View Poll Results: What drifting setup do you all run?
Pedal dance and turn all off 16 22.54%
Push the trac off button for 5 seconds 55 77.46%
Voters: 71. You may not vote on this poll
Old 09-22-2014, 03:21 AM   #1
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Proper drifting settings
What is the hooning technique for just busting donuts and drifting in general you run?
subiestyle is offline   Reply With Quote
Old 09-22-2014, 07:58 AM   #2
Teseo
Drives: frs
And old FR car
Old 09-22-2014, 09:50 AM   #3
Originally Posted by Manji View Post
Pull the abs fuse. Both of your options above will still interfere.
Can you explain more in how they still interfere? (Not sarcastic! I really would like more info).
Old 09-22-2014, 10:12 AM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Pull the fuse. Gets rid of all the driving aids and won't apply the brakes in a panic situation.
I hate any type of aid, including ABS for drifting.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Manji (09-22-2014)
Old 09-22-2014, 11:17 AM   #5
tennisfreak
Drives: 2018 BMW M240i
Pulling fuses and pedal dance is overkill for just wanting to drift around for fun.
Holding the trac button works just fine.
The Following User Says Thank You to tennisfreak For This Useful Post:
sittinSideways (09-25-2014)
Old 09-22-2014, 01:19 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Not true. I am able to do plenty of slides and manji with just pedal dance.
-alex
amilhazes (09-25-2014)
Old 09-22-2014, 01:37 PM   #7
8R6
8R6's Avatar
Drives: FRS
wet the ground with water.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Old 09-22-2014, 03:10 PM   #8
mav1178
mav1178's Avatar
With only pedal dance:
[ame="https://www.youtube.com/watch?v=cGwnf2tyDPA"]BRZ drifting @ Vegas Drift 05.30.14 - YouTube[/ame]
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
shiro (09-30-2014), teamturbo (09-22-2014)
Old 09-22-2014, 03:14 PM   #9
STV3
Señor Member
STV3's Avatar
Pedal dance. With just holding the trac button for 5 secs you can't use the brake and gas pedal at the same time.
STV3 is offline   Reply With Quote
The Following 3 Users Say Thank You to STV3 For This Useful Post:
CatDaddysBBQ (09-26-2014), Demandred7 (09-22-2014), shiro (09-30-2014)
Old 09-22-2014, 03:41 PM   #10
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Why not?
Frishkorn is offline   Reply With Quote
Old 09-22-2014, 04:01 PM   #11
STV3
Señor Member
STV3's Avatar
Originally Posted by Frishkorn View Post
Why not?
As a safety feature it cuts power to the engine.
The Following 2 Users Say Thank You to STV3 For This Useful Post:
Frishkorn (09-22-2014), lantsalot (09-22-2014)
Old 09-22-2014, 04:05 PM   #12
Frishkorn
Hi everybody!
Frishkorn's Avatar
Cool just a genuine question, hadn't heard that before. This apply to both hand and foot brakes? I only ask because this is my first stick and now that I've got rev match down shifting handled, I was getting ready to learn heel-toe techniques.
Old 09-22-2014, 04:20 PM   #13
STV3
Señor Member
STV3's Avatar
Yeah I learned one night messing around in a parking lot that this happens. So I stopped, did the pedal dance, and boom no more cutting out while using the gas and brake pedal simultaneously.
And you don't want to be on the gas while pulling the hand brake BTW. You don't want the trans engaged to the engine at all while pulling the handbrake for that matter.
Demandred7 (09-22-2014), Frishkorn (09-22-2014)
Old 09-22-2014, 04:35 PM   #14
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
I explained it in another thread a few months ago under my previous account (diss7) but the nanny police had a whinge at how dangerous it is driving the car without any aids or abs. My car has 16,000kms on it, almost all of it has been without the fuse in place. I enjoy the car more.
Depends on what you're trying to do. Those settings allow some oversteer, but will still cut in if you really dial the angle on.
-alex
As above. It will allow oversteer, but not big oversteer. Your video, the first slide would've engaged something, you just mihght not have felt it. If you looked down at your dash, the naughty light most likely flashed. On your other slides, the angle was minimal so it let you get away with it. Try some runs with your current settings, then with the fuse removed; if you have a good feel for the car you'll notice the difference, it'll carry speed better in high angle situations, it'll feel good, and then you'll realise that with the fuse in place, it is applying the rear brakes with higher angle.
I tested this exhaustively when I first got the car. Everyone said that pedal dance was all aids off except abs, but my experience was that there's still something that will cut in at high angle.
Don't ask me the technical reasoning, because I don't know. All I know is what I experienced, and I also know that the other drift guys I talk to have had similar experiences and don't run the abs fuse either.
Here's some vids of me holding the car on full lock through a few sections, all in 3rd gear. Even with pedal dance setting, it would panic at this lock, and it also didn't like lock to lock switches. With the fuse removed it feels like a normal FR car; that's why I never put it back in.
[ame]http://youtu.be/4tw7V20iy8M[/ame]
[ame]http://youtu.be/k0Hgq_kFj44[/ame]
[ame]http://youtu.be/j1upheg_q1Q[/ame]
Manji is offline   Reply With Quote
The Following 3 Users Say Thank You to Manji For This Useful Post:
Demandred7 (09-22-2014), Tcoat (09-22-2014), theurbaninja (09-26-2014)
Help on a proper setup Zechs21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-07-2014 01:20 AM
Proper Intake for 86/BRZ Martin Donnon Engine, Exhaust, Transmission 11 10-17-2013 05:49 AM
Had my car taken away for a proper detailing. Nourdmrolnmt1 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 04-16-2013 12:43 AM
Proper way to Rev Match pinoyplaya Engine, Exhaust, Transmission 46 09-05-2012 02:09 PM
A proper test of the FR-S Vanguard Scion FR-S / Toyota 86 GT86 General Forum 2 03-19-2012 11:58 PM
