model Citizen (11-02-2014), navanodd (11-01-2014), SomeoneWhoIsntMe (11-02-2014), Tcoat (11-02-2014), troek (11-01-2014), Ultramaroon (11-02-2014)
Old 11-01-2014, 10:00 PM   #8
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
I see what you did there
do you offer blinker fluid as well?
Canehda is offline   Reply With Quote
Old 11-01-2014, 11:49 PM   #9
troek
troek's Avatar
Drives: 2012 Toyota 86
We use nitrogen in all the aircraft in the navy, and we check and adjust pressure daily. The advantage comes from the lack of moisture.
http://www.tirerack.com/tires/tirete...jsp?techid=191
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
stugray (11-02-2014)
Old 11-02-2014, 02:29 PM   #10
stugray
The ONLY advantage to using dry nitrogen in aircraft instead of dry air is that the N2 is non combustible which is important in aircraft, not cars.
And as for the "my pressure changes less due to temperature changes with the Nitrogen":
Bullshit! Last time I checked PV-nRT applies to all gases which means that the Pressure change due to temperature is the same for Nitrogen as it is for "Air" especially since '"Air" is already 80% Nitrogen.
The ONLY difference it makes is that less moisture can translate to more consistent pressure to temperature variation.
That is because the presence of a phase change material (water) in the tire can make the pressure vs temp profile non-linear and NOT follow the ideal gas law.
So if you use an air dryer on your compressor, you will see no difference between dry air and Nitrogen.
But hey .... It's your money.
The Following 2 Users Say Thank You to stugray For This Useful Post:
ChuckD (11-02-2014), Tcoat (11-02-2014)
Old 11-02-2014, 02:48 PM   #11
gramicci101
Off Topic
They were doing that because of this:
It was expensive
Old 11-02-2014, 04:21 PM   #12
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
If it's free, whatever floats the boat. But 5/wheel???
My winters were put into storage last year - I just put them on the car 3 days ago. Exactly the same PSI as when I put them away (34). From my compressor. It's snake oil for a street car.
Khyron686 is offline   Reply With Quote
Old 11-02-2014, 06:17 PM   #13
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Got my tires filled with nitrogen after the Georgia winter and fluctuating temperatures had me going to the air fill up almost every two days. My Subaru dealership offered it to me for free and I haven't seen my tpms light go off since. It was worth it for me especially since it was free.
lastexile1987 is offline   Reply With Quote
Old 11-02-2014, 08:18 PM   #14
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Don't the cars come stock with nitrogen-filled tires, or is it just based on the dealership?
My tires have the green cap on them which I thought indicates that the tires are filled with, and only should be filled with nitrogen - I've had my car for over a year now, and I've never had to refill them outside of when the dealership checks them during my oil changes.
Ammunition is offline   Reply With Quote
Toyota filled my coolant overflow with washer fluid Decay107 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 08-11-2016 11:18 AM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 06:06 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 11:56 AM
Prescription Filled!!! SIC8D6 Scion FR-S / Toyota 86 GT86 General Forum 39 04-12-2014 02:47 AM
Dealer filled my new FRS with 87 octane; Should I flash ECU? Hakuzen Issues | Warranty | Recalls / TSB 37 01-09-2014 06:52 PM
