| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: RX7
Help, Rays 57extreme 18 on Toyota '86
Need some help,
I'm planning to buy a Rays 57extreme 18x9.5 +40mm for my Toyota '86. My car is slandered with no modification of whatsoever. I would like to know if the Wheels will stick out/in if I install them on my car without any modification. Or do I need to adjust the suspensions or something like to make the wheels fit just right? |
#2 |
Drives: 2013 DGM BRZ
You probably don't need suspension mods depending on the size of your tires, but 18x9.5 +40 looks horrible on stock suspension IMO. I'd say do suspension mods first then wheels and tires, or at least have lowering springs and some form of camber adjustment.
![]() Saorri for mah bad English ![]() |
#3 | |
Drives: 86 & GRB
Its going to stick out a lot with stock suspension by adding like 40mm spacers. The OEM for 18" wheels recommand 7.5J with 225 tire upgrade. 200HP really dont need big foot but its your preference. |
#4 | |
Drives: Subaru BRZ WRB
#5 |
Drives: 2017 Audi S3
I don't think that setup will work on a completely stock setup, you need coilovers that have a smaller diameter springs for clearance.
With that aside, it will poke quite a bit in the front. Even lowered on coilovers to about about a 2-finger gap up front, I was poking a bit in the front. I got a custom alignment with about -1.5 degree camber and it made it about flush. |
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
#7 |
Drives: Limited BRZ
He is not adding 40mm spacers. What he meant is that the wheel offset is +40mm
#8 | |
Drives: 86 & GRB
{{(9.5-7)X2.54}/2}X10 + (48-40)=39.75 mm Flush setup for OEM wheels (17X7 +48) is F 17X7 + 28 R 17x7 + 23 This mean 18x9.5 +40mm with stock suspension. F will poke 19.75 mm R will poke 14.75 mm In the other word, 18x9.5 +40mm wheels will look like the same as you add 40mm spacers to OEM spec. ------------------------------------- Another example of popular wheels Wedsport TC105N 18X8 +42 If you understand the caculation, you will know how much will poke or stick in for front and rear. The answer is (((8-7)x2.54)/2)X10 + (48-42) = 18.7 mm F will stick in 1.3 mm R will stick in 6.3 mm So Wedsport TC105N front is almost flush but you may need to add 5mm spacers to get flush in the rear. Or try to find wider section width tire if you dont like to add spacers. ---------------------------------------- Here is a pop quizz. 18X8.5J+45 Will this wheel stick out or in? |
#9 | |
Drives: Limited BRZ
http://www.frsproject.com/tire_size.php I have the wheels and wouldn't say they poke out 19+mm in the front and almost 15mm in the rear.
#10 | |
Drives: 86 & GRB
Well, that math is to get you a general idea. The best way is to check the wheels fitment in person. ^.~ |
#11 |
Drives: RX7
#12 | |
Drives: Limited BRZ
255 tires probably need a wee bit of camber to not rub at that height. 265 tires require close to -2 camber, and a slight fender roll on the back (this is the setup I have), and right at the very end of the turning radius, it starts hitting the spring perch so you can't go 100% turn anymore, maybe 95% or so.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Red (10-10-2014) |
#13 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
please search before posting new thread, this was covered a million times. if you simply read the meaty tire thread it will answer all of your questions.
rule of thumb, suspension before wheels. ALWAYS. please do not put a 245 on a 9.5 wheel. |
| The Following User Says Thank You to Jive Turkey For This Useful Post: | Sportsguy83 (10-10-2014) |
#14 | |
Drives: RX7
Please explain why do not put s 245 on 9.5 wheel? |
| Gramlights 57DR / 57Extreme / Volk TE37 | vividracing | Wheels and Tires | 99 | 09-24-2013 08:29 PM |
| FS: RAYS TE37FS: Brand new in box Rays TE37V 17x9 +36 5x100 gunmetal with polished | beat | Wheels and Tires | 1 | 04-29-2013 01:23 AM |
| RAYS 57DR - CUSTOM SIZE SPECIALLY MADE FOR TOYOTA 86 / SUBARU BRZ | Autotechnik | AUSTRALIA | 66 | 01-14-2013 06:14 PM |
| Gram Lights 57Extreme pre-order | No Limit Motorsport | Wheels and Tires | 14 | 08-03-2012 02:16 AM |
