Old 09-29-2014, 04:11 PM   #1
gonzo
Drives: frs
Setting Camber and Stock Camber
Should I set front camber depending on how I want the car to feel during autox or is there a set amount of camber that's recommended for all frs'?
Around what is stock camber on an frs with trd springs (.5" drop)?
gonzo is offline   Reply With Quote
Old 09-29-2014, 06:10 PM   #2
wparsons
wparsons's Avatar
Front will be very close to stock, rear you'll have around -1.5 to -1.75.
You'll want more static camber up front since the rear has a much better camber curve.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
D_Thissen (09-29-2014), gonzo (10-03-2014)
Old 10-03-2014, 07:44 PM   #3
gonzo
Drives: frs
Why more static camber up front if the front is already very close to stock after a .5-.75" drop? Because stock camber is not ideal?
By "more static camber" do you mean positive or negative? I assume negative but unsure since I'm new to suspension mods and setup.
Old 10-03-2014, 07:55 PM   #4
gonzo
Drives: frs
Never mind my questions--I'm reading the stickies so I'll probably answer my own questions soon enough
Thanks.
Old 10-05-2014, 09:11 PM   #5
wparsons
wparsons's Avatar
Yep, when I use "more" I meant more negative.
You're also right on why you would want more negative up front. Stock is ~0* and since the camber curve is almost non existent you don't gain (more negative) nearly enough camber as the suspension compresses compared to the rears.
-1.5 up front and -1 in the rear is a good starting point, but will require parts at both ends to adjust the camber. Just adding camber bolts (and maxing them out, then getting a good alignment) will definitely help, especially if it's a really mild drop.
flickr
gonzo (10-07-2014)
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
Curious about camber setting mid_life_crisis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-02-2014 11:57 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
