Old 10-05-2014, 04:32 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Any OBD power switch options?
Wondering if anyone has found some elegant way of incorporating an on/off to OBD ports. Specifically, trying to figure something out for my OFT. I know there's the new low power draw option, which is great but there are times where I won't drive the 86 monday through friday. Just want to be extra sure
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
serial gixxer (10-06-2014)
Old 10-06-2014, 06:22 AM   #2
steve99
Drives: FT86
You could put switch into wirefor pin 16 before it gets to obd conector and mount it in dash
Buy a obd extension cable and put in an inline switch
some crowd makes a obd connector with built in switch buy one and make your own cable
buying a cheap obd extension and inorporating switch probably cheapest non intrusive way
The Following 3 Users Say Thank You to steve99 For This Useful Post:
1Cor10:23 (10-06-2014), serial gixxer (10-06-2014), Wayno (10-07-2014)
Old 10-06-2014, 09:10 AM   #3
1Cor10:23
1Cor10:23's Avatar
Did some searching - this looks promising : http://www.fes-auto.com/products_det...p?productid=28
Can anyone confirm if the male connector to OFT is indeed a molex 8? Visual inspection looks close...
@Shiv@Openflash
Old 10-06-2014, 11:33 AM   #4
lucid215
with the new software update the oft will go to sleep. so now you dont have to worry about unplugging it
lucid215 is offline   Reply With Quote
Old 10-06-2014, 11:37 AM   #5
1Cor10:23
1Cor10:23's Avatar
As noted in OP, will be common for me to not drive my twin for 5+ days at a time, low draw might be too risky in case of unforeseen absences.
Old 10-06-2014, 11:48 AM   #6
lucid215
ah gotcha. i missed that part haha.
The Following User Says Thank You to lucid215 For This Useful Post:
Old 10-06-2014, 11:53 AM   #7
stugray
Drives: 2013 GBS BRZ Limited
I thought you were looking for an OBD command to turn off power to the OBD connector.
I thought "Oh that will work, send OBD command to turn off power to the OBD port. Then when you want it back on just send an OBD command to....... wait.."
The Following User Says Thank You to stugray For This Useful Post:
wparsons (04-15-2015)
Old 10-06-2014, 12:01 PM   #8
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Why an on/off switched? why you need a "elegant" way for something that is not visible? Just unplugged it. If you can forget to unplugged then you can easily forget to turn off a "on/off switch". Unless you are thinking of an auto-power off obd cable. What if this elegant solution malfuction during ECU writing process.
OFT may offer this in future firmware anyway.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 10-06-2014, 12:49 PM   #9
1Cor10:23
1Cor10:23's Avatar
It's not a matter of forgetting. The male/female heads basically have a limited number of uses - lots of people with bent pins, would be particularly bad if you busted the female port on attached to the car. I can only assume same goes for the molex connector on the OFT side.
TIE Pilot (10-06-2014)
Old 10-06-2014, 01:14 PM   #10
TIE Pilot
TIE Pilot's Avatar
People are buying $8 extension or "y" splitters to prevent such particularity. In addition you have more options to mount your device.
Not criticizing. Just exploring your idea: cost/pros/cons/alterantives.
*In for results
The Following User Says Thank You to TIE Pilot For This Useful Post:
Old 04-07-2015, 11:27 AM   #11
1Cor10:23
1Cor10:23's Avatar
Update - purchased this from Amazon - going to take ages to ship, likely coming from China.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Following 3 Users Say Thank You to 1Cor10:23 For This Useful Post:
phrosty (04-07-2015), Shiv@Openflash (04-07-2015), TIE Pilot (04-07-2015)
Old 04-07-2015, 12:30 PM   #12
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Nice find! I just ordered one too. If it works as expected, we will buy a load of them and keep them in stock
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
continuecrushing (04-07-2015)
Old 04-07-2015, 12:44 PM   #13
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Bought one too...lmao on the May 1-19 ship date.
ApolloSki is offline   Reply With Quote
Old 04-07-2015, 12:59 PM   #14
jaf89f
jaf89f's Avatar
Drives: Raven MT
Sub'd
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM zetaproducts.net Interior Parts (Incl. Lighting) 28 05-14-2013 09:32 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
