Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > EUROPE
Old 09-25-2014, 04:15 PM   #561
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by JoeHK View Post
If i remember correctly the TRD springs are not equal to the Eibach Sportlines but rather to the Eibach Pro-Kit (which is a little less low then the sportlines).
I'm not to sure you will be able to keep warranty on the stock shocks since you're basically "overcharging" them, causing them to possibly break faster (certainly on our crappy roads). A toyota dealer could easily tell you the answer though
They are indeed the Pro-kit. The stock shocks will wear faster but not that much faster because they don't lower that much. It will be the same as if driving with 4 people in the car every day.
I think in the case you just want springs and you're happy with the fixed lowering you could combine the springs with some Koni shocks or something
The only problem with a fixed lowering (in my opinion) is that there's going to be a day when you look at the car and say to yourself: "if it was only 1 cm lower it would have been perfect..."
Originally Posted by GT86meMR2 View Post
the trd springs being from toyota themselves should keep warranty but yeah i should check because I'm no sure and the 1inch drops is enough for me and increased handling without alot of hassle
Try the OEM Subaru crashbolts first to give you some camber in the front, it will improve cornering.
Originally Posted by remme View Post
Hi guys.
Not sure the TRD springs are 'just' rebranded Eibachs.
The 'real McCoy' TRD suspension is a hefty well over 2000€ adjustable racing damper set ( and you need to add a 400€ for the required pillowballs as they don't go on rubber mounts).
There's a 'sportivo' series which is less expensive ...
But ... in Germany you can get at the dealer the GT86 lowered by Bilstein B14 shocks (1065€). Those are sold as 'sporty' dampers for all year round driving. They drop the car 40/40 (front/rear). Eibachs -spring only- are also in the catalogue and drop 25/20 (189€).
OEM's buy alot of stuff of other companies and just rebrand it. My old car was an Opel Astra and you could buy the Irmscher lowering springs, they were exactly the same as the Eibach Sportlines, only a different name and 150€ more expensive for the Irmschers. The taillights from Irmscher were the Hella Icegrey, exactly the same but just a different pricetag.
yeah i just want the trd springs and probably the sway bar set :p it's a nice and cheap increase in handling with a slight drop which is enough here because of our crap roads and since my front bumper hits shit already sometimes... i just hope because they are toyota springs you wont lose warranty.. not just for the shocks but since the gt86 have supposedly weak axles and when lowered they tend to go kaput :p
I don't know where you live but I'm lowered 6cm's from stock and I don't hit anything. And yes, at the meet I was at stock height but that was to clear all the festival-parkings. On normal roads I don't have any problems. I even clear most speedhumps @ 40km/u.
Originally Posted by projectXTR View Post
Goddamnit why can't this be a dealer option ?!
Because Belgium.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following 2 Users Say Thank You to elBarto For This Useful Post:
JoeHK (09-25-2014), projectXTR (09-25-2014)
Old 09-25-2014, 07:16 PM   #562
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
Screw them springs, just like elBarto said, one day you'll look at the car and say it needed to be a little higher or lower...
I'm just going to order myself a nice set of KW V1's and it'll be a done deal; no rust, KW warranty & quality and i can adjust lowering to my likings/surroundings
Hope i'm not making a mistake cause 1000€ is not nothing lol :p
Grtz
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 09-25-2014, 09:41 PM   #563
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Grtz
yeah the popping axles when lowered gives me enough réason to stay with the trd springs if you sustain warranty with them :p
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 09-26-2014, 08:07 AM   #564
JoeHK
JoeHK's Avatar
True, but i'm not going to be slamming it!
Function > form
It's going to be lowered around 4 cm's which - i think - is not too bad
If the axles already break at that point i'd be pretty surprised!
Grtz
Old 09-26-2014, 08:45 AM   #565
GT86meMR2
GT86meMR2's Avatar
Function > form
Grtz
According to the the thread go lowing lower than 1" increases load on them already sadly...
GT86
Old 09-27-2014, 08:38 AM   #566
JoeHK
JoeHK's Avatar
Hmmmm, i'm gonna have to watch out for that then! I had indeed read some stuff about the weak axles, but mostly on extremely lowered cars...
Oh well, i'll see, i can only hope they won't snap
Grtz
Old 09-28-2014, 06:39 AM   #567
elBarto
elBarto's Avatar
Drives: Toyota GT86
Anyone here with an resonated secondary catback with the EC-approved papers?
I want to take a copy of it and modify it for my Milltek.
So my Milltek has arrived this friday, it's the Primary resonated Cat-back.
It's the same as a Secondary Cat-back (resonated) but with the addition of an overpipe and a Secondary Catalyst Bypass Pipe.
The fun part is that Milltek put a plaque with a serialnumber on the muffler and on the Secondary Catalyst Bypass Pipe , Also fun is that the Cat-delete pipe looks like a pipe with a sportcat, I only have the remove the "not for road-use" sign.
So I want to modify the EC approved papers with my serialnumbers and add a section that states there is a 200 cell EC approved sport-cat with it and refer to the serialnumber on the cat-delete pipe.
Should work for the inspection (if they even notice that it's an different exhaust).
The Following User Says Thank You to elBarto For This Useful Post:
projectXTR (09-28-2014)
Old 09-28-2014, 03:48 PM   #568
projectXTR
Drives: Sterling Silver BRZ
You know that it is now mandatory to post sound clips, right ?
projectXTR is offline   Reply With Quote
Old 09-28-2014, 04:58 PM   #569
elBarto
elBarto's Avatar
Drives: Toyota GT86
I know but I'm still waiting for my OpenFlashHeader to arrive. So I can fit all my exhaust parts at once.
Old 09-28-2014, 05:02 PM   #570
GT86meMR2
GT86meMR2's Avatar
So you're going full catless? that's going to be one LOUD car :p
GT86
Old 09-29-2014, 04:44 AM   #571
Yrr
Yrr's Avatar
Drives: Toyota GT86
Can't wait to see you post some soundclips!
Yrr is offline   Reply With Quote
Old 09-29-2014, 07:26 AM   #572
elBarto
elBarto's Avatar
Drives: Toyota GT86
Yes, thats why I went for the resonated version. If I'm lucky I'm just going tot wake up the neighbours and not the whole street
Old 09-29-2014, 10:44 AM   #573
Nostra
Drives: Subaru BRZ Sport Executive
so guys, about a year ago, i posted one of my first post over here.
I've also spotted (i guess) one of the members here.
Well about a year ago also i said that i was going to buy a gt86.
Last thursday, i've signed the purchase order for a brand new subaru brz sport executive in the tipical subaru blue and as an extra sport package by subaru.
Whitin' 2 till 3 weeks i'm driving my dreamcar in the coulour i'm so crazy about.
pics will folow also
kind regards
Nostra
Nostra is offline   Reply With Quote
Old 09-30-2014, 07:38 PM   #574
Twinguin
The 86 is gone.
Twinguin's Avatar
Drives: a Pony*& a HotHatch & a Cabriault
@Nostra: Congratulations, have Fun!
Sent from my toothbrush using iBrush.
"There is a curse. They say: May you live in interesting times!", Terry Pratchett
Twinguin is offline   Reply With Quote
The Following User Says Thank You to Twinguin For This Useful Post:
Nostra (10-01-2014)
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 11:35 PM
GT86 pricing for Belgium (Europe) NA_T Scion FR-S / Toyota 86 GT86 General Forum 13 01-15-2012 12:33 PM
MR2 OWNERS Abflug Other Vehicles & General Automotive Discussions 8 09-02-2010 09:35 PM
