go_a_way1
Old 09-30-2014, 12:56 AM   #1961
CSG Mike
CSG Mike's Avatar
Originally Posted by ddeflyer View Post
On the stock suspension (stock ride height, springs, dampers, etc), how far can we compress the suspension before we are on the bump stops and start having issues? Put another way, how many lateral Gs can the car sustain before the stock suspension is overwhelmed?
That's kinda situation dependent.
E.g., on an oval, you can be riding the bump stop and be perfectly okay...
Old 09-30-2014, 01:05 AM   #1962
D K
Stig's dark passenger
How much slower is an FRS. Around streets of willow without a wing??
D K is offline   Reply With Quote
Old 09-30-2014, 01:23 AM   #1963
enivid
enivid's Avatar
Drives: WRB JR BRZED
On the track prep thread, it says to not brake hard enough to engage ABS. If there is no brake fade, what other reason is there not to use ABS?
enivid is offline   Reply With Quote
Old 09-30-2014, 01:30 AM   #1964
gramicci101
Off Topic
ABS will be slower. If you can hold the brakes just below the point of engaging ABS, you will be using as much of the tire's traction as possible to slow the car down and the brake pads will be a steady pressure on the rotors. You're basically at the maximum effective braking ability of the car.
If you brake hard enough to engage ABS, it will pulse the brakes, repeatedly locking them up and releasing them. It isn't smooth and could upset the car if you're in a turn. Plus since you're repeatedly losing traction, you're not slowing down as effectively as you would if you had traction the entire time. Longer braking times mean shorter acceleration times means longer lap times.
The Following User Says Thank You to gramicci101 For This Useful Post:
CSG Mike (09-30-2014)
Old 09-30-2014, 01:45 AM   #1965
CSG Mike
CSG Mike's Avatar
None
I'm still waiting on APR... and still prepping for Shawn to morrow.
Old 09-30-2014, 02:49 AM   #1966
enivid
enivid's Avatar
When I first started, I would not engage abs coming off of a straight but I was braking at the 4/3 marker. My instructors told me to use abs so now I'm braking at the one marker. So I've been using it when going 100mph+ and need to slow down.
Old 09-30-2014, 04:39 AM   #1967
CSG Mike
CSG Mike's Avatar
Brake a little earlier, and stop using it. You'll find that you'll scrub the speed faster, AND be more settled for the corner
Old 09-30-2014, 08:24 AM   #1968
troek
troek's Avatar
Drives: 2012 Toyota 86
ive taken this advice and it has proven good for me. i use to just ride the abs into all the corners, now i stay out of it, if i need to brake earlier, so be it. as many people more experienced than me on here have said, and im sure mike has said once, corner exit is more important than entry. i have a nice clip of me overtaking a porsche cayman after a corner exit that demonstrates this nicely.
[ame]http://youtu.be/xGvNDPLL-CM[/ame]
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 09-30-2014, 08:57 AM   #1969
Mgrand34
Drives: FR-S, Evo 9, Evo X
Mike this is a great thread and a terrific resource.
Thanks,
Marty Grand
Mgrand34 is offline   Reply With Quote
The Following User Says Thank You to Mgrand34 For This Useful Post:
Old 09-30-2014, 09:05 AM   #1970
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
@CSG Mike
I wanted to know what a reasonable front and rear camber would be to accomodate 9" wheels with 255 tires. What's the max I could use without really causing an extreme wear situation for daily driving. I do occasional HPDE so I know camber would benefit me.
Part two of the question- When installing rear control arm to adjust camber at what point will i NEED toe arms? At what camber setting do the rear toe arms fall short.
Thanks!
yomny is offline   Reply With Quote
Old 09-30-2014, 11:19 AM   #1971
torqdork
torqdork's Avatar
Drives: RV-7
Mike, would you recommend rotating tires between track days at different circuits?
If so, what pattern would you use with a square setup and non-directional asymmetric tires (Michelin PSS)?
I'm rotating rears cross to front, front straight back after a track day but am wondering if it helps at all in prep for the next event.
TIA...
torqdork is offline   Reply With Quote
Old 09-30-2014, 02:36 PM   #1972
ddeflyer
So I am talking about road course use, basically I am deciding if I need to take the dive now to get some new coilovers or if I am still OK for the time being. I am seeing alot of body roll in high g corners (1-1.2Gs lateral according to data logger) which I would guess is probably reducing my grip and a major factor in the rate that I kill my tire's shoulders.
On a similar note, how do people feel about remote reservoir shocks? Good? Bad? Not worth the point cost in competition? Etc.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 09-30-2014, 05:36 PM   #1973
CSG Mike
CSG Mike's Avatar
Originally Posted by yomny View Post
@CSG Mike
Thanks!
Are you tracking 4+ times a year? Try -2.5 front -1.8 rear. It's "not enough" but we're compromising to accommodate your daily driving. 0 toe all around.
You *need* the arms when you want to be able to adjust rear camber. Otherwise you're at the mercy of your height adjustment.
Old 09-30-2014, 05:37 PM   #1974
CSG Mike
CSG Mike's Avatar
TIA...
We rotate tires based on wear to maximize life, since, like everyone else here, cost is a major factor.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
