Old 10-04-2014, 04:57 AM   #1
SMOKY
Drives: RX7
Help, Rays 57extreme 18 on Toyota '86
Need some help,
I'm planning to buy a Rays 57extreme 18x9.5 +40mm for my Toyota '86. My car is slandered with no modification of whatsoever.
I would like to know if the Wheels will stick out/in if I install them on my car without any modification. Or do I need to adjust the suspensions or something like to make the wheels fit just right?
SMOKY is offline   Reply With Quote
Old 10-04-2014, 05:13 AM   #2
TestaRossa
TestaRossa's Avatar
Drives: 2013 DGM BRZ
You probably don't need suspension mods depending on the size of your tires, but 18x9.5 +40 looks horrible on stock suspension IMO. I'd say do suspension mods first then wheels and tires, or at least have lowering springs and some form of camber adjustment.
Saorri for mah bad English
TestaRossa is offline   Reply With Quote
Old 10-04-2014, 08:02 AM   #3
86Toyobaru
Drives: 86 & GRB
Originally Posted by SMOKY View Post
Need some help,
{{(9.5-7)X2.54}/2}X10 + (48-40)=39.75 mm
Its going to stick out a lot with stock suspension by adding like 40mm spacers.
The OEM for 18" wheels recommand 7.5J with 225 tire upgrade. 200HP really dont need big foot but its your preference.
86Toyobaru is offline   Reply With Quote
Old 10-04-2014, 12:29 PM   #4
funcheung
funcheung's Avatar
Drives: Subaru BRZ WRB
Need some help,
I have seen my friends do that. It looks like a TRUCK after
funcheung is offline   Reply With Quote
Old 10-04-2014, 01:21 PM   #5
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
I don't think that setup will work on a completely stock setup, you need coilovers that have a smaller diameter springs for clearance.
With that aside, it will poke quite a bit in the front. Even lowered on coilovers to about about a 2-finger gap up front, I was poking a bit in the front. I got a custom alignment with about -1.5 degree camber and it made it about flush.
immaculate is offline   Reply With Quote
Old 10-06-2014, 11:57 AM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Need some help,
9.5 wide wheels will not clear the stock spring perch when turning left/right. Need coilovers to make them fit.
Old 10-06-2014, 11:58 AM   #7
Sportsguy83
Drives: Limited BRZ
He is not adding 40mm spacers. What he meant is that the wheel offset is +40mm
Old 10-06-2014, 03:30 PM   #8
86Toyobaru
Drives: 86 & GRB
Is that hard to understand simple math?
Flush setup for OEM wheels (17X7 +48) is
F 17X7 + 28
R 17x7 + 23
This mean 18x9.5 +40mm with stock suspension.
F will poke 19.75 mm
R will poke 14.75 mm
In the other word, 18x9.5 +40mm wheels will look like the same as you add 40mm spacers to OEM spec.
Another example of popular wheels Wedsport TC105N 18X8 +42
If you understand the caculation, you will know how much will poke or stick in for front and rear. The answer is
(((8-7)x2.54)/2)X10 + (48-42) = 18.7 mm
F will stick in 1.3 mm
R will stick in 6.3 mm
So Wedsport TC105N front is almost flush but you may need to add 5mm spacers to get flush in the rear. Or try to find wider section width tire if you dont like to add spacers.
Here is a pop quizz. 18X8.5J+45 Will this wheel stick out or in?
Old 10-06-2014, 03:44 PM   #9
Sportsguy83
Drives: Limited BRZ
F 17X7 + 28
R 17x7 + 23
LOL.... I didn't even look at your math. I don't think flush is 17X7 +28 and +23
http://www.frsproject.com/tire_size.php
I have the wheels and wouldn't say they poke out 19+mm in the front and almost 15mm in the rear.
Old 10-06-2014, 03:58 PM   #10
86Toyobaru
Drives: 86 & GRB
I think most of ppl here agree that by adding 20mm spacers to the front and 25mm spacers in the rear will get you OEM flush look. At least that works for me.
Well, that math is to get you a general idea. The best way is to check the wheels fitment in person. ^.~
Old 10-08-2014, 07:01 AM   #11
SMOKY
Drives: RX7
If I install TEIN Street flex coilovers will works with these wheels?
Old 10-08-2014, 08:30 AM   #12
Sportsguy83
Drives: Limited BRZ
Yes, but my recommendation to avoid rub is to not go lower than 1.5 inches and don't use tires wider than 245.
255 tires probably need a wee bit of camber to not rub at that height.
265 tires require close to -2 camber, and a slight fender roll on the back (this is the setup I have), and right at the very end of the turning radius, it starts hitting the spring perch so you can't go 100% turn anymore, maybe 95% or so.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Red (10-10-2014)
Old 10-08-2014, 08:24 PM   #13
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
please search before posting new thread, this was covered a million times. if you simply read the meaty tire thread it will answer all of your questions.
rule of thumb, suspension before wheels. ALWAYS.
please do not put a 245 on a 9.5 wheel.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
Sportsguy83 (10-10-2014)
Old 10-09-2014, 11:54 PM   #14
SMOKY
Drives: RX7
I already ordered suspension
Please explain why do not put s 245 on 9.5 wheel?
Gramlights 57DR / 57Extreme / Volk TE37 vividracing Wheels and Tires 99 09-24-2013 09:29 PM
FS: RAYS TE37FS: Brand new in box Rays TE37V 17x9 +36 5x100 gunmetal with polished beat Wheels and Tires 1 04-29-2013 02:23 AM
RAYS 57DR - CUSTOM SIZE SPECIALLY MADE FOR TOYOTA 86 / SUBARU BRZ Autotechnik AUSTRALIA 66 01-14-2013 07:14 PM
Gram Lights 57Extreme pre-order No Limit Motorsport Wheels and Tires 14 08-03-2012 03:16 AM
