Old 10-16-2014, 01:28 PM   #43
Chimera
Drives: FRS
crx-303 is rated at 4ohms, infinity speakers are 3ohm speakers, so I multiplied the crossover points by .75
my amps crossed over at 80 hz, so in reality the 6.5 will drive 80~375
Originally Posted by football751 View Post
I don't really understand your "at 3 ohm for infinity's that's..." What are those 3 numbers?
Also, are the 6502s rated for 20 Hz? Seems low for a 6.5" speaker.
Old 10-25-2014, 07:49 PM   #44
Chimera
Drives: FRS
Thumbs-up for the crx-303!
Old 11-04-2014, 03:50 PM   #45
rickytron
Drives: 2013 Black FR-S
Originally Posted by tonystewart View Post
I installed these and insulated/soundproofed the area with Raammat on the sheet metal and Ensolite on the interior panel.
I did the same setup in my car with 3"1/2 two way Kicker DS5 speakers and it sounds like a new system! New aftermarket rear speaker are a definite change in sound quality. I also have a self powered 10" Kicker sub in the trunk that rounds out a nice bump!
rickytron is offline   Reply With Quote
The Following 2 Users Say Thank You to rickytron For This Useful Post:
DAEMANO (11-24-2014), Tcoat (11-04-2014)
Old 11-24-2014, 02:32 PM   #46
AncientCityFRS
Poker Player
AncientCityFRS's Avatar
Drives: FRS Release 1.0
Anyone try the JBL GTO 328? It looks like it will fit and is 2 ohms. I just want a better fill than the standard rear speakers. I don't want the world just a better balance of sound.
AncientCityFRS is offline   Reply With Quote
Old 11-24-2014, 02:46 PM   #47
football751
Drives: n/a
If the rest of your system is stock I found moving the fader to Rear 2 improves the fill and allows the volume to get a bit louder before the woofers starts rattling the doors or distorting. If you are wanting to replace them I imagine any aftermarket speaker would be an improvement, and if you're not going to amp them I think you're pretty much good to go with anything.
football751 is offline   Reply With Quote
Old 12-05-2014, 03:03 PM   #48
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Rear Speakers
I am in a similar quandary with system choices. I do NOT want to add weight so I am trying to be smart with choices and replace the factory amp with something of similar size and weight to at least drive the fronts. Going either Kenwood Excelon or Alpine, but probably will end up with Kenwood Nav. The rear speakers are a pain to get to I understand (anyone have a DIY on getting to them without breaking any tabs etc..)?
Secondly, if you are spending the time to get in their and Dynamat, why not upgrade the speakers...or just take the caps off the little guys and run with it crossing them over with sound processing etc.
F1fletch is offline   Reply With Quote
Old 12-05-2014, 04:12 PM   #49
Chimera
Drives: FRS
IMO they're not particularly difficult to get to.
remove seat bottom, remove bottom door sill from front door, pull a little bit of weather sealing, like 3~4 push pins, and then pull the whole panel off.
Originally Posted by F1fletch View Post
Rear Speakers
Old 12-18-2014, 08:42 PM   #50
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Decided to put separates back there, the system is being installed today and tomorrow. We wanted to maximize cone area since I am not using a sub. Will be 7" components front and rear with the rear stage crossed over at about 80hz. Will post pics when done.
Old 01-17-2015, 02:30 PM   #51
Rosticles
Drives: 1966 Mustang, 2013 FR-S
Where are the rear crossovers? I just installed new speakers and put in sound dampening, but the highs are being cut to the rear. I know they're just for fill but I like to have some highs in the rear and I cannot get it until I take out or modify the crossover.
There were no components on the speaker or in the immediate wiring. Does anyone know where they are?
Rosticles is offline   Reply With Quote
Old 04-29-2015, 06:38 PM   #52
PNW FRS
PNW FRS's Avatar
Interesting thread...
Some good info throughout this thread. One thing I'd like someone to explain to me about this "rear fill" thing. When I play with Audio Settings and move Fader to full-rear (e.g., R-5), there is barely any sound coming out of the rear speakers. I have to push volume to over 25 to make out what is on the radio. Is this representative of "Rear Fill" -- just a little bit of sound to round-out what is coming from front speakers?
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 03-02-2016, 12:03 AM   #53
Stevemd24
Drives: FRS
Originally Posted by Gary in NJ View Post
What were the results?
do you know when you buy the frs, the factory stereo isn't turned correctly and the sound is completely wrong for the car, you can maximize the sound if you change the settings to FRS,
It will even let you customize your opening screen on your head unit,
to do this
Turn your car onto accessories, turn the radio off if its on, Push and hold down the volume knob, when it beeps, turn the volume knob to car type select frs,
to put in a message just go to "opening"
Stevemd24 is offline   Reply With Quote
Old 03-02-2016, 10:49 AM   #54
dgcam55
Drives: 2013 Limited
Did you consider adjusting the Fade 2 or 3 notches to the rear?
That's what I've done, and it fills out nicely.
It also slightly reduces some of the bass from the front, so you may need to adjust your EQ accordingly.
dgcam55 is offline   Reply With Quote
Old 03-02-2016, 05:18 PM   #55
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
Rear fill is wasted for DVD or SACD audio unless your processor uses some sort of surround processing. NONE of the head units currently out will put out a 5.1 signal, they simply take the audio on the disc and output in stereo. The ONLY processor that can decode proper surround sound is the Alpine H990, which is discontinued, and extremely expensive even used.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 03-29-2016, 11:25 AM   #56
FR-S Neck
Drives: FR-S Black Beauty
I was excited to see the finished result.
Did you ever get around to taking pictures of your install?
FR-S Neck is offline   Reply With Quote
Panel Removal for rear speakers? sesmls Electronics | Audio | NAV | Infotainment 8 08-01-2014 07:43 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 07:31 PM
FS [vic] Speakers & Sub fuddbutter Australia Classifieds 2 10-13-2012 07:59 AM
Rear speakers, problem? Style Electronics | Audio | NAV | Infotainment 8 07-15-2012 09:59 PM
Speakers Audi Scion FR-S / Toyota 86 GT86 General Forum 1 01-21-2012 06:09 PM
