Old 10-25-2014, 12:43 AM   #15
Model Citizen
Lacking brains
Drives: frz
i bought them about a month ago, did one small autox day, then first run of the next one blew out my front cat and missed 3 events with the car till the issue was pinpointed.
probably wont have any real time with them till next year now.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-25-2014, 03:38 AM   #16
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
I had the original ZII's, switched over to RS3 v2's after they wore out. I won't go back. I've driven a Fiat 500 Abarth and an STi with the newer ZII Star Specs, and they are an improvement, but the RS3's have so much more grip, especially out in the SoCal heat.
I did feel like the RS3's were missing that "precision" that I've seen people talk about with the ZII's. I don't know if that's the stiffer sidewall or what, but hey! That's the only downside to the RS3's I've seen.
Churg is offline   Reply With Quote
The Following User Says Thank You to Churg For This Useful Post:
fstlane (10-25-2014)
Old 10-25-2014, 07:20 AM   #17
troek
troek's Avatar
Drives: 2012 Toyota 86
plus one on the rs3 vII. cant compare to the ZII, but this tire is amazing.
troek is offline   Reply With Quote
Old 10-25-2014, 11:49 AM   #18
chucky12012
Drives: 2013 Asphalt Scion FR-S
I had run the ZII for two years, switched to the RS3 for nationals and a couple of local runs recently and will be going back to the ZII. The RS3 has grip, but just doesn't seem to work well with my driving style.
chucky12012 is offline   Reply With Quote
Old 10-25-2014, 01:20 PM   #19
xwd
Tirerack has dome some comparison tests and will be publishing some data in the next couple weeks. They tested the ZII Star Spec, Yoko AD08R, BFG Rival and RS3V2.
One of the Tirerack guys (Chris Harvey) autocrosses a MX5 (which took 2nd at Nationals this year on ZIIs) and his feedback on the ZII* is they do not overheat as bad as the ZIIs and they maintain more grip when pushed hard. So overall easier to drive since they don't penalize you as much when exceeding their limits. The old Star Specs and ZIIs typically require more precise driving than the RS3 and the Rival. HOWEVER, he shaved them to 6/32 so they had comparable depth to his ZIIs. Some early feedback from people with new tires is they may need to be broken in a bit. On that car they liked the ZII over the RS3v2.
On a track I still don't think they'll be able to take heat like the RS3, but I expect the ZII* to still be better in the wet than the RS3.
I was going to order a set for STX next year but will probably just go with the RS3v2 for price alone.
The Following 3 Users Say Thank You to xwd For This Useful Post:
fstlane (10-25-2014), G_Ride (10-25-2014), unsurety (10-27-2014)
Old 10-25-2014, 03:36 PM   #20
wparsons
wparsons's Avatar
RS3 v2's don't like heat like the old compound did. They still do ok, but they're definitely easier to overheat than the old ones were. That said, they're grippier with less heat than the old ones were too.
flickr
Old 10-27-2014, 11:48 AM   #21
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I am on the fence about what to try next year...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-27-2014, 10:10 PM   #22
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I only check them for reference on sizing and availability, but the Tirerack prices for the ZII* are strange. Is this normal?
235/45R17 = $168/ea
235/40R17 = $199/ea
What gives?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 10-27-2014, 10:59 PM   #23
renfield90
The Stig's German cousin
235/45R17 = $168/ea
235/40R17 = $199/ea
What gives?
Construction differences in the sidewall? Could be that at 235/40 the sidewall is a little small and it takes some extra reinforcement. The price difference between the 245/40 and the 245/45 is only $7, and both are cheaper than that 235/40.
Could also be that there's not much demand for that tire size and so supply is limited.
If Dunlop pulled a Toyo and put some special sauce in a specific size tire, testing is going to get very expensive...
The Following User Says Thank You to renfield90 For This Useful Post:
unsurety (10-28-2014)
Old 10-27-2014, 11:13 PM   #24
wparsons
wparsons's Avatar
It's probably all just driven off of what sizes are popular. I find 225/45/17 runs very close in pricing to 245/40/17, but other sizes are way off.
flickr
Old 01-28-2015, 12:41 PM   #25
jdp530
Drives: 2014 BRZ
Our autox/DE season has already begun so I need to order some tires ASAP for stock rims. I am running in CS for the time being.
Since the RS3 V2 tires 225/45/17 are back-ordered I am tempted to order the Dunlop ZII SS. The ZII SS 235/40/17 is also available and not too much more expensive.
Would there be a significant improvement in handling with the larger tire running on stock suspension? My car is completely stock but I do have a set of oem crash bolts to install.
Thanks,
jdp530 is offline   Reply With Quote
Old 01-28-2015, 01:46 PM   #26
enigma
Drives: Asphalt 86
Barring any new news from BFG on new Rivals, I'll be trying ZII Star Specs for sure.
enigma is offline   Reply With Quote
Old 01-28-2015, 08:06 PM   #27
renfield90
Rumor has it that news is coming in February...
Old 01-28-2015, 08:08 PM   #28
renfield90
Thanks,
Not significant, and beyond some size there are diminishing (or even negative) returns from going larger. That size is different for each tire model.
There is some data at least that supports oversizing the tire on RS3s, and the ZII SS with its stiffer sidewall should tolerate oversizing even better. I am personally targeting the Dunlop 235 for my next set, unless I end up getting some cheap slightly used Rivals from a local.
klittl06 (01-28-2015)
Dunlop Direzza ZII Star Spec xwd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 05-20-2015 01:30 AM
JRP- New Wheels from Enkei w/Dunlop Star Specs ready to roll!! Stav Canada Classifieds 6 05-02-2013 08:31 PM
Dunlop Star Spec anyone do yet ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 03-15-2013 08:29 AM
New Dunlop Z2 Star Spec Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 113 02-15-2013 01:57 PM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 11:18 AM
