| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#183 |
No it won't.
| The Following User Says Thank You to s2d4 For This Useful Post: | Vicsweet (09-30-2014) |
#185 | |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Fits well doesn't rub on full lock. Very functional setup for daily driving.
#187 | |
Circle Work Clerk
Wouldn't need them with coilovers as you can just adjust to get camber and the right height. |
#188 |
Drives: M/T Raven FR-S
#189 |
Circle Work Clerk
#190 |
JHerbert Racing
Drives: 2013 Scion FRS
Why can't i find a place to buy 17x9 +45 SBC rpf1's? Is it because the finish is limited edition? I checked all the usual places: ft86 factory - enjuku racing - frsport - touge factory - even ebay is having a hard time coming up with results. Seems most are for 5x114.3.
#191 | |
Drives: 2014 Ultramarine FR-S
Tire Rack has 17x9, +45 in SBC
| The Following User Says Thank You to NLSP For This Useful Post: | Takumi788 (10-23-2014) |
#192 | |
Drives: 2013 Scion FRS firestorm
#193 | |
People rubbing them on stock is because they don't have much room for useful camber due to spring perch, which then gets them on the tie rods.
#194 |
I did not hit the tie rod on stock suspension. The tire was very close to the spring perch.
#195 |
Drives: 2013 Raven FR-S
So, is the consensus here that this wheel will fit the stock suspension without rubbing? I want to use these with a 245 tire on the stock suspension. I'll probably get coilovers later, but not until my warranty is up next year.
#196 |
Drives: FR-S [Hot Lava]
It WILL fit with a +45 but there will be a very slight rub when you lock the wheel completely to the right. It a metal on metal rub. I run this setup and have only rubbed maybe 3 or 4 times when pulling out of a parking spot.
I also run a 245 Dunlop Direzza and do track days driving pretty hard and have never had the tires or rims rub during normal driving or on track. |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 07:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 05:18 PM |
